Tacoed Tundra project
Discussion in '1st Gen Builds (2000-2006)' started by whodatschrome, Sep 14, 2023.
  1. Oct 22, 2023 at 6:06 PM
    #181
    whodatschrome
    whodatschrome [OP] New Member
    North of North Plains, Oregon
    lots of dents
    I bought a set of four center caps on craigslist this morning. I lucked out that the seller was only a few miles from the church that i go to, so there wasn’t much additional driving. Plus there isn’t much traffic in portland at 9:30am on a sunday.
    Oh, and those $100 center caps came with free wheels and tires. The tires are starting to crack, but i needed a set of rollers to mount on my wrecked truck! It was a definite win for me!
    After i got home i did the ol’ sitchero and mounted the cracked tires onto my steel wheels, then mounted my more street biased (LT215/85-16) tires onto the aluminum rims that i just picked up. It’s nice having a tire machine Coats 40-40). It’s a bit worn out, so it definitely still takes some work, but it’s still pretty sweet to own it nevertheless.
    $100 center caps...
    ...along with free matching rims and tires
    The Black Mamba, Boerseun and BroHon like this.
  2. Oct 22, 2023 at 6:27 PM
    #182
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Nice find :thumbsup:and, they are/were Studded. Never ran those but I did have a set siped back in the day, x2 wet traction/braking, and quite a bit better in snow.
  3. Oct 28, 2023 at 9:08 PM
    #183
    whodatschrome
    lots of dents
    Fedex delivered a care package today. It’s a partial order from a toyota dealer. I have no idea where the rest of my order
    is, so i’ll have to make some calls on monday. But what did arrive today was greatly appreciated. OEM brake shoes, gas cap, and key fob.
    My current brake shoes had about 1/32” of friction material left in a few spots, so i’m glad i spent the time to remove the drums to inspect them.
    The gas cap that was on the truck wouldn’t stay tight...like whatsoever. You could keep twisting until it would click 10x, and the cap could be loosened easily by the wind from the fluttering butterfly’s wings. The new replacement cap solved the issue.
    And thanks to @shifty` for the info on which remote key fob to buy for my truck. I didn’t even realize that my truck had keyless entry as an option. So this is a VERY nice surprise! It only took about a minute to program to my truck.
    B5C45366-39F7-406D-BB84-70AA5533147B.jpg 4F78AC53-EF1C-4CAF-9156-CB45CBCA7BE6.jpg
    Here’s the youtube video i watched to program my key fob. https://m.youtube.com/watch?v=CcfJZ...urce_ve_path=MzY4NDIsMjg2NjY&feature=emb_logo
  4. Oct 29, 2023 at 7:29 PM
    #184
    whodatschrome
    lots of dents
    I found a used lumber rack on craig’s for $260 a few days ago. I left early this morning to go buy it. I don’t know if i will keep it on the truck full time or not. But when you need a lumber rack, you NEED a lumber rack. Luckily it’s light enough that two people can easily lift it on and off the bed though.
    1DECE3A3-1DD1-483B-BC0C-00EDB04109B1.jpg 0E9E7A9C-88DC-4883-9002-4A3C87BFD7FE.jpg
    ZPhilip likes this.
  5. Oct 29, 2023 at 7:56 PM
    #185
    whodatschrome
    lots of dents
    It was kind of a last second idea, but i decided to swap out the foam bottom and back, along with the seat covers themselves between the 2000 and 2004 trucks. The 2004 brown driver seat foam and covers were coming all apart. I used the passenger side seat in the wrecked 2000 truck for the donor parts. Too bad the 2000 truck had grey colored interior, but hey, i had all the parts already so i didn’t have to spend a dime. I’ll just have to install some seat covers to make both side look uniform.
    The seat pan on the left was bent up from the crash, but luckily the foam cushion didn’t get damaged.
    A little comparison between the two seat bottoms.
    Since this is a passenger side seat foam, i had to cut out a chunk of foam where the round seat adjuster knob bracket resides.
    I then glued the foam plug on the other side.
    The colors looks a bit peculiar, but it feels WAAAAAY better on my backside!
    BroHon, The Black Mamba and Mr.bee like this.
  6. Oct 29, 2023 at 8:05 PM
    #186
    whodatschrome
    lots of dents
    I had a large parts order that Fedex was supposed to deliver yesterday. I checked the tracking just now...i don’t have high hopes. I placed the order through Midlands Toyota on 10/8. Tomorrow is the 30th. I’m just starting to get a little frustrated. Hopefully the order does arrive tomorrow AND that all the parts are there and undamaged.
