Tail gate kills my knees...
Discussion in '2.5 Gen Tundras (2014-2021)' started by kai38, Jul 25, 2022.
  1. Jul 25, 2022 at 1:10 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I second the bed step, easy and relatively inexpensive mod. I know this is no help for the Tundras, but my F-250 has an integral tailgate Step that retracts and folds down. I use it all the time. I am surprised all truck Mfrs don’t have an OEM solution right from the factory.
  2. Jul 25, 2022 at 2:02 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Why on earth would I want that?
    It would be in my way.
    I have a bed step I got for Xmas, I just haven't had my truck for 8 months to install it.
  3. Jul 25, 2022 at 2:28 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    BedRug is attached by Velcro and can be swept or hosed off. It is very durable. I have never worried about moisture but live up n a dry desert. In my 08 I do not have a sprayed liner and have only removed it once. The paint underneath was pristine but dusty. In my 20 I have a sprayed liner. I would double check with the BedRug folks but I assume it is mold resistant.
    WillTunBlack20 and cran2[QUOTED] like this.
  4. Jul 26, 2022 at 3:03 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I have the Bed Rug for just the bed and tailgate, highly recommend, with spray liner. I also have a fiberglass tonneau cover, don't worry about water and moisture. Once installed it can be removed easily...also have AMP bed step but so far rarely use it..
    WillTunBlack20 likes this.
  5. Jul 26, 2022 at 3:16 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    x2. Mainly because im 5’3” and couldnt get in the bed anyways but the step helps a lot.
    WILLINH and JDR76[QUOTED] like this.
  6. Jul 26, 2022 at 3:27 AM
    BedRug tailgate mat....
  7. Jul 26, 2022 at 4:14 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I use a broom handle or closet dowel with a hook on the end and pull 95% of what I need close enough to grab. Rare that I ever have to climb into the bed.
    Even with Linex, I can usually pull close enough to grab. Not a fan of bed rugs or mats…unnecessary weight and headache in my view.
    I can make you one for $150 +shipping;)
  8. Jul 26, 2022 at 4:38 AM
    Cthulhu
    OH MAN @Crunch527 what a DEAL!! Please send me one and I will pay you the second Tuesday of next week. :D
    WILLINH, Cpl_Punishment and GODZILLA like this.
  9. Jul 26, 2022 at 11:34 AM
    eagleguy
    eagleguy New Member
    Life has been so much easier for me with the step. Had a small step ladder before but rather have the bed always open.the smalls
  10. Jul 26, 2022 at 1:00 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    619Tundra likes this.
  11. Jul 28, 2022 at 10:45 PM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    I’m cheap.
    Lots of camping in camper shell trucks.
    I use a piece of high density foam cut to 1x2 feet and move the foam as I move about the back of the truck. Sometimes I use two.
    No carpet. I prefer the slippery surface of the bed liner. It makes it easy to load and unload. The bed gets dirty fast when road tripping. Easy wipe to clean before rolling out the bedding for the night.
    NomadicFrog and Cpl_Punishment like this.
  12. Jul 28, 2022 at 11:52 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This.
    JDR76[QUOTED] likes this.
  13. Jul 29, 2022 at 5:20 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    With the way I use my truck, I was thinking a bed rug would get disgusting.
    ZappBrannigan likes this.
  14. Jul 29, 2022 at 4:05 PM
    eagleguy
    eagleguy New Member
    The bed step works for me at 6 foot and the wife at 5 foot. Tried all the other ways (cheaper) first. Waste of time. Guess it depends on what you are lookig for. In my case keeping things in the bed to get in or even the ladder option takes up too much space.
  15. Jul 31, 2022 at 4:03 PM
    Ljackson71
    Ljackson71 New Member
    2018 Tundra Limited
    Here's a step from Toyota. It's priced a little less than the one mentioned earlier. https://www.amp-research.com/bedstep-bumper-step/2018/toyota/tundra $290.00. I think it is the same one with a different brand sticker on it? Made by Lund Motion Products https://parts.streettoyota.com/p/Toyota_2018_Tundra/BedStep/69524312/PT39234140.html $ 218.30. Shipping +$ 25.71
    BedStep
    [​IMG][​IMG]
    Part Number: PT39234140
    Supersession(s): PT392-34140
    Get a leg up when loading or unloading the cargo in your truck’s bed with a BedStep®. It bolts on with no drilling required, and tucks neatly under the rear bumper when not in use.
    • Works with tailgate up or down
    • Hands-free operation; adjusts easily
    • Lightweight, high-strength aluminum die-cast construction features a reinforced nylon step pad with ribbed, nonskid stepping surface
    • 300-lb. load capacity
    • Weather-resistant black anodized and Teflon powder-coat finish for long-term durability
    • Leaves hitch receiver free for towing
    Fits Tundra
    BedStep is a registered trademark of Lund Motion Products, Inc. Teflon is a registered trademark of The Chemours Company FC, LLC.
  16. Jul 31, 2022 at 4:26 PM
    Wallygator
    Does this thing hang down at all? Less ground clearance?
