T100 Brake Booster Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Thrussn, Mar 31, 2021.
  1. Mar 4, 2022 at 7:35 PM
    #61
    Redonionbreath
    Redonionbreath New Member
    Could be a silly question, but is there any issue using these parts in a non-ABS tundra?
  2. Mar 4, 2022 at 7:42 PM
    #62
    Thrussn
    Thrussn [OP] Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I'm willing to bet a non-ABS would be even easier. The biggest thing to ensure is that you don't have traction control that came in some first gens.
    des2mtn and FirstGenVol like this.
  3. Mar 4, 2022 at 7:51 PM
    #63
    Redonionbreath
    I’m in a base 02, no traction, no ABS. The whole reason I bought it was it’s the smallest single cab I could find with a full size bed (all the t-100s I could find had frame rot). 10 years later I’m in love and upgrading her. Toyota just replace my frame last month under recall this winter! I’ll be on here a lot soon. Which reminds me, I have to go thank the guy who started the frame rust recall thread. I’ve got huge upgrades coming, gx460 front brakes with the sequoia rear, just had limited slip installed, got factory leather seats with a Honda sienna jump seat for the center, new doors with electric everything, painting it blue raptor liner, dying the whole interior the works!
    AR 02 TUNDRA, bmf4069 and Thrussn[OP] like this.
  4. Mar 4, 2022 at 7:57 PM
    #64
    Thrussn
    Gabe
    NM
    That's awesome! I have more upgrades planned for my unit too as soon as I'm finished up on my 89 Firebird LS build. Your build sounds nice!
    AR 02 TUNDRA likes this.
  5. Mar 4, 2022 at 9:43 PM
    #65
    wiggilez
    wiggilez New Member
    2004 access cab 4x4 tundra
    Topper, 1.2-2" lift, older motorola radio
    I had no idea that there was a no ABS version of our trucks. does that mean the passenger side of your inner fender near the fire wall is just a big blank canvas?
  6. Mar 4, 2022 at 10:19 PM
    #66
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    V8 with no ABS.
    V6 with no ABS.
  7. Mar 4, 2022 at 10:25 PM
    #67
    wiggilez
    wiggilez New Member
    damn, so much room for activities.
    bmf4069 likes this.
  8. May 18, 2022 at 6:15 PM
    #68
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So im bringing this thread back up from the dead. My M/C was leaking into my booster and I ordered parts from Rockauto. Everything went smooth but the brake pedal is really stiff it's stops and hard to push down. Is that normal with the upgrade? Also my e-brake is not holding like it used to.
    Oh forgot to mention that my LSPV was leaking so I installed a wilwood proportioning valve.
  9. May 18, 2022 at 6:55 PM
    #69
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No that doesn't sound right. Almost sounds like a defective booster. What manufacturer did you go with?
    The original poster in this thread got a bad booster initially if you go back and read. They had to send him a replacement.
  10. May 18, 2022 at 7:17 PM
    #70
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I posted a picture of the booster I purchased Cardone 532791
    FirstGenVol[QUOTED] likes this.
  11. May 18, 2022 at 7:20 PM
    #71
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My bad. I saw you mentioned the prop valve and my eyes glazed over the screenshot of the parts.
  12. May 18, 2022 at 7:23 PM
    #72
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Is there a way to test and see if the booster is defective? I have a road trip on Friday and now I'm worried the it's bad I paid $60 for next day air.
  13. May 18, 2022 at 7:33 PM
    #73
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    There is a test in the field service manual. I'm on my phone or I would look for it. You can probably find it using the search function here. It's been posted before. Google says a stiff pedal is a sign of a faulty booster.
  14. May 20, 2022 at 4:54 AM
    #74
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    My pedal would get stiff due to lack of vacuum. But it wasn't constant, only after high rpm like cresting the 1 hill we have here. Did you double check all your vacuum lines @Dave8699?
  15. May 20, 2022 at 5:19 AM
    #75
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Thank you for your response as this has me going crazy not knowing if it's normal. I'm assuming my vacuum lines are good as my old booster was working. The new upgrade booster has a consistent feel. Pedal feels like when the cars off.
  16. May 20, 2022 at 5:27 AM
    #76
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Never assume. Give em a good eyeballin’.
  17. May 20, 2022 at 5:32 AM
    #77
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Whats the easiest way to check the vacuum? Is there a diagram that I can follow or should I buy a vacuum gauge ?
  18. May 20, 2022 at 5:35 AM
    #78
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Carb cleaner if that finds a leak while the engines running rpm will increase. But also looking for cracks after you disconnect the hose.
    Riverdale21 likes this.
  19. May 20, 2022 at 5:37 AM
    #79
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I'll give that a try, also how would I determine if the booster is bad.
  20. May 20, 2022 at 5:43 AM
    #80
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    When its running, lift the pedal up, theres a bit of movement from gaps in the linkage, but if the pedal comes up more than 1/8-1/4 inch something might be wrong.
    my brake problem was the mc, my booster was still good, so i’m assuming with speculation.
  21. May 20, 2022 at 5:51 AM
    #81
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Ok ill give that a try it's a brand new t100 M/C and booster
  22. May 20, 2022 at 5:55 AM
    #82
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Oh, did you shorten the push rod?
  23. May 20, 2022 at 5:55 AM
    #83
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I can't find any pics, but rodents had chewed up some of my lines on the box by the booster, and 1 of the lines was disconnected. After replacing those the problem went away. I'd check the easy stuff like that first. Don't forget the connections on the booster itself!
  24. May 22, 2022 at 3:15 AM
    #84
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Yes I cut about 1/2" I left it to the same distance of my oem booster.
  25. May 26, 2022 at 5:56 AM
    #85
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I noticed that when I shut the truck off there is a very low hissing sound by the pedal. Is that normal or is that the booster leaking?
  26. May 26, 2022 at 6:06 AM
    #86
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I just placed an order for a new booster under warranty let's hope that's the problem.
  27. May 26, 2022 at 6:18 AM
    #87
    Casper421
    In the woods
    06 DC
    Does the brake pedal lose pressure and depress quickly when applied?
  28. May 26, 2022 at 3:01 PM
    #88
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Nope it's constantly hard, it's a little softer then if the truck was off.
  29. May 26, 2022 at 3:35 PM
    #89
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Also forgot to mention my ABS light turns on here and there.
  30. May 26, 2022 at 3:49 PM
    #90
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Sometimes that means low fluid
    des2mtn likes this.
