********* System 1B - Detailed Installation and Reviews
Discussion in 'Audio & Video' started by Netmonkey, Jul 31, 2018.
  1. Oct 13, 2019 at 1:08 PM
    #61
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    i am glad that i got the 12's. the system sounds good to me. it is so much better than the stock system. i am sure that there are better systems out there, but this one is a great bang for the buck and everything was plug and play..
    afbatts[QUOTED] likes this.
  2. Oct 29, 2019 at 8:35 AM
    #62
    afbatts
    afbatts New Member
    19 Black Tundra 1794 JBL
    @Netmonkey do you have a picture of the crossovers mounted on the rear doors?? I went to mount the same way as front doors but the wiring harness is in the way. I just flipped the mount and it fit well that way. just wanted to know if you had to do the same. No videos or images ever show the rear door mounts.
  3. Oct 29, 2019 at 8:41 AM
    #63
    Netmonkey
    Georgetown, TX
    hmm... I guess I didn't take a picture of the crossover on the rear door. for me, it went in the same way as the front doors.
  4. Nov 2, 2019 at 12:34 PM
    #64
    afbatts
    afbatts New Member
    Thanks to your installation doc file it helped me big time. Finished my install last night. Only question I have is for the Mids and Highs amp. For tuning it is set on HP. Does it get changed back to Full once done? Thanks again for this write up!!
    Netmonkey[OP] likes this.
  5. Nov 2, 2019 at 12:37 PM
    #65
    Netmonkey
    Georgetown, TX
    no, once the amp is tuned, leave the settings the way they are. do not change them back.
  6. Jan 19, 2020 at 7:44 AM
    #66
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    This is HANDS down the best Write up Ive ever seen. Thanks Sooo Much.
    DjSamthrax and Netmonkey[OP] like this.
  7. Feb 21, 2020 at 5:34 AM
    #67
    Brownmoney
    Brownmoney New Member
    Anybody here have the same system with JBL? i could use some help on the settings for the amps. Thanks.
    system sounds good but i just have all the settings set to the middle on the amps
  8. Feb 21, 2020 at 6:45 AM
    #68
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I like the email photo regarding the blue remote on wire.
    That one also got me for my install of the LOC and my Amp.
    Called Crutchfield and the support Rep asked me the exact same question.
    Dang blue wire !!!
    Nice write up my man... Should be a sticky !!!
  9. Nov 7, 2020 at 5:08 AM
    #69
    dkard
    dkard New Member
    Just wrapped up the same install in my crewmax yesterday. I've done a number of audio installs over the years and this one was the most complex. But with the step by step videos and the outstanding support that I got from Daniel, everything went super smooth. The sound of this system is outstanding and the best part is I didn't have to cut a single factory wire for the entire install (including when I swapped out the head unit). Overall, I am extremely happy with this system and the amazing support I received. If anyone is considering doing this upgrade, I highly recommend it. Just plan for a full day of work to do the install!
    Black@Blue19 and Netmonkey[OP] like this.
  10. Nov 9, 2020 at 8:19 AM
    #70
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Nice write up. On 2 is why I went the Tech 12 Volts direction of having brand name products supported by mfg's. I know anything other than stock will greatly improve the sound, but I was exhausted reading this. Think the 12 volt is a little more straight forward and similar, no stock harnesses to cut. Hope you figure out your next steps and get it banging again!
  11. Mar 16, 2021 at 6:43 PM
    #71
    Wellensky
    Wellensky New Member
    Lereazoah
    2016 Toyota Tundra crewmax Limited
    None
    This is breath taking.
    Please do you live in Texas? Can I pay you to do thesame for me ( 2016 Tundra), please?
    9105452050
  12. Mar 16, 2021 at 7:45 PM
    #72
    Netmonkey
    Georgetown, TX
    Heh. Yes, I live in Texas, but you would be better off going directly to T a c o t u n e s for an installation.
  13. Mar 16, 2021 at 11:34 PM
    #73
    Wellensky
    Lereazoah
    None
    Thank you sir.
    Do you happen to have an idea how much to expect to pay at ********* for installation?
