Switch panel lighting?
Discussion in 'Lighting' started by Sas, Jul 16, 2018.
  1. Jul 16, 2018 at 8:04 AM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Hey all, I'm sure this has got to exist somewhere, but maybe I'm just searching for the wrong thing because I'm not finding anything. The switch panel and center console area under the dash is pretty dark at night. Is there a lighting solution available that can better illuminate that area?
  2. Jul 17, 2018 at 7:56 AM
    Sas
    OKC, OK
    Well, since there are no replies to this I decided to snag a couple of lighting items to try and put something together. I ended out buying the 7" Lightning LED strip flexible LED strip and a black latching switch (both red). I can cut that strip down to less than 9" to fit in that space.
    https://gtrlighting.com/gtr-lighting-7-long-lightning-series-led-light-strip/ (this is currently on sale as of this post BTW)
    https://gtrlighting.com/gtr-lighting-12-flexible-led-strip/ (nixed the one above and went with this instead)
    https://gtrlighting.com/gtr-lighting-led-halo-switch-black-bezel-latching-switch/
    The (very loosely thought out) plan is to stick the LED strip under the dash on the switch panel housing and install the button on the panel itself somewhere. I've ordered those new 2018 bi-LED headlights and the NSV hood bulge light bar that comes w/its own panel, so I'll wire this stuff in when I do those upgrades.
    Not sure where a constant power source would be that I could tap into though. I was thinking the cigarette lighter initially. Anyone have a better idea?
  3. Jul 17, 2018 at 9:39 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Just a heads up on those lightning led. I got 2 free as a black Friday deal which were damaged due to tiny wires were broke. Yes they sent 2 new ones. They are too bright for switch panel lights. I ended up using 4 of them as bed lights.
    Sas[QUOTED][OP] and parker44 like this.
  4. Jul 17, 2018 at 9:43 AM
    Sas
    OKC, OK
    Thanks, I was wondering about that. I figured I would use them elsewhere, but I may just cancel the order and just grab their LED strip instead.
  5. Jul 17, 2018 at 10:46 AM
    Grizzly660
    North Dakota
    The other option I was going to use them for was to wire them into the door light on so they would act as a puddle light and mount them under the door between my running boards. However the wiring is so small on them I didn't think they would hold up
  6. Jul 17, 2018 at 12:36 PM
    Sas
    OKC, OK
    Puddle light would be interesting. That's a mod I briefly kicked around, but wasn't sure what I was going to do with the mirrors so I put it on the back-burner. Might have to revisit these lights again if I end out doing that mod. Incidentally I canceled my original order and went with the flex LED strip I also linked above. It's not quite as clean, but where it'll be located will make it hard to see, if it's seen at all.
  7. Jul 18, 2018 at 9:10 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I used one of these to light the panel under the radio and one to light the inside of the console. They are a lot brighter than you would expect them to be, I had to add a couple resistors to dim them down to keep them from being blinding at night.
    https://www.amazon.com/gp/product/B01AFU4QD6/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
  8. Jul 18, 2018 at 9:15 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Here's a pic of where I mounted the led and you'll get an idea of just how small it is. And yes, I know it's in serious need of a cleaning, but I haven't had a day off in 2 weeks.
    Sas[OP] likes this.
  9. Jul 18, 2018 at 9:20 PM
    Sas
    OKC, OK
    Good choice on location. That's pretty impressive light output for such a little LED. Did you put a switch to it or is it always on?
    ... incidentally, I'm totally judging you now based upon your cleanliness.
  10. Jul 18, 2018 at 9:26 PM
    Cuzican
    Cuzican New Member
    Louisiana
    It is wired to an ignition 12v, actually I tapped into the power and ground wires to the 12v socket inside the console, so it's on any time the ignition is on. The 12v socket wires were just the easiest wires to access, since they were right there when I took the top of the console off to install the LED. If you think it's bright now, you should have seen it before I dimmed it down.
