Switch pros + Redarc dual battery setup w/ Genesis offroad battery tray
Discussion in 'Outdoors' started by 3mxdivr, Apr 7, 2019.
  1. Apr 7, 2019 at 4:58 PM
    3mxdivr
    3mxdivr [OP] New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Finally about 95% done with Redarc dual battery setup using their BCDC to charge the auxillary battery and an isolator just in case the primary needs a jump.
    + Switch pros install
    Process was tedious because:
    1. Had to make cables from scratch
    2. Organize Genesis battery tray
    3. Ran wires to all lights in the bed.
    4. Installation of Switch pros.
  2. Apr 7, 2019 at 5:43 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Nice job!
  3. Apr 7, 2019 at 5:49 PM
    3mxdivr
    NorCal
    Thanks bro. NORCAL meetup soon?
    GiantsFanDan[QUOTED] likes this.
  4. Apr 7, 2019 at 5:53 PM
    GiantsFanDan
    I'm up for getting some beers. What part of norcal you at?
    3mxdivr[QUOTED][OP] likes this.
  5. Apr 7, 2019 at 6:02 PM
    3mxdivr
    NorCal
    Sacramento.... always up for beers!
    As we speak.....
    Tundra Fan and GiantsFanDan like this.
  6. Apr 7, 2019 at 6:04 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Just looking at ur set up looks hard ass hell to install lol . Looks bad ass for sure tho.
    3mxdivr[OP] likes this.
  7. Apr 7, 2019 at 6:08 PM
    3mxdivr
    NorCal
    Thanks man. Personally, WAY harder than me installing anything. Ie suspension and mods. Just plain tedious and im kinda OCD.
    Like they say ..... Do it right the first time.
  8. Apr 7, 2019 at 6:50 PM
    -G-
    -G- New Member
    Grayson
    Philly 'Burbs
    2021 Cavalry Blue
    Looks great - your OCD served your well :)
  9. Apr 24, 2019 at 10:27 AM
    Baconchief40
    Baconchief40 New Member
    2018 White tundra Limited
    I’m looking to do this exact set up. About how much did it cost if you don’t mind me asking?
  10. Apr 24, 2019 at 10:56 AM
    FISHLIPWASHINTON
    FISHLIPWASHINTON New Member
    2007 CM
    2007 CM 4X4 ALPINE EQ BACKUP LIGHTS LED JL 1000/1MONO BLOCK. 2 10IN JL 450/4 MIDS & HIGHS FOX COILOVERS & BILSTEIN REARS DEZ'S SABM MAGNAFLOW 7031 PROCOMP 35x12.50x18 AMG Battery BUSHWACKER PAINTED FENDER FLARES
    X2 for pricing i want it too!!! Lol
  11. Apr 24, 2019 at 1:52 PM
    3mxdivr
    NorCal
    Redarc BCDC = $370
    Redarc SBI (isolator) = $110
    Redarc Dual Voltage Gauge = $182
    Redarc Mounting Cup = $41
    Redarc Hall Effect Sensor = $99
    Genesis Tray = $199
    Odyssey Battery x2 = $600
    Fuses and Fuse Holders = $70
    Wiring = $70
    Miscellaneous parts = $100
    Redarc Dual Battery setup rough TOTAL = $1841.00
    aperezsh likes this.
  12. Apr 24, 2019 at 2:12 PM
    FISHLIPWASHINTON
    2007 CM
  13. Apr 24, 2019 at 2:18 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    Thanks for sharing this. Originally I wanted to go this route, but I knew I wouldn't be able to do such a clean job. Went a different route with a separate battery and REDARC controller in the bed. Cost about the same minus the SP.
  14. Apr 24, 2019 at 3:22 PM
    3mxdivr
    NorCal
    Yup, very tedious because the genesis tray was a real tight fit w/ the 18+ LED headlights. That total above was just for the dual battery part, the switch pros parts & needed parts was another story. but the most time was spent figuring out how to stack equipment/parts on that genesis tray. + didn't want anything more on the bed since it gets packed camping
  15. Sep 12, 2019 at 2:30 PM
    offroadnewbie
    offroadnewbie New Member
    Chad
    2019 Toyota Tundra CM SR5 TRDSport 4x4
    ARE camper top, Cargo Bed Slide
    Hi Guys, new to this forum. I am slowly building out an over landing Tundra this year and want to start with the inside before I beef up the outside. I am torn between the dual battery system using either Genesis setup or Redarc Battery Manager 30. I came across this post and was curious why you went with the Genesis and just the REDARC battery charger? From what I have been researching it looks like I may want to run the REDARC BMS 30 to a Battle Born Lithium Battery and put both of these in the bed of the truck. Im building the entire bed out as well so it will not just be flopping around back there. Just trying to get your thoughts on your system
    3mxdivr ? I am a complete rookie at this and it looks like you did a great job on your install. I will be running the ARB 65 qt fridge, I will have a winch, light bars, inside lights, pure sin inverter, and charging phone, laptop, and iPad constantly.
  16. Sep 13, 2019 at 2:41 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    @3mxdivr Do you have a better picture of the gauge on your console and what mount you used? I was thinking of mounting a gauge there and was looking for a mount.
  17. Oct 29, 2019 at 11:55 AM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    How was the install on the victory bed side molle grid? for your propane tank are you using the mount from power tank? Set is nice, i'm looking to get the victory bed side molle grid and mount my power tank and propane
  18. Oct 29, 2019 at 12:04 PM
    Sunnier
    Sunny
    San Diego, CA
    I saw you never got a response and only posted one time. If you do what you described, please post a thread. I too am thinking I’d maybe rather power with a lithium ion batter than run a dual batter system. Please hit me up (tag me by typing “@“ and “Sunnier” with no space between) if you do. Thanks!
  19. Oct 29, 2019 at 12:42 PM
    offroadnewbie
    Chad
    I did get stage one complete, which is putting it all together and working. I'm deciding how to redo the box that I have it incorporated in. I will have to take some pictures to post. @Sunnier
    Sunnier likes this.
  20. Oct 29, 2019 at 1:04 PM
    Sunnier
    Sunny
    San Diego, CA
    Awesome, thanks!!
    Do you know how to start a new thread, so we don’t completely hijack this one?
  21. Oct 29, 2019 at 4:24 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    :bowdown:
    Nice job :thumbsup:
