Tail lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by BRP479, Mar 17, 2019.
  1. Mar 18, 2019 at 1:04 PM
    :rofl::rofl::rofl::rofl::rofl:
    War Machine[QUOTED] likes this.
  2. Mar 19, 2019 at 4:28 PM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    I like my Spyder smoked tail lights
  3. Mar 19, 2019 at 5:07 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Those look great! Why do yours look more red then the other smoked ones I’ve seen??
    Can you post some pictures of other angles? I like LED taillights but I really prefer an OEM look. These kind of look like they could have come from the factory!
    619Tundra likes this.
  4. Mar 19, 2019 at 5:40 PM
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    There are two smoked versions these are the red smoke and That is exactly why I liked them. They are not to flashy or ricey , they are subtle and for sure an upgrade. However the reverse area lenses have lines that give off a ladder pattern that's my only complaint. And If you do get them make sure you have them plugged in correctly postive and negative or it will blow both fuses under the hood and the dash.... don't ask me how I know :anonymous:
    Istvank11, Kerch71, 619Tundra and 3 others like this.
  5. Mar 19, 2019 at 7:28 PM
    CCLJ03
    Craig
    Hahaha. Good info. Thank you!!
    Phadedbeard[QUOTED] likes this.
  6. Mar 20, 2019 at 3:54 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
  7. Mar 20, 2019 at 8:30 AM
    stevep1794
    stevep1794 New Member
    2019 Tundra Limited 2WD - Cement
  8. Mar 20, 2019 at 8:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Exactly the same problem that I have. I've had 'em for 3 yrs. now with no other issues.
    Larmand[QUOTED] likes this.
  9. Mar 20, 2019 at 5:29 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    I go back and forth on Tail lights...rhinking I may just get these, since I just spent a few bucks on all GTR Leds for the facyory housings. I prefer a more '"smoked" factory look, and these would match up with my 2018 OEM Led Headlight conversion.
  10. Mar 20, 2019 at 7:07 PM
    916tundra
    916tundra New Member
    Ken
    2017 Tundra Crewmax
    Do you have a link to these tail lights?
  11. Mar 20, 2019 at 10:03 PM
    Phadedbeard
    Ma
    I got them through autoanything.com your best bet is to message @eccracer104 he is the man over there and can set you up he got me a solid deal.
  12. Mar 21, 2019 at 4:42 AM
    undermyvoodoo82
    undermyvoodoo82 New Member
    '19 Crewmax Limited TRD
    Stocky Balboa and HighonFirewood like this.
  13. Mar 21, 2019 at 5:00 AM
    Apinion
    Apinion New Member
    2015 Black Tundra Platinum
    I have the Lumens. Absolutely love them and lots of compliments. Upgraded to better white reverse lights.
  14. Mar 21, 2019 at 6:39 AM
    Apinion
    Apinion New Member
    A little smoke for you.
    HighonFirewood likes this.
  15. Mar 21, 2019 at 7:47 AM
    sundance
    sundance New Member
    I like those but you could probably buy the tinting lens spray and get the same result.
  16. Mar 21, 2019 at 8:27 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I have Winjets installed for nine months now. I have no problems (knock on wood) aside from the lower LED side marker on the driver's side not functioning. Agree with @War Machine that they are the BEST looking taillight I've seen IMHO. No hyper flash and I did install LED reverse light bulbs.
  17. Mar 21, 2019 at 10:24 PM
    916tundra
    Ken
    2017 Tundra Crewmax
    I’ve placed an order with Autoanything. Can you explain the correct way to wire them or take some photos? I do not want to make a costly mistake of blowing the fuses or frying the wires. Thanks!
  18. Mar 22, 2019 at 4:02 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Where’d you get yours? I like these the best out of all shared on here. I already have led’s from headlight revolution so do these come without bulbs?
  19. Mar 22, 2019 at 5:55 AM
    #49
    undermyvoodoo82
    They reuse the factory reverse bulb so if you already have an LED replacement then you just put it in the new tail light during the install.
  20. Mar 22, 2019 at 7:16 AM
    #50
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Ok cool. I have led reverse and led brake. Only one that’s still factory is my blinker.
  21. Mar 22, 2019 at 7:27 AM
    #51
    undermyvoodoo82
    @bigzrs01 If you go with the style Apinion and I have you'll just need the reverse lights.
    @916tundra the wiring was easy for mine it was all plug and play. The connections were all different so they couldn't be mixed up, they only plug in one way and it came with an extension since the reverse light was in a different location than factory.
    916tundra and bigzrs01 like this.
  22. Mar 22, 2019 at 10:14 AM
    #52
    Phadedbeard
    Ma
    Nice ! Just look at the wires and match the positive to the positive negative to negative I'd pop the tail and take a picture for you but its raining pretty good here... I may be able to take one tomorrow but if you do hook them up wrong the fuses are only a couple dollars worst case scenario.
  23. Mar 22, 2019 at 10:29 AM
    #53
    916tundra
    Ken
    2017 Tundra Crewmax
    Look at this review on Amazon.
  24. Mar 22, 2019 at 10:47 AM
    #54
    undermyvoodoo82
    @916tundra The ebay seller I bought mine from has some pretty legitimate positive reviews in the last 12months and they shipped from the Spyder address.
    #54
    916tundra likes this.
  25. Mar 22, 2019 at 3:22 PM
    #55
    Apinion
    Apinion New Member
  26. Mar 22, 2019 at 3:44 PM
    #56
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
  27. Mar 22, 2019 at 4:56 PM
    #57
    Phadedbeard
    Ma
    That sounds like a bad day I only popped two fuses guess I got lucky I also did them one at a time that may have something to do with it but ill shot a picture tomorrow afternoon for reference also when you do the install I don't know if you have removed the tails before but be gentle pulling on them the inserts can break pretty easily.
    Major and 916tundra[QUOTED] like this.
  28. Apr 6, 2019 at 12:24 PM
    #58
    BigCase19
    BigCase19 New Member
    Casey
    Anaheim, CA
    2016 Tundra CrewMax SR5
    All stock - FOR NOW!!!
    What fuses did you pop? I tried installing my Spyder tails, and at 1st I only had running lights on one, then checked the connections and now I got nothing. No turn signals, no fog lights, and nothing from the tail lights.
  29. Apr 6, 2019 at 12:31 PM
    #59
    BigCase19
    Casey
    Anaheim, CA
    What dash fuses did you blow?
  30. Apr 6, 2019 at 12:43 PM
    #60
    BigCase19
    Casey
    Anaheim, CA
    Fuse location please?