    Also I just double checked and I forgot that I used a different led light that I already had inside the console. The light inside the console is one of these and it did not need a resistor to dim it down.
    https://www.amazon.com/dp/B076SDCJ1...olid=1Q5LXDATMSB6A&psc=0&ref_=lv_ov_lig_dp_it
    Sas[OP] likes this.
  11. Jul 18, 2018 at 9:29 PM
    Sas
    OKC, OK
    Nice, I've been thinking about doing a lighted console when the lid is lifted. Those may work perfectly.
  12. Jul 18, 2018 at 9:31 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Those 2 places missing light, drove me nuts the first time I drove the truck at night and I knew I just had to do something about it.
  13. Jul 18, 2018 at 9:34 PM
    Cuzican
    Cuzican New Member
    Louisiana
    831Tun likes this.
  14. Jul 18, 2018 at 9:35 PM
    Sas
    OKC, OK
    Yep, right there w/ya. It was literally the first night I had it that I knew those areas were getting lights lol.
  15. Jul 18, 2018 at 9:38 PM
    Sas
    OKC, OK
    There's a lot of little niggly things like that that really need to be lighted IMHO. I'll probably end out snagging some interior parts from a junkyard and tinker around at some point.
    831Tun likes this.
  16. Jul 18, 2018 at 9:47 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Sas[OP] and nk1794 like this.
  17. Jul 18, 2018 at 9:52 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I saw those, but they're not exactly what I want. I actually still have another one of the small LEDs that I used in the front of my console, that I had bought for that spot, but it's the angle of the surface above the switch that is the problem. The area where he mounted his LEDs is where I was gonna mount it, but the angle aims the light more towards my knee than the switch. I don't want to see the actual light, just the glow from it.
  18. Jul 18, 2018 at 10:01 PM
    Sas
    OKC, OK
    I'm actually looking for a shielded light bar that won't obstruct what I'm reaching for just for that exact reason.
  19. Jul 18, 2018 at 10:02 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I was worried about the angle as well but with the right LED it’s not an issue for me. The LED that I found (on my 3rd video) really did the trick. It’s bright enough to see all the buttons clearly but not bright enough to get into my eyes while driving. After driving around with it for a few days/nights I can say that I’m really happy with the way it turned out.
    Sas[OP] likes this.
  20. Jul 18, 2018 at 10:29 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  21. Jul 19, 2018 at 3:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Yup something similar. Still like it. Let’s me see my mirror switch at night. That one looks hella bright tho!
    831Tun[QUOTED] likes this.
  22. Jul 21, 2018 at 1:48 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Well, my LEDs came in today for my mirror switch, took about an hour start to finish, but I got the look I was after. I drilled a small hole in the panel to be able to hide the LED out of sight and angle it straight down, instead of at my knee. The LED was still brighter than I wanted, so I added. 1/2 watt 1K ohm resistor to dim it down.
    NewImprovedRon and Sas[OP] like this.
  23. Jul 21, 2018 at 7:44 PM
    Cuzican
    Cuzican New Member
    Louisiana
    At night, mirror switch and console switch panel lit up.
  24. Sep 1, 2018 at 9:16 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Are these ^^^ the lights you used in the pics below? I like them. I wanna do some in those same spots.
    @BlueBottle what did you use?
  25. Sep 1, 2018 at 9:20 PM
    Pudge
    CT
  26. Sep 1, 2018 at 9:33 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I used one of those for the mirror switch, I used one of these for the the front of the console/usb/power port area.
    Pudge[QUOTED] likes this.
  27. Sep 1, 2018 at 9:33 PM
    Pudge
    CT
  28. Sep 1, 2018 at 9:36 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Both were brighter than I wanted, so I had to add a 1/2 watt 1k resistor to each to dim them down.
  29. Sep 1, 2018 at 9:51 PM
    Pudge
    CT
    Thanks for that tip. I have never wired resistors or even bought them. Is it ok if I hit you up with a PM when the time comes for me to do this?
  30. Sep 1, 2018 at 9:54 PM
    Cuzican
    Cuzican New Member
    Louisiana
    This should answer any questions you may have.
    https://youtu.be/ID_KC9fC3rc
