Tap factory amp to add an amp
Discussion in 'Audio & Video' started by Txhouse, Dec 8, 2017.
  1. Dec 8, 2017 at 4:01 PM
    Txhouse
    Txhouse [OP] New Member
    Aaron
    2018 Tundra SR5 Crewmax 4x4
    Stock for now.
    All,
    I'm looking to see if I can use some of my existing equipment without buying new equipment. I have a two channel amp that I want to use on the front two channels.
    Can I tap the signal before the factory amp and splice into the speaker outputs for the front without it affecting the amp leading to the rear?
    This is for a non jbl system.
  2. Dec 8, 2017 at 5:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Why don't you just run the front speakers off of channel 1 and the rears off channel 2 and eliminate the factory amp all together. You can get a wiring harness from Tech12volts or ********* so you don't have to hack up the factory harness.
    NewImprovedRon likes this.
  3. Dec 8, 2017 at 8:37 PM
    Txhouse
    Aaron
    Stock for now.
    My front components are two ohm and that wouuld present a 1 ohm load. I would also no longer have any channel separation unless I am misunderstanding something.
