Switch Pros 9100 Install
Discussion in 'Lighting' started by matictundra, Jun 10, 2019.
  1. Jun 10, 2019 at 1:49 PM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Do you need a fuse on each switch when hooked up?
  2. Jun 10, 2019 at 2:10 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    If I’m not mistaken no.
  3. Jun 10, 2019 at 2:22 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    No, overload protection is built into the unit for each output. Using the app you program the current value for each output
    matictundra[OP] likes this.
  4. Jun 10, 2019 at 2:26 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I don't currently have a pic, but I bought the SDHQ mount for my 9100. Can't see doing it any other way. It mounts to the side of the driver's side headlight. It's out of the way, but easy to access.
    Erichudgins and Pinay like this.
  5. Jul 9, 2019 at 5:36 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    I’m doing mine Friday. Looks good!
    Pinay[QUOTED] likes this.
  6. Jul 9, 2019 at 5:38 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thanks! I’m contemplating upgrades to more Baja Designs and ditch lights, waiting to get bumpers so fogs can be done, maybe all at once.
    Porschetech29 likes this.
  7. Jul 9, 2019 at 5:43 PM
    fundra_goes_west
    Evan
    2022 SQ8
    Nice. I’m mounting the ditch lights at the same time. Will do lights on my bed rack, and the C4 bumper once it comes out.
  8. Jul 10, 2019 at 10:04 AM
    matictundra
    Franco
    AZ
    I made a custom panel switch mount for my 9100 that goes onto to overhead center console. I still have full access to the sunglasses holder. Also, I mounted the the power module on the passenger fender well and designed a terminal junction box, hope to have the 3D printed completed this week, but I have the whole system pre-wired and functional.
  9. Jul 10, 2019 at 10:15 AM
    Matthewkort
    Matthewkort New Member
    I want to see more of this rack setup, been thinking of doing a rack and awning.. thanks!
  10. Jul 10, 2019 at 10:34 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    That looks awesome!!!
  11. Jul 10, 2019 at 10:39 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    And then I relocated it to passenger side...
  12. Jul 14, 2019 at 11:56 PM
    matictundra
    Franco
    AZ
    Cleaned up my wiring after 3D printed terminal panel was completed and installed. Now just waiting for revised 3D Printed cover.
  13. Jul 16, 2019 at 2:09 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Nice. Super clean install. Where did you pull the signal for the ignition and illumination @matictundra ?
  14. Jul 16, 2019 at 3:38 PM
    matictundra
    Franco
    AZ
    For ignition, I use the tap a fused in the ignition fuse in the engine bay. Illumination, I tapped into the parking lights. For trigger1, which can be programmed to turn on up to 4 switches, I used the fog since I no longer have one.
    aperezsh likes this.
  15. Jul 22, 2019 at 10:13 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Got my switch pro put in yesterday. SDHQ mount under the hood and in the cab. I ran through the firewall using the nipple on the drivers side under the main wiring harness.
    I also disassembled the main entry into the fuse box to add my wires for the switch pro. I went around the battery, under the fuse box then followed the main harness in.
  16. Jul 23, 2019 at 11:02 AM
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    2016 White Tundra TRD Pro
    Fab Four front/rear bumpers, Warn VR12S
    SDHQ has a nice vertical mounting plate that goes in front of the battery.
  17. Jul 23, 2019 at 11:11 AM
    matictundra
    Franco
    AZ
    The driver side of the engine bay is already crowded. That's why I mounted it to the other side.
  18. Jul 23, 2019 at 11:23 AM
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    There is a small recess in there for this application.
  19. Jul 27, 2019 at 9:20 AM
    #49
    NomadsLand
    NomadsLand The 719
    TS
    Future Tundra
    Some of these installs are really clean! Thanks for posting up pics as it definitely gives me an idea when I start my install.
  20. Aug 13, 2019 at 9:07 AM
    #50
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    so where do we put our order in lol
  21. Aug 13, 2019 at 9:24 AM
    #51
    fusion94
    fusion94 Just some dude...
    Tony
    Half Moon Bay, California
    2015 Barcelona Red Tundra CM SR5 5.7L 4x4
    @matictundra
    I'd love to get the STL or raw file for printing/future editing/modifications. I have a few 3d printers setup in my workshop at home and help manage the MakerSpace at work.
  22. Aug 26, 2019 at 8:28 AM
    #52
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    What are the three add a fuses for? And what fuses locations did you use?
  23. Aug 26, 2019 at 10:00 AM
    #53
    shellshock
    Iowa
    2019 TRD PRO
    They are for control of the switch pro. Much Easier and cleaner than tapping wires.
    Ignition (INJ) - Blue (Ignition)
    Lights (H-LP RH-LO) - White (Lights)
    High beams (h-LP LH-HI) - Pink (trigger wire)
    *** I believe these fuse names are correct. I used the same as on my tacoma. ***
    diablodalton and kkim124 like this.
  24. Sep 3, 2019 at 5:49 PM
    #54
    MMichaelJJ
    14 Platinum CM
    Anyone remove the wires from the 4 wire molex connector for controller? I can’t get the wires released, even after reading the instructions.
  25. Sep 10, 2019 at 8:48 PM
    #55
    mountainpanda
    mountainpanda New Member
    2016 Super White SR5 TRD 4x4
    How do I get one of these, I have a bench seat so I don’t have all the cool mounting options.
    Sunnier and fisherman951 like this.
  26. Sep 10, 2019 at 10:27 PM
    #56
    fisherman951
    Tony
    2017 crewmax 4x4
    Good luck with that I’ve been searching as I have a 6 seater but no luck. SDHQ said that are willing to make one but they need a truck and well I’m no where close to AZ.
  27. Sep 10, 2019 at 11:13 PM
    #57
    MMichaelJJ
    14 Platinum CM
    What overhead console do you have? If you have the flip down card version this is an option.
    Photo is from blue.streak.tundra on IG
    diablodalton and aperezsh like this.
  28. Sep 10, 2019 at 11:28 PM
    #58
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    love the headliner too!
  29. Sep 11, 2019 at 7:08 AM
    #59
    mountainpanda
    That's pretty cool but I don't have that console.
  30. Sep 11, 2019 at 2:18 PM
    #60
    matictundra
    Franco
    AZ
    Sorry, I only two of them through work, for me and bro. It is too expensive to machine when I got it quoted.
