Tail and license plate lights no longer illuminating
Discussion in 'Lighting' started by smslavin, Aug 1, 2017.
  1. Aug 1, 2017 at 4:42 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I was just swapping out the license plate bulbs for LEDs. When I turned the lights on to test the new bulbs, I noticed that neither the license plate bulbs nor taillights turned on. Headlights turned on although the fogs are not.
    I just had the topper installed last week and they added some wiring for the third brake light and interior topper dome light. I followed their harness and saw that they spliced into the driver's side taillight wiring.
    cOUERaZy7i-zZ46d0mBHJymuaL86X2Eg8AtDGyNQ_8d5212de37c3ad838d0436151145b0d9fff98c4e.jpg
    Turn signals still work as do the brake lights including the one on the topper. I'm sure this is standard practice for them but I'm surprised the LED Recons are not happy with it. I've checked all the fuses, including the new one in the pic, and none are blown unless there's one I've missed. Looking for ideas as I'm at a total loss. No need to drive in the dark tonight but tomorrow I will have to.
    No time to run over to the topper place tonight but I will tomorrow.
  2. Aug 1, 2017 at 4:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Did you try switching polarity first?
    1UPPER, Law323, Areith762 and 2 others like this.
  3. Aug 1, 2017 at 5:04 PM
    smslavin
    Hudson Valley
    Some stuff
    did not know about fuses under dash. Checking those now.
    Pulled LEDs and put back regular bulbs. Still nothing. Assuming blown fuse somewhere.
    joonbug[QUOTED] likes this.
  4. Aug 1, 2017 at 5:30 PM
    smslavin
    Hudson Valley
    Some stuff
    Found the other fuse box. No idea that was there. Thanks for the tip @RowdyRon.
    Taillight fuse was blown. Replaced and popped the LEDs back in. Everything is back on. New problem though. Passenger side license plate bulb looks like this.
    EimTC64A1y4OzQietocKu9Ujf1FQyezMxFPBgR4C_1fb61d07b4ab3afc07eefb8c3e726c7855f54f08.jpg
    I did not break it. Must have been that way when I picked the truck up. Any ideas on how to get that thing out of there?
  5. Aug 1, 2017 at 6:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Not sure what I'm looking at in the pic, but you can stick your hand behind the bumper to get the license plate light out. Just twist it a quarter turn I believe and pull it out. Careful I believe it only turns one direction.
  6. Aug 1, 2017 at 7:39 PM
    smslavin
    Hudson Valley
    Some stuff
    it's the bulb connector. somehow the end of it got destroyed. the out of focus white blob is the wiring harness. i can't get a grip on it to twist it out. is there a way to get at it from the other side?
  7. Aug 1, 2017 at 8:05 PM
    PMG
    PMG New Member
    Smack a potato on it and twist?
  8. Aug 1, 2017 at 8:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Pliers?
  9. Aug 2, 2017 at 4:27 AM
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    use your teeth
    smslavin[OP] likes this.
  10. Aug 2, 2017 at 10:59 AM
    smslavin
    Hudson Valley
    Some stuff
    Tried using my teeth. Couldn't fit my head up into the bumper. So, after a few rounds of expletives and one smashed knuckle from slipping pliers, I manage to get it out.
    9qmU9JFas52e4w_M-TiKPTMZJPhqI58Xl89NQVJ7_1b1128bc43faf6424c950417d3691737bac74986.jpg
    How the hell does that happen? The plug on the wire appears to be in perfect shape. Head scratcher for sure. Anyways, off to look for a new one.
    NewImprovedRon and joonbug like this.
  11. Aug 2, 2017 at 1:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    1UPPER likes this.
  12. Aug 6, 2017 at 7:04 AM
    motorswin
    motorswin Back the blue
    2017 Tundra Limited TRD
    Maxtrac 3.5" lift Kmc Grenades with Cooper St Maxx 295/75/18
    what leds did you use? I have read some companies don't work with our trucks
  13. Aug 7, 2017 at 10:46 AM
    smslavin
    Hudson Valley
    Some stuff
  14. Aug 7, 2017 at 10:48 AM
    motorswin
    Sweet thanks
  15. Aug 10, 2017 at 2:58 PM
    JohnKoch12
    JohnKoch12 New Member
    2014 Crew Max
    Another stupid question on similar topic. [New guy, first post, thanks for the help]. I have a 2014 Crew Max. My left tail light is out, right is working. Bulb is not the problem. Can't find burned out fuse under dash or in engine compartment. What should I do next? Thanks in advance.
  16. Aug 26, 2018 at 5:41 PM
    VAQuicksand
    VAQuicksand New Member
    did you ever get this resolve?
  17. Mar 20, 2021 at 10:49 AM
    Mrjmm
    Mrjmm New Member
    San Jose
    2015 Tundra Trd
    Icon 3.0 lift , Front / Rear bumpers by RC, 35’s by Pro Comp, Tonneau cover retrac,
    @rowdyron and smslaven I’m having the same issue after replacing the plate lights to led’s. I’m searching for the fuse panel under my dash drivers side but can’t seem to locate it. 2015 crew max Tundra
  18. Mar 20, 2021 at 12:36 PM
    Mrjmm
    Mrjmm New Member
    San Jose
    2015 Tundra Trd
    Ahh found it ! Wow this was not even in a reasonable spot
    Lights work again .. Anyways thank you for the quick reply. Take care
    NewImprovedRon likes this.
  19. Mar 20, 2021 at 12:38 PM
    Mrjmm
    Mrjmm New Member
    San Jose
    2015 Tundra Trd
  20. Mar 20, 2021 at 12:39 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Leds may require a larger fuse. I have had no problem with mine from ibrightstar on Amazon in my 4Runner or 2 Tundras.
  21. Mar 20, 2021 at 12:42 PM
    Mrjmm
    Mrjmm New Member
    San Jose
    2015 Tundra Trd
    Thanks ! What was the amps you upgraded too ?
  22. Mar 20, 2021 at 3:39 PM
    Mrjmm
    Mrjmm New Member
    San Jose
    2015 Tundra Trd
    Thank You!
  23. Mar 20, 2021 at 8:11 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    You are right. I did not put in a larger fuse. I should have said that some led’s draw higher amperage which can cause the fuse to blow. Unfortunately led kits have instructions say they may need a higher amp fuse. But, they shouldn’t recommend that for the very reason you stated.
