Tacoma steering wheel in Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by yoneytan, Oct 30, 2018.
  1. Feb 28, 2020 at 7:06 AM
    #151
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Only paid $122 including tax and shipping. Should have it next Friday.
  2. Feb 28, 2020 at 7:33 AM
    #152
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Good deal, i ended up paying $100 more for a nice one that appears to have perfect leather. It gets delivered today and hoping to get it installed tonight.
    I was happy to jump on the price as the condition was much better than others at the same price point or higher, until I found that one. Oh well, can't win them all. Save some here, lose some there.
    It does look like the 4runner steering wheels have an extra piece of metal at 12 O'clock on the steering wheel. It looks like this can be unbolted as the extra metal piece doesn't match the steering wheel metal color. Your install should be easier since you don't have to switch over stalks or the steering wheel buttons if you prefer the darker metallic grey.
  3. Feb 28, 2020 at 7:45 AM
    #153
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    I’m not sure what piece of metal you are talking about... hope I didn’t get to quick and order a wheel that will not work... that would suck balls..
  4. Feb 28, 2020 at 7:48 AM
    #154
    Critical05
    I found one listed on Car-Part.com from a 2018 tacoma sport listed in grade A for $100. The sports have leather steering wheels. The cab doesn't show any broken glass so less chance of scratches. You could contact them for better photos.
    The vin shows only 38k miles on the wreck so should be lightly used. Don't know if the link will work"
    https://imageappky.car-part.com/image?seller=1984&partsourceid=1984&partGUID=1984-1-325842&vehicleGUID=1984-1-V13539&display=2018 Toyota Tacoma Steering Wheel-Stock# AM9648#1
    Lets just say I had some time to wallow in my "average price" purchase.
  5. Feb 28, 2020 at 7:52 AM
    #155
    Critical05
    This piece, in the tundra/tacoma there is just a plastic wire retainer/guide. On the 4 runner, there is this extra metal piece. The part number for just the wheel is the same accross the tacoma and 4runner so it should be removable. Others have installed the 4runner wheels on tundras and into SR tacomas with no issues.
    Hammerdog[QUOTED] likes this.
  6. Feb 28, 2020 at 8:41 AM
    #156
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Ok, thanks!
  7. Feb 28, 2020 at 8:58 AM
    #157
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Super easy. Unhook negative battery terminal. Use a trim tool, pop the square pieces of trim on the left and right of the steering wheel.
    This will expose a T30 screw on either side. These release the airbag. Airbag pulls straight out. Use a flat blade screwdriver to release the clips on the airbag and unhook the terminals. Remove horn wire. 19mm socket to remove the steering wheel. No puller needed, it will wiggle right of. Transfer controls over (6 or 7 phillips screws). Repeat in reverse.
  8. Mar 2, 2020 at 4:30 PM
    #158
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
  9. Aug 25, 2020 at 10:48 AM
    #159
    Jerry Te37
    Jerry Te37 New Member
    Jerry
    Lapalma ca
    2014 2wd white tundra cm
    Jdm volk racing 20inch te37 Level rear end Morimoto headlight
    Same part# 2020 4Runner TRD Pro
    Probably I’ll order this
  10. Dec 23, 2020 at 4:02 PM
    #160
    Elduder
    Elduder New Member
    Bumping this up, just swapped a wheel in mine, is off center to the left. Attempted to counter adjust the splines one to the right but no change. Is the fix for this just to get an alingment?
  11. Dec 23, 2020 at 4:07 PM
    #161
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Alignment will never hurt. Was your steering wheel straight prior to swapping? If so, might try adjusting the fit again. Make sure wheels are straight.
  12. Dec 23, 2020 at 4:13 PM
    #162
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    You can adjust your drivers side tie rod out 1/4 turn and the passenger side tie rod in 1/4 turn to bring it back center, or you can take it in for an alignment.
    Elduder[QUOTED] likes this.
  13. Dec 23, 2020 at 4:13 PM
    #163
    Elduder
    Elduder New Member
    Straight-ish. Honestly it seems like Ive seen a lot of stock Tundras with a little bit of an off center wheel. Mine was pretty close, now its visibly to the left.
  14. Dec 24, 2020 at 2:10 PM
    #164
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Where has everyone found this wheel i have been looking but haven't came across any..
  15. Dec 24, 2020 at 2:23 PM
    #165
    glowblue
    VA
    Got mine on www.car-parts.com - paid like $175 shipped for it looked brand new
  16. Dec 24, 2020 at 2:30 PM
    #166
    FitsofRage88
    Hill Country, Texas
    do you just set up an account or how did you purchase what you needed with them?
  17. Dec 24, 2020 at 2:51 PM
    #167
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Call them and pick it up, or like I did pay for it over the phone with a small extra charge for shipping and most of them will ship it to you.
  18. Dec 24, 2020 at 2:57 PM
    #168
    glowblue
    VA
    I found the part and called the place that had it to confirm availability and condition and paid over the phone... super easy.
  19. Dec 24, 2020 at 8:06 PM
    #169
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Found one on eBay for $100 in great condition. Easy swap and really makes the truck “feel” better. Add in the nice TRD pro shift knob and the main two points of contact in the truck really improve. Highly recommended.
    WFD473 and glowblue like this.
  20. Apr 4, 2021 at 6:58 PM
    #170
    cjmay13
    cjmay13 New Member
    Corey
    Indiana
    2017 Toyota Tundra TRD Pro Cement Gray
    None Yet.
    Love the picture of Johnny Greaves Pro-4 on your background!
    JoshuaA[QUOTED] likes this.