  17. Jul 31, 2022 at 7:05 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Nope! Pops up to only about 1-2 inches below the bumper, still higher than diff and exhaust. I got one, use it EVERY time I get in back of the truck. I'm 5'9", and I would grab the corner, one foot on the bumper, and hoist...and I'm getting too old and crunchy for such as that. Super easy with the step.
  18. Aug 1, 2022 at 7:30 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    ^^^ What he said ^^^
    Wallygator likes this.
  19. Aug 1, 2022 at 8:13 AM
    #49
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    I use folding step stool so I can step anywhere up on to tailgate. Bungee’d to the side walls of the bed when not using.
    Limited-time deal: Acko Folding Step Stool 13 inch Heavy Duty Plastic Foldable Step Stool for Kids and Adults, Small Collapsible Fold Up Stepping Stool 1 Pack https://www.amazon.com/dp/B01LYW5BFB
    Have spray on liner with Weathertech over it. I use a couple of Harbor Freight moving blankets to make a path to where I need to be. Easy on my old knees.
    Wallygator and French Avocado like this.
  20. Aug 1, 2022 at 8:55 AM
    #50
    I use those HF moving blankets for EVERYTHING! Keep one in the cab for quick dog seat protector (I have a nice one for longer trips), bedliner, wrap any antique finds, etc. 3 or 4 more at the house to protect woodworking, floors, lay under the vehicles for working on'em...
  21. Aug 1, 2022 at 10:11 AM
    #51
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Yeah, this is basically my solution: I keep a small folding closed-cell camping pad (found along the road!) in a cubby near the tailgate, and can quickly plop it down for my knees. Doubles as padding to rest on, lean on, etc. Or a rag, or work gloves - I just throw something down fast for my knee(s) - there's almost always something readily available. Not permanent, cheap, light, fast, doesn't take up space as I would have it anyhow.
    A buddy with an '06 took some of those rubber inter-locking workout mats and screwed them to the tailgate with sheet metal screws, then cut to shape. It's very cushy, but he has a higher tolerance for putting holes in his truck. And since we both use our tailgates as our camp kitchen, his mats get...let's just say his tolerance for dirt is higher than mine, too.
    Something like this: https://amzn.to/3zs2lua (Not an endorsement of those, I just quickly picked it at random to illustrate.)
    I like keeping my tailgate bare metal because I do use it for cooking, setting beer cans down, etc., and don't want stuff flopping over on something too soft, or getting soaked in beer, grease, coffee, etc. I do wish there was a fancy replacement or insert for ours (first gen), though, that would do away with most of the corrugation. Every once in a while I lose a few sips of beer to a can that slips into a divot.
    One note that hasn't gotten mentioned at all, and is kinda relevant: mice. I go camping with my friend a lot. I have a spray in bedliner, he does not. Apparently the lack of bedliner leaves enough gap for mice to get in his truck even with the tailgate closed and with his special padding on the tailgate. My bedliner, on both the tailgate and the bed itself, seems to close the gaps enough to keep the mice out. Something to consider if you're camping a lot... those bedrug things that go over the gap seem nice.
  22. Aug 15, 2023 at 4:08 PM
    #52
    solarguy22
    solarguy22 New Member
    Is there any issue with installing this bedstep on a truck with factory dual exhaust?
  23. Aug 15, 2023 at 4:39 PM
    #53
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
  24. Aug 15, 2023 at 6:33 PM
    #54
    French Avocado
    Utah / Wyo
    Nope - works great with dual exhaust
  25. Aug 15, 2023 at 6:39 PM
    #55
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    That's what I did (tailgate bed rug). Works very well.
  26. Aug 15, 2023 at 6:58 PM
    #56
    2mchfun
    Rubber stall mat. Protects the bed, knees, and cargo. Pull it out for a doormat while camping. Heavy bastard too, so it provides for additional traction year round. Flexibility allows it to roll up and down as the tailgate folds.
  27. Aug 16, 2023 at 8:47 AM
    #57
    seydou
    seydou Distinguished Member
    They do. And they are a pain to clean, and trap dog hair, burrs and grass seed very easily. Got rid of the one in my first truck and never looked back.
    I have an OEM bed mat which is more than flexible enough for me to crawl on it with my bad knees. I have a single section of interlocking workout/play mat that I use on the tailgate to get up and down. I had ordered a bed step but while waiting for it, realized it was useless to me because of my topper. Without a topper it would be a no brainer.
  28. Aug 16, 2023 at 8:57 AM
    #58
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I currently have two big pieces of cardboard in my bed (mostly because my dad was concerned about the stuff I was hauling for him scratching my bed - I guess he doesn't know what Line X is :rofl:) and a small rug I use for kneeling on the tailgate and changing tires.
  29. Aug 16, 2023 at 12:51 PM
    #59
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    another vote for a BedRug tailgate mat. first heard of them on this forum and installed one a few weeks ago. game-changer for my old knees :D
    HulkSmurf14 likes this.
  30. Aug 16, 2023 at 1:39 PM
    #60
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Makes no sense, How do you keep the rope in the air?