  7. Oct 30, 2023 at 9:35 PM
    #187
    whodatschrome
    lots of dents
    I regreased my front driveshaft splines this afternoon. A new OEM boot was fairly inexpensive (about $8) so i also decided to replace my old boot as well. I cleaned out the old grease, slathered in some new, slipped on the Oetiker clamps, smooshed the boot over the splines, and then reinserted both halves together. I’ll wait to tighten up the clamps after i install the shaft. I don’t want a bunch of trapped air (positive or negative) under that boot.
    Hindsight i’m thinking it would be super simple to add a zirk fitting into the tube. At the same time, since the shaft never compresses or extends, then i don’t really see a need for adding grease as part of a regular maintenance program.
    558FC074-AE24-45F3-9833-C50D93EA3309.jpg A7224620-920B-4B52-8BBF-3A6CC48E3AD7.jpg F6FAD5E3-5AF2-4CB8-A936-A42020C7FAC9.jpg
  8. Nov 3, 2023 at 9:55 PM
    #188
    whodatschrome
    lots of dents
    I received my AVS window visors in the mail and then promptly installed yesterday. They’re pretty much a prerequisite on every vehicle here in the rainy PacNW.
    B422DF22-D441-4C09-9464-2157A3B19367.jpg F088240E-576D-4AF6-8C2B-8F0F7C32BD42.jpg
  9. Nov 5, 2023 at 8:43 AM
    #189
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    What's this promptly installed, you speak of?????
    rock climber likes this.
  10. Nov 13, 2023 at 7:00 PM
    #190
    whodatschrome
    lots of dents
    It’s been a minute since i’ve been on this thread. I’ve been waiting and waiting for my parts order to show up...which it finally did today. 5.5 weeks after my initial order date...Ugh!
    I was at a dead standstill for weeks. All the parts i got from a toyota dealer. The new exhaust studs are quite a bit shorter than the original ones. They also are stainless steel! I don’t have any experience with using stainless studs on the exhaust manifold collector though. Hopefully they’re strong enough.
    Once the exhaust manifold studs were installed (and liberally coated with nickel anti-seize) i quickly proceeded to get the rest of the exhaust installed. I’m hoping to get LOTS more accomplished tomorrow!
  11. Nov 17, 2023 at 6:07 PM
    #191
    whodatschrome
    lots of dents
    I found another rack on craigslist today. It’s not another lumber rack this time, but a hybrid sort of headache rack. It’s a Pro Tech brand an they call it a “sport rack”. This rack would be a lot better for hauling firewood than a lumber rack. At some point i’ll plan to weld in some sort of rear window protection. Whether that be a screen, expanded steel, bars, or who knows what, i just doesn’t know yet. I would like the screen protection to be able to be unbolted and removed so that i could wash the rear window if needed. Maybe i’ll add some backup lights/brake lights/ amber warning lights as well?
    Here’s are pics of it when it was still on the seller’s truck. $150 later and it was on the back of my little trailer.
    ACE24C4E-5C7D-46F3-A16D-BB8011AA8C98.png B36C5F35-13B3-48B8-8E06-F09333423FBD.png 2D147BC1-CDBF-4D06-9345-0742F3FB3755.jpg A65761C1-2013-4C67-9523-897324847D95.jpg 6FE03A46-63DA-4BE3-AE13-B9BC927426C5.jpg
  12. Nov 17, 2023 at 6:26 PM
    #192
    whodatschrome
    lots of dents
    I also did some testing for the past couple days with the ABS delete on my 2004 ABS truck. I’m pretty sure it’s now 100% sorted. I haven’t done any pavement miles on the truck just yet, but i do have all four tires off the ground on jack stands for testing.
    So here’s the gist...there are four ABS wheels sensors, one at each wheel. The two rear ABS sensors send a signal to the ABS pump, which in turn send another signal to the speedometer. If you want to delete the ABS on the earlier 2000-2004 trucks (i dunno about the 2005 and 06 trucks), you MUST retain the two rear ABS sensors! You also have to retain a portion of the ABS pump assembly! You actually don’t need the whole pump. You can simply unscrew the plastic covered electronic portion from the ABS pump itself. But then you should seal the back of the electrics somehow. Perhaps with RTV? I reassembled the electric box to the ABS pump for now. I want to put some miles on the truck before i go and start throwing any of my ABS parts away. So this next spring/summer i’ll get around to the next step. The front two ABS sensors have absolutely nothing to do with sending a speed signal, so those wires are now obsolete. I currently have mine unplugged.
    ABS pump
    What the electronics looks like unscrewed from the ABS pump. You must keep this portion of the ABS pump and plug the wire harness back into it!
    txagg and BroHon like this.
  13. Nov 17, 2023 at 7:28 PM
    #193
    SAGE63
    San Diego County
    love the boat cleat...
