Tailgate Hinges
Discussion in '2nd Gen Tundras (2007-2013)' started by ICECOLDBEER, Nov 24, 2020.
  1. Nov 24, 2020 at 5:08 PM
    ICECOLDBEER
    ICECOLDBEER [OP] New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    Anyone ever take these off before? They appear to be a t40. But they are super tight. Not sure if just rust or maybe there is loctite on there as well. I tried some penetrating oil and then a map propane torch on the back of them. Still super tight and worried I will strip them. Any ideas?
    I have a tailgate ramp I want to put on and want these off to check the fitment.
  2. Nov 24, 2020 at 5:36 PM
    I would ask a bodyshop.....:notsure:
  3. Nov 24, 2020 at 5:46 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Funny you should ask this right now as I am trying to get mine off too.
    I need them off to get my Shell to line up correctly and seal to the back of the truck and I got one off without issue when I put the shell on but the other side is being a little bitch about being removed!
    So I tried to ignore the bad fit on that side until a few weeks ago when I tried a little persuasion applied with a 4 lb sledge and of course broke the tail light on that side but the hinge did not budge!
    So I got a replacement lens the other day and I am going to remove or lift the shell out of the way and soak the crap out of the hinge bolts over a few days and see if that gets me anywhere.
    Very frustrating to say the least.
  4. Nov 24, 2020 at 6:05 PM
    ICECOLDBEER
    That's my plan as well. I guess its just rust. Will try homemade trans fluid mixed with acetone. Soak it a few times probably.
  5. Nov 24, 2020 at 6:09 PM
    ezdog
    ezdog New Member
    Gateway To The West
    My plan as well roughly but using a special Penetrating I got from a friend said to be a Miracle Worker.
    I bent 2 T40 bits on the first go around in an old fashioned Impact Wrench that you hit with a hammer to get it to rotate,I am scared that using power tools or air that I will strip or break something and then have to drill or sawzall after that or both!
  6. Nov 24, 2020 at 6:44 PM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
