Switch Pro-9100
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bohica_sob, Sep 6, 2018.
  1. Sep 6, 2018 at 12:20 PM
    Bohica_sob
    Bohica_sob [OP] New Member
    2014 Tundra
    So I have a problem with my switch pros. I can only get the switch to work if i use the app. They key pad will not work unless the app is connected through blue tooth. I wrote them an email an they responded with they have had problems with tundras not supplying the required 12 v to the switch. They suggested that I tie into a radio output. I used the fuse tap to tie into an ignition source under the hood. Does anyone else have this problem? If you remedied it please let me know how. Thank you
  2. Sep 6, 2018 at 12:39 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    I've had my 9100 since January with zero issues. Installed per their instructions. Only thing I changed was using this as my ignition fuse tap. Allows there to be a separate fuse for the tap while the original circuit retains it's own.
  3. Sep 6, 2018 at 12:53 PM
    Bohica_sob
    2014 Tundra
    I'm using that fuse tap as well. Do you have a pic of where you plugged it in under the hood?
  4. Sep 6, 2018 at 1:07 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i had this issue with mine. it was a power problem.
    https://www.tundras.com/threads/hmm-switchpros-not-turning-on.15450/#post-341148
    831Tun likes this.
  5. Sep 6, 2018 at 1:15 PM
    crochetjohn
    It's a slightly different one. The one that comes with the kit is not the low profile. I switched it to the low profile.
    I can get a pic later today.
  6. Sep 6, 2018 at 2:04 PM
    Bohica_sob
    2014 Tundra
    Thank you, I'll be looking for your pic later.
  7. Sep 6, 2018 at 5:33 PM
    Bohica_sob
    2014 Tundra
    This is where I plugged it in.
  8. Sep 6, 2018 at 5:37 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    if you follow the link i posted earlier, i describe the same problem and how i resolved it. i did not use the engine bay fuse box though. i used the one above the driver's side kick panel.
  9. Sep 7, 2018 at 3:24 PM
    crochetjohn
    So I see the problem. That last fuse slot is not on the bus. You won't get any power out of it. The fuse tap is to fall in line with an active 12v ignition. Put it into the 10 amp to the left of it and all will work.
  10. Sep 10, 2018 at 1:03 AM
    Bohica_sob
    2014 Tundra
    Thanks man, what's the blue fuse you have in the tap?
  11. Sep 10, 2018 at 5:24 AM
    crochetjohn
    The fuse tap I linked to Amazon lets you put a fuse per line. That way you can put the original 10 amp in place for ignition, then I have a 5 amp going to the switch pro. The ignition signal does not require a lot of amps. That fuse tap is also the low profile so it seats correctly.
    This is nothing wrong on switchpros part or what they provide. They produce a great kit that is beyond well equipped. Our trucks just happen to use low profile fuses and I like that tap better in place.
  12. Feb 9, 2019 at 4:18 PM
    2015TRD
    2015TRD New Member
    2015 Tundra SR5 TRD
    Where did you tap the white wire into the lighting circuit?
  13. Feb 11, 2019 at 6:32 PM
    crochetjohn
    The small running light in the corner of the headlight.
  14. Feb 11, 2019 at 6:42 PM
    2015TRD
    2015TRD New Member
    2015 Tundra SR5 TRD
    Thank you
    crochetjohn likes this.
  15. Feb 15, 2019 at 4:16 PM
    coTony
    Tony
    Montrose, CO
    Which light are you referring to? This is the last connection I need to make
