Switch Help Please
Discussion in 'Lighting' started by zlaneb, Jan 25, 2018.
  1. Jan 25, 2018 at 7:14 PM
    zlaneb
    zlaneb [OP] New Member
    Austin, TX
    Guys-
    I'm looking for a back-lighted switch for to use with a rigid light bar. I want to use the blank spot next to the "Tow/Haul switch to install it. I'm finding tons of types/kinds. Can anyone point me in the right direction? I've ben to OTRATTW and other sights, but so many options!
    Thanks
    Z.
  2. Jan 25, 2018 at 7:24 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  3. Jan 25, 2018 at 9:54 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Check out AirOnBoard. They have switches specifically for the Tundra, excellent quality and tons of options.
  4. Jan 27, 2018 at 5:50 AM
    zlaneb
    Austin, TX
    Thanks guys - I'm just learning about switches. It is a bit more complicated then "Do I want a toggle or rocker"? I know I need a switch that is rated for the amps, and learning about single/double throws ect.
    For example - I want to change out my TC switch to something that is customized (Maybe have it say "Beast Mode"). I guess I could pull the switch and try to figure it out.
  5. Jan 27, 2018 at 6:16 AM
    zlaneb
    Austin, TX
    Thanks Sir!
    Watt maker likes this.
  6. Jan 27, 2018 at 6:28 AM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    :thumbsup:
  7. Jan 27, 2018 at 6:47 AM
    zlaneb
    Austin, TX
    Thanks Jersey - those are push button, could you have used rockers?(SPST)??
  8. Jan 27, 2018 at 6:54 AM
    zlaneb
    Austin, TX
    Can anyone tell me if my thinking is correct - the Trac Control switch is a simple push button, and although there are different action the switch takes, those actions are controlled by holding the switch in to apply power to the trac control computer in the truck?
  9. Jan 27, 2018 at 6:54 AM
    JerseyTundra1260
    Marc
    New Jersey
    They are push.... These switches are an exact fit. Some of the others on Amazon and so forth are bigger. I wanted the so called factory look. You can customize as well.
  10. Jan 27, 2018 at 7:13 AM
    SATX_ProRunner
    SATX_ProRunner New to forum, not new to tundras
    2018 Blazing Blue 1794 4X4 ProRunner
    Still in progress
    I’ve seen a lot of write ups on this topic lately and curious on feedback on both SPOD and Switch-Pro. Looking for pro and cons of each. I love the set up from sdhq with the switch pro. Curious if you could get a similar setup with a SPOD would you do it.
    @BlueBottle i’d love to hear your thoughts.
  11. Jan 27, 2018 at 9:29 AM
    zlaneb
    Austin, TX
    OK - 4 hours into this process I"m back to a question - the tow/haul and TC switches - are they push button or momentary??
  12. Jan 27, 2018 at 12:46 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Momentary
    zlaneb[QUOTED][OP] likes this.
  13. Jan 27, 2018 at 5:16 PM
    zlaneb
    Austin, TX
    Thanks BB! Onward through the fog!
  14. Jan 27, 2018 at 6:34 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Push button locking for tow haul. If it was momentary then tow haul would turn off when you took finger off. Momentary only works when depressed and held. I used a Mictuning left of steering wheel for my light bars. Prefer push button over rocker. Fit is perfect.
    zlaneb[OP] likes this.
  15. Jan 29, 2018 at 6:05 PM
    zlaneb
    Austin, TX
    how can i test if a switch is momentary or locking?
  16. Jan 29, 2018 at 6:20 PM
    Rustynutz
    Rustynutz New Member
    Russell
    Louisiana
    2015 Tundra Limited 4X4
    6" Rough Country lift on 35" Toyo Open Country MT's on Moto Metal MO970's, 30 inch grille led bar, rear bumper mounted cube leds, rocklights, stereo upgrade, bed Backflip, dual exhaust
    Ditto on Air on Board or Mictuning switches. They have several colors and logo designs to fit stock Toyota switch holes.
  17. Jan 30, 2018 at 3:28 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Easy, push it and if it locks on on position it is not momentary. Momentary switches are used in apps like boat tilt and trim where you only want power when holding the switch in on position. Would not want for lights unless you want to hold switch to operate them.
  18. Jan 30, 2018 at 8:05 PM
    zlaneb
    Austin, TX
    Thanks man, that makes sense on lights. But for other functions on the truck like Tow/Haull VSC then it is not quite as obvious...