  14. Nov 17, 2023 at 8:51 PM
    #194
    whodatschrome
    lots of dents
    Yeah, there’s a total of five of those cleats that are attached with fairly small screws. I don’t really trust them for a heavy load. I think they’re coming off and some sort of loops or something will be welded back on. To the previous owner’s defense, he was hauling around a kayak on the rack. So i guess a boat cleat would have been the most appropriate option.
    SAGE63[QUOTED] likes this.
  15. Nov 19, 2023 at 9:20 PM
    #195
    whodatschrome
    lots of dents
    I went to test the drivetrain of the truck with it on four jack stands. I was getting a horrible shake from the front left tire. After inspecting, i found that the inner steering rod had some slop in it. I decided to order just a single inner rod...then changed my mind and figured i should also buy a new tie rod end too...then prudence came and convinced me to just go ahead an buy inner rods and tie rods for both sides! Might as well buy a pair of TYC front turn signal housings as well. The lenses on both of the existing ones fell out a few months ago. My order arrived from Rocky auto well after dark saturday night. So today i begin the install.
    ...then found out that my left brake caliper was sticky. Turned out three out of the four pistons were a bit rusty. I was tempted to just buy a piston and seal kit, but i’m beginning to loose patients on just how long this project is taking. So it was off to the local parts store to buy a pair of reman 13WL calipers. Of course i accidentally snapped off the brake hard line (that threads into the caliper). I let the words “son of a”...then the rest just kinda trailed off. I wasn’t about to let the truck know that there was a possibility that i would/could get frustrated with it. Luckily my wrecked truck donated its brake line. I got the brakes bleed the rest of the way just after dark this evening. Before i remove the rack and pinion accordion boot, i need to see if i can procure a replacement Oetiker clamp tomorrow (for the boot). Hopefully my local toyota dealer has one in stock.
    1D09B2A7-9B14-48E0-8285-1A1D4F01C75E.jpg E265AE3D-78F0-402A-B4DD-642A4A14ADD3.jpg
  16. Nov 19, 2023 at 9:23 PM
    #196
    whodatschrome
    lots of dents
    I also grabbed the buffer and spent less than 5 minutes polishing up the headlights and fog lights. It would make it MUCH safer to drive at night!
    Before
    After
    Reddawg1100 and BroHon like this.
  17. Nov 19, 2023 at 9:27 PM
    #197
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    While playing with the abs pump, did you happen to stumble upon a way to hot wire it? Some folks have mentioned their belief that the pump hinders bleeding, but mine gravity bled fine.
  18. Nov 20, 2023 at 5:13 AM
    #198
    whodatschrome
    lots of dents
    What do you mean by “hot wire”?
  19. Nov 20, 2023 at 5:16 AM
    #199
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You know, hit a pin with 12v & make the pump pump. I've heard theres a dealer tool that can do it to the newer trucks, but seems the early trucks dont have the option.
    no big deal, i just know i've seen people asking about it.
    BroHon likes this.
  20. Nov 20, 2023 at 3:08 PM
    #200
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    Man you do great work! What a thread!
    whodatschrome[OP] likes this.
  21. Nov 20, 2023 at 6:11 PM
    #201
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I think you do that with techstream on the new trucks.
    txagg likes this.
  22. Nov 20, 2023 at 6:17 PM
    #202
    whodatschrome
    lots of dents
    Thank you sir! It's been pretty fun so far, but the waiting for all my random part's orders to arrive are REALLY wearing on me! I would have liked this project to have been 100% completed 1 month ag0, but i guess that's why it's called a "project".
    AircoolerKirk[QUOTED] likes this.
  23. Nov 20, 2023 at 6:19 PM
    #203
    whodatschrome
    lots of dents
    I haven't even tried touching it. I'm afraid that i would short something out and have to buy a replacement pump!
    Mr.bee[QUOTED] likes this.
  24. Nov 20, 2023 at 6:30 PM
    #204
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    What's that saying... something like "the adventure/fun is in the journey, not the destination"
    I'll second AircoolerKirk, awesome thread here, info and photos are invaluable.
    Cheering you on:thumbsup:, can't wait to see the finished truck.
  25. Nov 23, 2023 at 6:59 PM
    #205
    whodatschrome
    lots of dents
    I noticed that the recently installed fleabay snorkel might vibrate some in the wind. I don’t know that for sure, but it just seemed like it might. So i ended up installing an additional support bracket. The snorkel kit came with a steel bracket, so i decided to use it. I bought some M6 rubber well nuts as well as some toggle type riv nuts from Mcmaster. I wasn’t sure which would work better, but it turned out the rubber well nuts were the winner.
