Sway bars
Discussion in '2.5 Gen Tundras (2014-2021)' started by dunleav1, May 7, 2018.
  1. May 7, 2018 at 3:00 PM
    dunleav1
    dunleav1 [OP] New Member
    I am thinking about picking up a rear sway bar. My truck is a 2018 limited Tundra with no lift.
    I like the looks of the Hellwig sway bar over the TRD.
    The Hellwig has a two offerings one for stock height and one for 2-4” of lift.
    I may get a 3” lift in 6 months. The Hellwig is supposed to be adjustable. How is it adjustable and which one should I order?
    Thanks,
    JD
    Prostar 190 likes this.
  2. May 7, 2018 at 3:06 PM
  3. May 7, 2018 at 6:22 PM
    It is adjustable in the linkage here's a picture.
    4x4_Angel, ColoradoTJ, 71_340 and 5 others like this.
  4. May 7, 2018 at 6:25 PM
    You can also move the linkage between 3 different mounting holes on the sway bar it's self for a more stiff ride.
    1UPPER likes this.
  5. May 7, 2018 at 7:05 PM
    TheBeast The Beach
    that's a big block you got there. how is the ride ?
  6. May 7, 2018 at 7:11 PM
    dunleav1
    Ok, thanks for responding. Are you using the standard sway bar (7692) and not the one for lifted trucks (7889)?
    I want to make sure the sway bar I install now when I don't have a lift, will work if I put 1 3" lift on later.
  7. May 7, 2018 at 7:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Just an FYI. The TRD sway will work on a 3" lift. It just angle up.
    Challenger1 likes this.
  8. May 7, 2018 at 7:21 PM
    dunleav1
    Ok
    Ok. I’ve seen a few builds using the trd sway bar on lifted trucks. I just don’t dig the red.
    4x4_Angel and 831Tun[QUOTED] like this.
  9. May 7, 2018 at 7:45 PM
    Ride is good!
    TheBeast[QUOTED] likes this.
  10. May 7, 2018 at 7:45 PM
    It's the 7889.
  11. May 7, 2018 at 8:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Looks like the Helwig has more to offer. I've seen lots of painted sway bars. You just gotta get whichever one makes you happy.
    TheBeast and Prostar 190 like this.
  12. May 8, 2018 at 4:17 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is one stout looking sway bar, nice!
  13. May 8, 2018 at 7:11 AM
    dunleav1
    Has anyone used the 7692 with 3” lift?
    Or has anyone used the 7889 with no lift?
  14. May 8, 2018 at 11:21 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    I love the TRD sway bar.. makes the ride smoother and the truck isnt a boat for DD..
    Quick unbolt when going off road.
    JoshuaA likes this.
  15. May 8, 2018 at 1:58 PM
    15whtrd
    15whtrd Mr. Blonde
    Do you unbolt the entire sway bar or do you just do the links. If so what do you do to tie it up and out-of-the-way.
  16. May 8, 2018 at 4:38 PM
    Challenger1
    Andy
    I remove completely. very simple.. only a few bolts.
    15whtrd[QUOTED] likes this.
