T-SB-0043-21 June 9, 2021 Audio Head Unit Software Update (Panasonic)
Discussion in 'Audio & Video' started by Authority, Sep 12, 2021.
  1. Sep 12, 2021 at 10:13 AM
    Authority
    Authority [OP] New Member
    Sam
    SLC, UT - USA
    2020 Black Tundra Platinum
    SPC Upper Control Arms Bilstein 5100 front and back Readylift front diff & sway bar drop Toyo Open Country R/T LT285/75R18 Fuel Off-Road Vector 18” wheels Bushwacker OEM style fender flares. Mods by: @proaudioutah AJT Design on a lot of my interior, including shift knob replacement.
    Originally posted over here, but figured I'd move this to a new thread, might help some people if they're experiencing issues with the stock head unit. The attached TSB referenced quite a few software improvements. I jumped from 1021 to 1047, then to the latest referenced below. Comparing 1021/1006 to 1162/1150; seems to be roughly the same for me minus any reference to Entune (now Apps). Menu does seem a bit more responsive. YMMV, and upgrade at your own risk.. I imagine a dealership will be able to upgrade for you, I just decided to purchase the 2-day TIS account and do it myself.
    Latest TSB: (attached to this thread)
    I ended up downloading them, and trigger released, now it is running Audio Version: 1162 and Navigation: 1150.
    Initial impressions look about the same, maybe a little less lag in the menu compared to my original 1021... They also renamed the "Entune" stuff to "Apps" or something, I saw no mention of Entune anywhere in the settings or apps page.
    No noticeable difference to audio yet, but I'll test more in the days to come.
    Public link(s) to the firmware so no one needs to pay the $65 for TIS... -- and upgrade at your own risk.
    Edit: zipped file containing both 0066 update files. I just placed them on a USB drive formatted with FAT32 (nothing else but the two files on the root, connected to the data USB port); started up the truck and checked for an update. Took ~5minutes to update. Restarted the truck (off/on) once prompted, and it was good to go. No messing with the battery.
    https://www.filefactory.com/file/2btrv6w7n53q/Tundra0066FW.zip
    or:
    (1/2): https://www.filefactory.com/file/2kufblfq641q/17TDT2NA-DA30_0066.kwi
    (2/2): https://www.filefactory.com/file/2fzjsaclmde6/17TMT2NA-DA50_0066.kwi
    Copied from TSB for search/Index:
    Some 2020 model year vehicles equipped with Audio Plus (version 1035) or Premium Audio (version 1035) or earlier may exhibit one or both of the following conditions:
    Abnormal screen play while using Apple CarPlay® (primarily during phone calls).
    Poor sound quality during phone calls while using Apple CarPlay®.
    Some 2020 model year vehicles equipped with Audio Plus (version 1047) or Premium Audio (version 1047) or earlier may exhibit one or more of the following conditions:
    USB audio does not resume after ignition cycle.
    Intermittent rebooting.
    Bluetooth disconnecting during a phone call when using Apple CarPlay®.
    Intermittent screen freezing.
    Navigation intermittently will not boot up.
    Home Screen Audio widget is blank after a Destination Assist call.
    Song, artist, or album data missing.
    Abnormal clock operation.
    Apple CarPlay® intermittently inoperative.
    Radio takes a long time to boot up.
    Some 2020 – 2021 model year vehicles equipped with Audio Plus (version 1065) or Premium Audio (version 1065) or earlier may exhibit one or more of the following conditions:
    Bluetooth Audio not displayed on the MID (Multi-information Display).
    Unable to connect iPhone® device via USB.
    iOS device inoperative until IG OFF/ON.
    Some 2020 – 2021 model year vehicles equipped with Audio Plus (version 1101) or Premium Audio (version 1101) or earlier may exhibit one or more of the following conditions:
    Audio does not resume after playing voicemail in Apple CarPlay®.
    Repeat icon does not match what is displayed on the handset in Apple CarPlay®.
    No sound from Siri®.
    Abnormal Voice Recognition Operation when connecting a phone for Projection Mode.
    Apple CarPlay® music will stop intermittently after IG ON.
    Incorrect cover art is intermittently displayed during Apple CarPlay®.
    Unable to change volume while listening to voicemail.
    Apple CarPlay® audio intermittently resumes.
    MAP switch intermittently does not work with Android AutoTM.
    Intermittent pop noise when listening to USB audio.
    Intermittent blank screen.
    Blower speed incorrectly displayed.
    Some 2020 – 2021 model year vehicles equipped with Audio Plus (version 1122) or Premium Audio (version 1124) or earlier may exhibit one or more of the following conditions:
    Intermittent Radio Rebooting.
    Tune knob doesn’t change the track in all audio sources.
    “Waiting for the beep” is displayed, but voice recognition does not start.
    Music does not resume when changing the volume, and the audio source is paused.
    Blower motor mode does not match the actual blower mode.
    Apple CarPlay® does not start immediately after connecting iPhone®.
    Rear Seat Entertainment equipped vehicles have inoperative track controls.
    Incorrect FM and XM® genre information.
    1794Fan0315 likes this.
  2. Nov 8, 2021 at 8:28 AM
    Stoogefan
    Stoogefan New Member
    2015 Tundra Limited
    Will this work for a 2015 with navigation? My audio shows it was updated in 2018. I just paired a new Google Pixel 6 and now it rebots the radio after 30 minutes. Very irritating! any guidance provided is appreciated.
  3. Nov 24, 2021 at 5:47 PM
    Lordaca
    Lordaca New Member
    2019 Calvary Blue Limited 4x4 crewmax
  4. Dec 2, 2021 at 6:32 AM
    kent.fraser
    kent.fraser New Member
    Do you still have access to the TIS? Looking for the audio update for a Sienna.
    File name would be: 17TDT2NA-DA55_0066.kwi
    Thanks.
  5. Dec 7, 2021 at 10:22 AM
    Authority
    Sam
    SLC, UT - USA
    I no longer have access. Only purchased a 2-day license.
  6. Dec 7, 2021 at 10:28 AM
    kent.fraser
    No problem.
    Was the 2 day $20 access enough to get the files needed?
  7. Dec 7, 2021 at 11:21 AM
    Authority
    Sam
    SLC, UT - USA
    I believe I paid around $65 for professional; from what I read the standard one didn't allow for file downloads... but it's possible I overpaid.
  8. May 2, 2025 at 4:41 PM
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    Has anyone used this lately or still have the files? It looks like the links are dead...
