Tailgate won't lock/unlock
Discussion in '2.5 Gen Tundras (2014-2021)' started by Baconator, Sep 1, 2017.
  1. Sep 1, 2017 at 10:49 AM
    Baconator
    Baconator [OP] New Member
    Keith
    2016 White Crewmax 5.7l SR5
    I picked up a used 2016 SR5 and I was trying to lock the tailgate but it won't lock. They key won't turn it either way. Is there a known issue with this? Am hoping to install a pop lock but want to be able to lock it in the interim to avoid theft of the tailgate.
  2. Sep 1, 2017 at 11:00 AM
    T-Rex266 Moderator Staff Member
    Never heard of it. Is there dirt inside the tumbler anywhere? You have a 2016 so it should be warrantied if something is wrong with the lock itself
    TheBeast likes this.
  3. Sep 1, 2017 at 1:22 PM
    Baconator
    Keith
    It seems like maybe the key isn't going in all of the way. I'll take it in.
    NewImprovedRon likes this.
  4. Sep 3, 2017 at 10:41 AM
    BDridge1
    BDridge1 New Member
    Bud
    2016 SR5
    Car might have been hit in the ass and tailgate replaced entirely. If they left the original lock cylinder in the replacement, your key goes in and doesn't turn because it's the wrong key. IMHO
  5. Sep 3, 2017 at 10:46 AM
    Baconator
    Keith
    Hadn't considered that. Hope they can just fix it at the dealership
  6. Dec 4, 2020 at 12:47 PM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    2016 Tundra, my tailgate wont lock with the key, it happened once before and after slamming it shut it i was able to use the key to lock it, not under warrentee, the key will turn both ways and was able to unlock now key wont lock it, common problem? anybody know of a quick fix?
  7. Dec 7, 2020 at 4:23 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Do you have another key you can try? Does the key work to lock/unlock the glovebox lock?
  8. Dec 7, 2020 at 4:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just remove the cover and open it up. Bet it’ll be obvious once you look inside.
    LKTundra likes this.
  9. Dec 7, 2020 at 5:50 PM
    Dalandshark
    Dalandshark Fortified with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Have to push on mine a little for the key to turn. I haven’t looked into how to adjust anything yet.
  10. Dec 9, 2020 at 7:36 AM
    scharring100
    Houston, Texas
    Thanks for the advice, I am trying it all, yes, the different key operates the same and both open and lock the glove box so I assume it is in the tailgate mechanism itself.
  11. Dec 15, 2020 at 6:44 AM
    scharring100
    Houston, Texas
    I can get it to lock now but it takes some manipulation of the key and the lock. To fix the problem, once and for all, I will probably replace the assembly. Thanks for the advise
  12. Dec 15, 2020 at 7:35 AM
    1lowlife
    1lowlife Toxic prick and pavement princess
    Sandy Punani
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
    panicman likes this.
