Tailgate Assist
Discussion in '1st Gen Tundras (2000-2006)' started by Johnnyg, Oct 16, 2016.
  1. Oct 16, 2016 at 8:03 AM
    Johnnyg
    Johnnyg [OP] New Member
    2004 tundra dc
    Has anyone installed a tailgate assist. I see 2 option; torsion bar or shock and I am wondering what works better.
  2. Nov 8, 2019 at 7:25 AM
    timesinfinity
    timesinfinity New Member
    drew
    northeast
    reviving this old thread... im not seeing much besides the torsion bar these days. anyone retrofit a shock for this?
  3. Nov 10, 2019 at 7:27 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    there are a few on Amazon for various trucks....so I'm gonna try a couple and see if I can't retro fit one for the 1st gens.
    They will be here tomorrow...gotta love Amazon.
  4. Nov 11, 2019 at 5:02 PM
    timesinfinity
    drew
    northeast
    let me know if you make any of them work!
  5. Nov 11, 2019 at 10:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    well I tried two different ones tonight, 1 for a dodge and 1 for a ford. The struts themselves were very different in length but most of the hardware is the same. The issue you run into is that you will probably have to drill a hole into the tailgate as well as the bedside sheet metal. The ball mount bracket that the kits come with are fairly thick and there just isn't enough room between the tailgate and bed sheet metal due to the thickness of the ball mount bracket.
    I'm going to try and find a ball mount screw and see if I can make this work.
  6. Nov 12, 2019 at 7:26 AM
    Professional Hand Model
    Hand Protectors
    Cody. I looked at doing this a while back and ran into the strut thickness being too great to fit in the gap. I actually considered removing the tailgate inner bed cover and mounting the strut on the inside of the tailgate wall (vs. between the gate and latch wall). Might need to notch the tailgate steel? Notch the bed cover and reinstall.
    Didn’t pursue as far as you due to other truck priorities. Maybe this is another option outside the box?
  7. Nov 12, 2019 at 12:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    maybe you could show me a picture about what your saying cause I can’t get a visual of what you mean, sorry. I am thinking about denting in a quarter size of the tailgate and then throwing a threaded insert in there for the ball head screw so there would be more clearance but don’t know if it’s really gonna be worth it. Plus what if I do this and my tailgate is too heavy or too light for the strut....would be all for not then lol
  8. Nov 12, 2019 at 1:29 PM
    Hand Protectors
    Its up to you to make the concept work. Like I said, this was just a brain storming event last year and had too much going on to actually commit to something low on the truck priorities.
  9. Nov 12, 2019 at 2:05 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Gotcha. Yeah I thought about that location too but didn’t wanna have a hole for more dirt and debris to muck up.
  10. Nov 12, 2019 at 2:35 PM
    Hand Protectors
    I could make something happen. Just need the DZ kit in hand then do some reverse engineering.
  11. Nov 12, 2019 at 4:51 PM
    Hand Protectors
    Here is some hardware that I think will make that above DZ opener work without cutting a slot as I suggested above. Ditch the DZ hardware and use these. The final measurements are your call.
    timesinfinity likes this.
  12. Nov 12, 2019 at 4:58 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Could you measure the length of the tailgate cable, get an assist that length and use the threaded studs in place of the existing cable mounting screws?
  13. Nov 13, 2019 at 12:38 PM
    Hand Protectors
    I’m cooking up something right now as this thread restarted a fire from last year. Hope the best for me. If it ends in agony, will you guys still love me?
    Migraine likes this.
  14. Nov 13, 2019 at 1:00 PM
    timesinfinity
    drew
    northeast
    Sick! Just don’t ruin those hands
  15. Nov 13, 2019 at 11:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Those screws are what I was looking to buy locally but no one has them. The ford kit I bought has one but the threads are too small but I believe that it would work otherwise.
  16. Apr 25, 2020 at 4:16 PM
    migx333
    migx333 New Member
    any lucky in this?
  17. Apr 25, 2020 at 4:46 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Ga
    2006 Tundra 4X4 Limited Dbl Cab
    The Hopkins torsion bar will work and isn't really noticeable...
  18. Apr 25, 2020 at 4:50 PM
    migx333
    migx333 New Member
    Does the hopkins bar help both lifting and assists going down on its own?
  19. Apr 25, 2020 at 4:59 PM
    abcinv
    Tommy
    NW Ga
  20. Apr 25, 2020 at 5:07 PM
    migx333
    migx333 New Member
  21. Apr 25, 2020 at 5:22 PM
    abcinv
    Tommy
    NW Ga
    I installed one on an F150 several years ago; not on my Tundra. No more than I drive my truck I'm fine with the heavy tailgate...
    Hopefully a few folks on the forum will chime in
  22. Apr 25, 2020 at 8:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yes, I ended up buying those screws off Amazon but with the two strut kits that I bought, I just couldn't get them to work for me so I gave up on it...
  23. May 2, 2020 at 4:34 AM
    Hand Protectors
    timesinfinity, theblurry1 and abcinv like this.
  24. May 2, 2020 at 9:50 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I'm gonna order that torsion bar and see how it works.
  25. Nov 4, 2024 at 9:38 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    How are these setups working out for you guys?
  26. Nov 4, 2024 at 10:27 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    the torsion bar works pretty well. You still can't just let the tailgate slam down but it's way lighter now and has held up fine for the past 4 years
    Teutonics likes this.
  27. Nov 5, 2024 at 3:50 AM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Installed the torsion bar, as stated it helps both ways but if you’ve had a gas strut before you will be disappointed, it does not slow the drop nearly as much as a strut and you can’t just pull the handle and slam it down.
    It is worth it however imo. Definitely have a buddy over for a beer to help install, they aren’t kidding when they say don’t do it alone. Very difficult to try and hinge the tailgate up and over the bar without smashing it all over the back of the truck
    my experience
    https://www.tundras.com/threads/mechanics-special-05-dc-refresh.133376/page-4#post-3526961
  28. Nov 5, 2024 at 11:42 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I haven't tried the strut, but had the torsion bar on my last truck. I liked it, but yes it was a bitch and a half to install by myself. I don't recommend if you ever have the need to take your tailgate off. both options you have to drill into the tailgate but I liked the bar being lower profile and assisting with both up and down.
    Weagle likes this.
  29. Nov 5, 2024 at 8:17 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    I went deep down this hole a year or so ago. I tried to get the strut to fit in the pocket so it was hidden when the tailgate was closed but there’s just no way. If you’re gonna do the struts, do them like professional hand model ^.
    And I can just attest from having a 2nd gen for a while, the gas strut tailgate is the one thing I miss the most. Other than the 5.7.
    Weagle likes this.
  30. Nov 5, 2024 at 8:20 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep, I bought and still have a few different struts that I just couldn’t make fit without being in the way and out in the open. The torsion bar is the best way to go for us 1st genners
