Tailgate Protector?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by westsunset, Oct 9, 2019.
  1. Oct 9, 2019 at 9:46 PM
    westsunset
    westsunset [OP] New Member
    Got a Tundra OEM rubber bed mat, so the bed is all good but now my tailgate is getting scratched up. Thinking of either a rubber protector since the material matches or a plastic that would make it easier to slide stuff in.
    Anyone have any thought on this?
  2. Oct 10, 2019 at 2:58 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I just installed a bedrug tailgate cover and I am satisfied with it.
    Amazon 50 bux.
  3. Oct 10, 2019 at 3:28 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I bought a rubber bed mat that really did the job but ended up blowing-out my tailgate shock, because of the extra weight. Changed over to a Bed Rug tailgate mat (like johnxmccoy) and it does fine.
  4. Oct 10, 2019 at 4:26 AM
    Berettafan
    Berettafan New Member
    2017 CM
  5. Oct 10, 2019 at 6:08 AM
    westsunset
    Hadn't thought of that. I really like that feature and wouldn't want to jack it up
  6. Oct 10, 2019 at 6:10 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Look up mountain hatch.
    They make a flat melamine replacement for the inside of the tailgate.
    Flyinryank likes this.
  7. Oct 10, 2019 at 6:27 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Find a Bullet Liner Dealer in your area and get the bed sprayed.
    Same product as Line-X but not as expensive.
    georgiey22 likes this.
  8. Oct 10, 2019 at 6:29 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I have the Weather tech tailgate cover with the factory rubber bed mat too. Works pretty good. Pretty thin, not heavy. Nothing slides though, its grippy when you're pushing things into the bed. Only complaint is that it gets slightly wavy when it gets hot in the sun. But it goes back flat after it cools off. Its held in with a combo of factory screws and 3M sticky Velcro. I was skeptical of that but it holds well.
  9. Nov 7, 2019 at 8:38 PM
    915tundra
    915tundra New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
    the plastic drop in bedliner has a matching plastic corrugated cover for the tail gate, it would compliment your bed mat beautifully and both surfaces would be about the same height so when your sliding stuff in and out you wont catch the lip between the tailgate and bed floor gap. you can buy just the part for the tailgate
  10. Nov 7, 2019 at 10:51 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Same here.
    I have the OEM spray on liner, but still have the Bedrug bed mat and tailgate mat.
    Both are installed with Velcro and easily removed if needed..
    E56C2A52-CB37-4473-BA4A-B034B228A760_zps_68059568c03bcad9bc30d16392fdbc6934371974.jpg
    546A275F-72CF-4EAD-8C56-93DF9EA35A68_zps_083b8cab62d7da1800a8793296b260c6ead53ee3.jpg
    47C705D7-0F1A-45AF-8C36-4A8D5C3C9E63_zps_c4f4573b4a09f6566bcc8044968586c020204435.jpg
