Talk me out of 285/70's
Discussion in 'Wheels & Tires' started by Danimal86, May 15, 2023.
  1. May 15, 2023 at 3:28 PM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm on the fence between 275/70's and 285/70's. I had the intention of either getting some meaty MT's in 275 or a hybrid in 285.
    I found a local person selling some 285/70 Toyo Open Country MT's that are barely used for $1k.
    Is the power and mpg loss really that noticeable?
  2. May 15, 2023 at 3:30 PM
    Mountainmanjh
    Mountainmanjh New Member
    Northern Utah
    2012 Black Crewmax
    Eibach Protruck coilovers and shocks Total Chaos UCAs, bed stiffeners Deaver U748 leaf springs with Camburg shackles TRD sway bars, front and rear Gear Dominator wheels (18x9 18+) Cooper AT3 XLT (275/70r18) RCI engine, trans, and A-arm skids Transferflow 46-gal fuel tank Yakima Outpost bed rack Curt front hitch receiver SumoSprings (yellow) StartX remote start *coming soon* Auburn rear LSD RCI sliders, diff skid, cat guards Coastal offroad front bumper Badlands apex winch Kenwood DNX577S head unit
    Might as well go up to 285/75
    Terndrerrr, Moe2o4, DZ_ and 1 other person like this.
  3. May 15, 2023 at 3:34 PM
    See how much the MT's weigh. I have the Ridge Grapplers in 285/70 and they are 59 lbs. It didn't have too much of a noticeable decrease. These trucks are definitely not know for good mpgs.
  4. May 15, 2023 at 3:43 PM
    AZBoatHauler
    So.Arizona
    I noticed a bigger difference from stock to 275/70-18 E rated than I did going from 275/70-18 to 285/70-18. As mentioned above - I’ll go to 285/75-18 or just bite the bullet and do 35s on my next set.
    Tripleconpanna and PermaFrostTRD like this.
  5. May 15, 2023 at 3:44 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This is the only correct answer.
  6. May 15, 2023 at 3:46 PM
    AZBoatHauler
    So.Arizona
    Ha. New tires, rear bumper, better suspension - hopefully my wife doesn’t get the truck in the divorce.
  7. May 15, 2023 at 3:47 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    She's got the LC, I'm sure she'll be reasonable.
  8. May 15, 2023 at 3:48 PM
    AZBoatHauler
    So.Arizona
    I’m sure she’d love to leave me with just the Pioneer tho. The Pioneer and the kids.
  9. May 15, 2023 at 3:56 PM
    PermaFrostTRD
    Northern NY
    Are you running a lift?
    biebs96 likes this.
  10. May 15, 2023 at 4:50 PM
    biebs96
    PA
    As stated above, if you have a leveling kit or mild lift, go 285/75s. They fit well on these trucks.
    PermaFrostTRD likes this.
  11. May 15, 2023 at 4:52 PM
    Danimal86
    Daniel
    Sacramento, CA
    leveled in the front with 6112's at 1.9" Rear is stock
  12. May 15, 2023 at 4:53 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Nah I’m good
    you do you
  13. May 15, 2023 at 4:54 PM
    Danimal86
    Daniel
    Sacramento, CA
    I thought that on a 2" lift that 285/70's were the largest before having to do some surgery
  14. May 15, 2023 at 4:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    They weigh 70lbs according to the Toyo website.
    Not really worried about mpg too much. Truck gets between 12-14mpg around town, but i do tow a travel trailer a few times a year and dont want to run into power problems.
  15. May 15, 2023 at 5:06 PM
    PermaFrostTRD
    Northern NY
    I think a lot of guys here run 2” up front with 285/75r18. Stock +60mm offset helps with that. Front (bumper side) mud flaps is all that most remove.
  16. May 15, 2023 at 6:23 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    11 MPG in the city :thumbsup:
  17. May 15, 2023 at 6:43 PM
    AZBoatHauler
    So.Arizona
    I think you’re right. Chances are decent 285/75 will hit the bumper.
  18. May 15, 2023 at 6:50 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Has anyone mentioned that 285/75s are the way?
    Terndrerrr likes this.
  19. May 16, 2023 at 6:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    I can live with that.
  20. May 16, 2023 at 6:40 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would stick with 275/70 or go to 35s. Both of those options are probably much easier to find if you are ever in a pinch somewhere.
    Sierradevil likes this.
  21. May 16, 2023 at 6:44 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Ya lets just talk you into 285/75/18s!!! Because that's where its at!!!!!
  22. May 16, 2023 at 6:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    Talk me out of 285/70 and into 285/75's.
    In reality the 75's weren't even on my radar. These more of a common size or just "bigger is better" kinda thing?
    I'd have to look into what else would come along with it...assuming i'd have to use spacers for the front bumper?
  23. May 16, 2023 at 7:04 AM
    JWWard03
    JWWard03 New Member
    James
    2021 Tundra SR5 CrewMax 4x4
    I'm going with 295/70/18s in a Falken Wildpeak A/T3W E-Rated after a 2-3" front level and 1 inch rear block (plus an RAS HD in a few months). Discount Tire lets you try them for a little bit before settling.
  24. May 16, 2023 at 7:04 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    I absolutely love my 285/75/18 Falken Wildpeak AT3Ws. Picked them up from Simple Tire for $1240!
    I'm on Bilsten 6112s on the 4th notch so about 2.5" of lift I believe. On a 18x9 +25 SCS Ray 10! They fill the wheel wells so much better than the 33s!
    Before and after top is 275/70/18 on a 18x9 +12 and bottom is 285/75/18 on a 18x9 +25!
    D4x4TRD and Sierradevil like this.
  25. May 16, 2023 at 7:15 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ohh trust me, i've used that comparison calculator many times.
    my concern is more so how they will fit on the truck, will they clear the UCA and bumer on TRD OR wheels? I eventually will get some SCS Ray10, but probably put them on the OR wheels for now.
  26. May 16, 2023 at 7:17 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    I can get a measurement between my tire and my stock UCA and then deduct the offset difference between the stock trd wheel and a SCS ray 10 which would be 35mm! Then that should tell you if you can fit it on the stock TRD off-road wheel! As long as i have 35mm there you should be able to clear a 285/75/18!
  27. May 16, 2023 at 7:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    that would be great!
    Did you have to trim anything with the 75's?
  28. May 16, 2023 at 7:22 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Nope, when I bought the truck it came with the black rhino York wheels and 275/70/18's and the only thing the guy did to the truck was put the bumper spacers on it and that's it! Which gives you a little extra room but it would be close without the bumper spacer but still would probably clear!
  29. May 16, 2023 at 7:24 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Going to run outside and grab a quick measurement!
  30. May 16, 2023 at 7:29 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    So Between the sidewall and stock UCA on a 285/75/18 on my SCS Wheel I got 1-5/8". So my wheels are +25mm and stock TRD offroad wheels are +60mm which means there is a 1.37" difference so mathematically speaking you should be able to clear a 285/75/18 on a stock TRD Offroad wheel! You Should have about a 1/4" of clearance which is enough!
    rruff and PermaFrostTRD like this.