    60468C2E-69A1-4A4C-9B5B-941312CCB87D.jpg B379D454-8589-449F-B653-30D1333EA2F0.jpg 185E2195-D73D-471A-95CD-EE405CD5EF33.jpg
    I did a test of both M6 nuts beforehand on a scrap piece of 1/8” HDPE. The rubber well nut worked better. I would have rather used the steel riv nut, but since it just has a zinc plating, i figured it would corrode sooner than later.
    0F2A8F89-8B05-403D-9DCE-BE00F3208E80.jpg BC6DD386-F45B-447F-B566-C1E536DCCC0A.jpg
  26. Nov 23, 2023 at 7:03 PM
    #206
    whodatschrome
    lots of dents
    Two 1/2” holes for the well nuts were drilled.
    0A2C83BB-9151-4F6F-81EF-77E9409BE24A.jpg 71F74FDB-17C1-4962-B88D-B2A488C9BC6B.jpg FE5804FF-4CB8-420C-A388-D34E7B1670E6.jpg 89CA0A26-3074-4D0D-8A36-A6C78B2CD12A.jpg 92F34DC7-8B70-43D0-84CE-55E1C99B72B1.jpg
  27. Nov 23, 2023 at 8:10 PM
    #207
    whodatschrome
    lots of dents
    I wanted a bit better connection between the rubber S shaped snorkel tube and the hard plastic airbox inlet. My solution was to buy a rubber Fernco style plumbing connector. I used a 3x2” rubber adapter. The 3” coupler had a slightly larger I.D. and O.D. I cut all of the 2” taper off the connector and just kept the 3” portion of it. I got it good and hot with a heat gun, then slipped it over the top of the plastic airbox inlet pipe.
    I also bought brand new stainless hose clamps. The stainless clamps included in snorkel kit began to rust overnight, so i bought new ones that were heavier duty. Once everything was installed and clamped down i was pleasantly pleased with the results. It will be a more reliable and solid connection now.
    I also swapped out the 2004 airbox lid (that has the built in grey colored screen) with a freer flowing open lid off of my 2000 truck. I dunno if there’s any sort of performance difference between the two, but obviously the 2000 lid will have less obstructed air flow.
    161D7088-76FC-4309-88F6-93E83E2970C4.jpg E964B91B-AC13-4597-95A2-4D038AE2085E.jpg 3BD15164-AD46-4586-A4F9-1068D08ADCA7.jpg EBEDD200-8415-45D9-ACF5-119C5767C2AC.jpg
    The rubber S shaped snorkel adapter will slip on over the top of the 3” rubber Fernco piece.
    CF97F656-B142-403A-8267-67D6C2B982AF.jpg D0E25078-89A6-4340-A248-782F3831B526.jpg
    The Black Mamba likes this.
  28. Nov 23, 2023 at 8:21 PM
    #208
    whodatschrome
    lots of dents
    With the snorkel and airbox FINALLY installed, i could now plug in the MAF sensor to the airbox. Ironically the check engine light shut off once it was plugged in. I say ironically because because back when this engine and exhaust system (including the same o2 sensors) was in the 2000 truck, there was always a check engine light on. So i automatically assumed that eventually i would have a large headache of trying to figure out the source of the check engine light once i had this 2004 truck up and running. So right after i plugged in the MAF sensor, the light went off. I didn’t quite trust if i had a broken check engine light or not, so i plugged in a code reader and nothing came up. Success!!!
    4BA8FF99-E022-42C7-9708-56DB78C50D51.jpg 13C51D4A-7944-4213-85EA-917E1BDFB44D.jpg
    Fobroader, The Black Mamba and BroHon like this.
  29. Nov 23, 2023 at 8:44 PM
    #209
    whodatschrome
    lots of dents
    I’m also sheepishly admitting that i forgot to install the dust shields when i installed new wheel bearings. I set the shields RIGHT next to the spindles so that i purposely would NOT forget to install them...well sure enough, i got both bearings and hubs completed installed in the spindles without the dust shields. I didn’t really care too much whatsoever that they are not installed, i’m just really frustrated with myself that i forgot to install them. My old 71 ford f-250 has no dust shields, neither of my 3 jeeps have dust shields (front or rear), so i could care less about having them on the tundra either.
    F7A47AE9-8D82-4B45-B569-6B7996CABE27.jpg 3AAC4629-BB9E-4C17-831C-68C8C5817E96.jpg
  30. Nov 25, 2023 at 6:56 PM
    #210
    whodatschrome
    lots of dents
    I figured if i used a maintenance minder sticker to date my replacement timing belt it would eventually get accidentally worn off. Instead i used an engraver to write down the date and mileage on the airbox.
    M3Tundra-JK and BroHon like this.
