Tailgate Lock
Discussion in '2nd Gen Tundras (2007-2013)' started by CTB Mike, Feb 21, 2021.
  1. Feb 21, 2021 at 6:40 AM
    CTB Mike
    CTB Mike [OP] It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I have a 2011 CM 5.7 (no FFV) Rock Warrior. Is the tailgate pre wired for a power tailgate lock? There is a harness entering the tailgate close to the middle on the hinge side, but the only thing in the my tailgate that requires power is the backup camera. I'm hoping that the wiring is there so that I can just install the Toyota lock so I don't have to deal with the Pop-n-Lock. Anyone know?
  2. Feb 24, 2021 at 7:58 AM
    CTB Mike
    Southern Arizona
    Well, since it does not appear that anyone knows, can anyone tell me if this was at least an option on the 2011 model year? I cannot find a definitive answer. If yes, then it would make sense that the wiring would be present in the harness together with the camera wiring.
  3. Feb 24, 2021 at 8:12 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    No tundra is prewired for a tailgate lock, it’s a dealer add-on at best. You have to “steal” power from under the driver side kick panel and run it to your tailgate to power the pop-n-lock.
    YardBird likes this.
  4. Feb 24, 2021 at 8:16 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
  5. Feb 24, 2021 at 10:50 AM
    CTB Mike
    Southern Arizona
    On second thought, I would rather not have it. If a thief would be able to hit my unlock button in the cab then he would have full access to the bed (not that any type of cover would really stop him).
  6. Feb 24, 2021 at 11:10 AM
    395 Runner
    395 Runner New Member
    2018 Tundra Platinum MGM 4x4 Crewmax
    I do have a bed cover and so I added one to my 18. Easy install and I could not imagine going without.
  7. Feb 24, 2021 at 11:40 AM
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    I have an undercover classic tonneau cover and if it is closed I can't open the tailgate even when it is unlocked since it wraps over the top of all the edges. If somebody wants in they will still get in the bed though so there is only so much you can do. https://undercoverinfo.com/undercover-classic/2012/toyota/tundra
  8. Feb 24, 2021 at 11:44 AM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    I have a soft tonneau cover, and I definitely leave my tailgate unlocked. My theory is that I don't leave valuables in there anyway, and I'd rather a curious passer-by is able to open the tailgate to see that, rather than slashing my tonneau cover to take a look inside.
    jcr1323 likes this.
  9. Feb 24, 2021 at 11:46 AM
    CTB Mike
    Southern Arizona
    I also have a soft one, but have a hard tri-fold on order.
  10. Feb 24, 2021 at 12:24 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Have you never heard of a Diamondback Cover? I'm confident the things I have in my bed are more secure than what I have in my cab with it.
  11. Feb 24, 2021 at 12:38 PM
    CTB Mike
    Southern Arizona
    Yes, I've done my research and those are a little too rich for my blood, and unless I'm mistaken, the tailgate could still be opened with the cover locked. I have a Rugged Liner on the way.
  12. Feb 24, 2021 at 1:50 PM
    The Californian
    Eric
    Sure the tailgate can be opened - that's why I lock my tailgate.
  13. Feb 24, 2021 at 2:24 PM
    CTB Mike
    Southern Arizona
    My point exactly. If someone were to push the unlock button in the cab (coat hanger, breaking a window, etc.) with a power tail tailgate lock they will have access to everything in the bed. I would rather lock it manually.
  14. Feb 26, 2021 at 1:49 PM
    The Californian
    Eric
    If you have any bed cover other than a Diamondback - they can just pop themselves right into your bed regardless.