  14. Mar 17, 2021 at 5:22 AM
    #74
    Netmonkey
    Georgetown, TX
    Back in 2018, they were charging around $550 for the installation; which is totally worth it. But I don't know what they are charging now. You should contact them.
  15. Mar 17, 2021 at 5:29 PM
    #75
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    $550 is worth it. I spent probably 12hrs total on my speaker and amp install. I think the most time consuming was doing the sound deadening. I'm sort of a perfectionist though. Glad I tackled it myself and saved money for my subs. After doing all of that, the sub install will be cake.
  16. Apr 1, 2021 at 7:11 PM
    #76
    zlaneb
    zlaneb New Member
    Austin, TX
    Curious - what did TT do or not do that caused the forum to block their name in all the posts? Were they a paying member that stopped paying?
  17. May 25, 2021 at 11:58 AM
    #77
    Jingusflob
    Jingusflob New Member
    JT
    Silver 2020 Xp Predator
    None yet...just beginning
    This is an OUTSTANDING thread! Perhaps one of the most well laid out and comprehensive DIY posts I've seen in a very long time. Thank you for putting it together. I am about to start my install this week and I am so glad to have stumbled across this. It all makes sense now. I was a little worried at first, but this thread was spot on. I am putting in the 1B with sound deadener all the way around and 2 x 12" subs. Also doing component speakers front and rear. Can hardly wait. I have not heard one of these systems yet. Only could find one video that seemed to show what it sounds like. Hope it ends up worth the money. Everyone says it is. - JT
  18. May 25, 2021 at 12:28 PM
    #78
    Netmonkey
    Georgetown, TX
    awesome. If you run into any problems during your install, I am happy to help out.
  19. Oct 8, 2021 at 7:07 AM
    #79
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Just purchased a non JBL 2021 Crewmax and considering the audio upgrade at some point.
    Thanks for your very detailed step by step procedure. I can truly appreciate the time it must have added to your install and it will be a great resource when I begin pulling my truck apart.
    Unless it was skimmed over I didn't notice a signal processor such as a Fix 86 was used in front of the amps.
    Wondering if such a unit would have made much of a difference in the sound quality on your system and counter any possible bass roll off that many factory head units are known to have.
    Netmonkey[QUOTED][OP] likes this.
  20. Oct 8, 2021 at 7:19 AM
    #80
    Netmonkey
    Georgetown, TX
    The JBL system does require a signal processor whereas the non JBL system does not require one. Since I do not have the JBL system, I opted to not add that unit. For me, the quality of the new system is just fine. It is way better than the stock system so I am happy with it. I suppose if you are a true audiophile, you would want to add the signal processor for even better audio quality.
  21. Oct 26, 2021 at 8:15 AM
    #81
    Nickatnight
    Nickatnight New Member
    Nick
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    First Class install thanks
  22. Oct 26, 2021 at 11:42 PM
    #82
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Word has it they have screwed customers both here and on Tacomaworld over the years. No one has gone into detail.
    My own experience with TT was mixed. Very mixed.
    Mike59 likes this.
  23. Oct 27, 2021 at 8:04 AM
    #83
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    I know you put alot of time into making the audio install, is their a chance to get a copy? Thanks
  24. Oct 27, 2021 at 8:29 AM
    #84
    Netmonkey
    Georgetown, TX
    copy of what?
  25. Oct 27, 2021 at 8:49 AM
    #85
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    THe checklist for the audio update.
  26. Oct 27, 2021 at 8:59 AM
    #86
    panicman
    Eric
    Look at the first post in this thread.
  27. Oct 27, 2021 at 9:48 AM
    #87
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    Yes I see it (install doc) but when I click on it, it just goes to the thread and no doc. It might be my computer but the checklist doesnʻt show up.
  28. Oct 27, 2021 at 11:56 AM
    #88
    Netmonkey
    Georgetown, TX
    hmm... the link is still good... it downloads for me. maybe a browser setting is preventing it from downloading?
  29. Oct 27, 2021 at 3:35 PM
    #89
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    Yes sir, I guess Iʻm a dumbass.. LOL, I was able to download it off my iphone. Sorry for the trouble.
  30. Nov 28, 2021 at 5:48 AM
    #90
    thedonn
    thedonn New Member
    great thread netmonkey- that is some impressive work!
