Switch blade key fob
Discussion in 'General Tundra Discussion' started by Shanejum, Sep 19, 2016.
  1. Sep 28, 2018 at 10:06 AM
    #61
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Bumping old thread. I want to do this and just wondering if those that did, is it still working for them.
  2. Sep 28, 2018 at 10:15 AM
    #62
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Yes mine works but haven't been using it. My whole reason was to use it for all in one but I can't program the fob with my aftermarket remote start so I am debating on getting the This remote start that retains the factory fobs to start. So I can use the switchblade
    https://shop.tech12volts.com/product.sc?productId=537&categoryId=59
  3. Sep 28, 2018 at 11:06 AM
    #63
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Nice.
  4. Sep 28, 2018 at 11:15 AM
    #64
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Mine still working just fine.
  5. Sep 28, 2018 at 12:09 PM
    #65
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    Yours works with the switchblade key?
  6. Sep 28, 2018 at 12:36 PM
    #66
    4Runner
    4Runner New Member
    Columbia, SC
    Yes. No issues at all.
  7. Sep 28, 2018 at 12:48 PM
    #67
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Sweet! Now to find a locksmith.
  8. Sep 28, 2018 at 1:02 PM
    #68
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I bought a blank switchblade key off ebay that didn't have the chip and ordered an H chip (for 2018+) separately for it. Had it cut at homedepot, and programmed it myself using obdII cable and software off of ebay.
    #68
  9. Oct 14, 2018 at 8:05 PM
    #69
    TTCrewmax
    TTCrewmax New Member
    So I just pulled the trigger on this - https://www.ebay.com/itm/1126236596...il&pgrp=main:email&e=op&mchn=em&s=ci&mail=sys
    I'm assuming after watching this - https://www.youtube.com/watch?v=MRg8til2TVk - that I won't need to go to a locksmith or dealer to program the chip in the key. Sounds like the biggest problem is finding someone that will cut the key to match?
    Anyone with a pre '10 Tundra been able to program the chip in the key themselves or did everyone go to a locksmith/dealer to make this key work?
    Thanks!
    #69
  10. Mar 21, 2019 at 2:58 PM
    #70
    magnum23
    magnum23 New Member
    2019 Cav Blue Tundra Off Road
    Sorry to bump this old tread, Anybody have found a blade key-fob, for an H key for Tundra 2019 and sucessfully program it DiY??
  11. May 24, 2019 at 6:01 AM
    #71
    Danezu
    Danezu New Member
    2016 Toyo Tundra SR5
    Does anyone have been using this type of key for a good period of time? Wandering if still working. I heard they may go bad after few months.
  12. May 24, 2019 at 6:20 AM
    #72
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    Mine has been working for two maybe three years. I use it everyday
  13. May 24, 2019 at 6:58 AM
    #73
    Danezu
    Danezu New Member
    Thanks. Do you remember which key was and where you got it from?
  14. May 24, 2019 at 11:32 AM
    #74
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    Petty sure got the one shipped from Taiwan
  15. Jul 8, 2019 at 5:05 PM
    #75
    tbickle77
    tbickle77 New Member
    Tom
    2013 Tundra Rock Warrior
    Step bars, Line-X, E-Track, Motorcycle Wheel Chock Bar, Bug Guard
    Re-opening this thread. I'm a new Tundra owner and got the switchblade key fob key cut, and have the TechStream on its way (arrives today). Does anyone know how to program the lock/unlock on the key fob? I tried the open/close door and insert/remove key method... and the turn the key to "On" 7 times method and neither worked. It is a 2013 Tundra ("Rock Warrior"). Any help would be appreciated! Thanks!!
  16. Jul 8, 2019 at 5:27 PM
    #76
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    This is also done with techstream.
  17. Oct 6, 2019 at 1:13 PM
    #77
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
  18. Oct 18, 2019 at 2:47 PM
    #78
    spyshot
    Ohio
    Just moved the parts over and cut the key today and it works great. I even managed to keep the original key in near perfect shape in case I need to switch back.
  19. Mar 16, 2020 at 11:26 PM
    #79
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Bumping old thread. What remote start do you have? I have a compustar that has a completely different fob, wondering if this would change anything if I can get it cut and programmed.
    ccdawnpatrol likes this.
  20. Mar 20, 2020 at 6:49 AM
    #80
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
  21. Apr 11, 2021 at 7:12 AM
    #81
    AMO_Tundra
    AMO_Tundra New Member
    TJ
    Hernando, MS
    2017 Super White Tundra Crewmax
    SDHQ Dual Battery System FRAC Harness Tacoma TRD Manual Shifter Mod w/Boot Diamondback SE Cover Front Runner Bed Rack Engine Mounted ARB Compressor Raptor Grille Light Mod 3wlines Power Window Mod Color Matched Door Handles Color Matched Mirror Caps
    How do you program the key fob with tech stream? I got the key programmed but where do I go for the fob?
  22. Apr 11, 2021 at 4:36 PM
    #82
    Ericsopa
    Ericsopa Old man and the sea
    Sorry man, it's been over three years ago. Techstream is on my other laptop, so I can't access it right now. It's in there somewhere, and many have done it, so maybe someone else can chime in.
  23. Apr 11, 2021 at 6:31 PM
    #83
    AMO_Tundra
    TJ
    Hernando, MS
    No problem thanks for the reply, I figured it out I got it programmed. Thanks
