Synthetic oil, conventional oil, does it even make a difference?
Discussion in '3rd Gen Tundras (2022+)' started by patriotpat, Feb 10, 2022.
  1. Feb 10, 2022 at 7:36 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Exactly.
    Extra internet points to anyone who can actually find for sale a non-synthetic 0W-20. There are very, very few manufacturers that make a conventional zero weight. So in practical terms there is no choice.
    Black Wolf and Cpl_Punishment like this.
  2. Feb 10, 2022 at 7:37 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    If you look up IlSAC GF-6A approved oils, they only list Full synthetic or synthetic blends. No Dino oil listed.
    mountainpete and JLS in WA like this.
  3. Feb 10, 2022 at 7:39 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Think pretty much dino is only used for specialty products like clutch based LSDs and lockers and such nowadays.
  4. Feb 10, 2022 at 7:43 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Bingo....I knew someone would get it...:yes:
  5. Feb 10, 2022 at 7:53 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I had some Banana Pudding flavored Dee's Nuts yesterday. Highly recommended.
  6. Feb 10, 2022 at 8:22 AM
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    Note even remotely true, but okay. I agree with you, the best oil is clean oil; however, synthetic can last longer under high heat and colder environments.
    If you change your oil ever 3k, it really doesn't matter what you use. Those "close" interval oil changes allows you to do any preventative maintenance it might need which makes it last longer... Also clean oil generally means a clean intake/valves which always have build up with people that choose not to change their oil.
    You do NOT find more wear using synthetics, no way no how. Every oil analysis, test, and wear tests show they reduce wear.
    Oil is NEVER the direct cause of an engine failure. Generally it's poor machine work or someone's screw up putting it together.
    GODZILLA and WXman like this.
  7. Feb 10, 2022 at 8:29 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
  8. Feb 10, 2022 at 8:39 AM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    Four things I hate discussing. Politics. Pickup Trucks. Religion. and Engine oils.
  9. Feb 10, 2022 at 8:56 AM
    mass-hole
    mass-hole New Member
    0W-20 is too light for a TT V6 in a truck and is all about the EPA. Prove I am wrong.
    sd172 and Hoff like this.
  10. Feb 10, 2022 at 8:59 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Look at your user name. Done...
    RavingOx and GODZILLA like this.
  11. Feb 10, 2022 at 9:08 AM
    nuclear
    nuclear New Member
    :popcorn:
    RavingOx and sd172 like this.
  12. Feb 10, 2022 at 9:15 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You know that farm guy on youtube who tests stuff. I’d LOVE to see the difference in performance between conventional oil at 2500 miles and synthetic oil at 9k miles…
  13. Feb 10, 2022 at 9:20 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Hydrodynamic wedge.
  14. Feb 10, 2022 at 9:24 AM
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I like cow milk. But that’s just me.
  15. Feb 10, 2022 at 9:43 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    And sewer rat may taste like pumpkin pie, but I'll never know because...
  16. Feb 10, 2022 at 9:55 AM
    nodak67
    nodak67 New Member
    JR
    well be happy you can still somewhat easily still change your oil yourself. i am expecting in the future they will go the same route as the transmission setup and add some inconvenience for the average joe to change the oil.
    at my age, i'd rather just take it in to a place i trust and let them do in under 30mins and be done with it. dont have to deal with used crap afterwards.
    oil change in my 14 4runner is like $90. i could probably do it for under $50 in the summer by myself in about 1-2 hrs but then the long term cost of the setup to do an oil change, i would have to take a few years to recoup the initial cost. and lets not even talk about winters in ND and trying to change your oil unless you have heated and proper garage to do it in.
    at my age in the 50's i dont have the gumption to care to do oil changes anymore. i have better things to worry about :)
    like grand kids.
  17. Feb 10, 2022 at 10:05 AM
    mass-hole
    Thats what a Fumoto valve is for. Just hook a hose onto it and drain the oil straight into an empty oil jug. No mess, no fuss.
    At least with my F150, I can just slide under without lifting it off the ground, drain the oil, and be done in 30 minutes or less. Its half the time that it would take me to drive to a "trusted" place and back. And I know its done right with good oil.
    Hadelson, Ericsopa and JLS in WA like this.
  18. Feb 10, 2022 at 10:29 AM
    nodak67
    nodak67 New Member
    JR
    and you forgot the time you had to go get the oil, filter and dispose of the waste. so you did that in less than 30 mins? good for you. personally i couldnt give .02 for the satisfaction of doing it myself. i have better things to worry about. and at the rate i put 10k on vehicle, thats at most 2 oils changes a year, even less on the tundra as we only get about 7-8k per year on it. and before you go spouting off that i should change my oil more often. meh, been doing 1-2 oil changes a year for 20yrs and i've yet to have any issues with any of my toyota's. working toward 9yrs on the 4runner and i am still on my oem brake pads, trans oil, brake fluid and spark plugs. last year had the 3 diffs and chemical flushed the cooling system. i might get around to having someone change the trans oil and spark plugs or brake fluid but meh, not sure if i want to keep it past 2023.
    i just drop the vehicle off and come back in the afternoon to pick it up. again i have better things to do than having the satisfaction of doing something that i couldnt give .02 about.
    but more power to you and your satisfaction of telling people you changed your oil yourself. no one gives a crap about that. i learn a long time ago a lot of the stuff we think matters really doesnt matter except to the person doing it.
    Doxiedad and 17inferno like this.
  19. Feb 10, 2022 at 10:35 AM
    #49
    MadMaxCanon
    Boy are you on the wrong forum lol
  20. Feb 10, 2022 at 10:42 AM
    #50
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Gosh this thread devolved quickly.
  21. Feb 10, 2022 at 10:42 AM
    #51
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Oil threads never gets old... Wait for it..
  22. Feb 10, 2022 at 10:42 AM
    #52
    Ericsopa
    Ericsopa Old man and the sea
    Yeah, like 49 posts back.
  23. Feb 10, 2022 at 10:45 AM
    #53
    MadMaxCanon
    getting back to a topic we can all agree on, how does one fit 35's on a tundra without a BMC???? How awesome are tow hooks and a cool tranny?
    @hagrid please take us through the finer points of each topic.
  24. Feb 10, 2022 at 11:13 AM
    #54
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Lol...
    I'll just use the search function and post links for each topic... ten links per.
  25. Feb 10, 2022 at 11:32 AM
    #55
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I love how this thread has gone off the rails. It's made my day.
  26. Feb 10, 2022 at 11:36 AM
    #56
    What size of tires are the best choice when using synthetic oil such as Mobil 1?
  27. Feb 10, 2022 at 11:38 AM
    #57
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    LMFAO!!
    toyofan87 and Hbjeff like this.
  28. Feb 10, 2022 at 12:35 PM
    #58
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Lighten up Francis.
  29. Feb 10, 2022 at 12:36 PM
    #59
    JLS in WA
    Please post pics of your tire and oil setup.
  30. Feb 10, 2022 at 12:36 PM
    #60
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    And please, no pics of a cool tranny.
    Oey12 and Cpl_Punishment like this.
