Sway bar rubbing 6112s
Discussion in 'General Tundra Discussion' started by centxyota, Nov 19, 2020.
  1. Nov 19, 2020 at 8:00 PM
    centxyota
    centxyota [OP] New Member
    2018 White Tundra Limited 4x4
    Bilstien 6112s and 5160s, Ranch Hand Grill Guard
    Hey guys, new to the forum with a question I can't find the answer to anywhere.
    I recently had 6112s put on my 2018 limited 4x4. The shop that put them on did a terrible job on the alignment the first time they did it, took it back and had them redo it, and they got it closer. Knowing they had issues doing what should have been an easy alignment I am worried they didn't put the bilstiens on right.
    My sway bar ends are rubbing both struts. I don't hear anything making noise, but as you can see below they definitely look like they are rubbing. Obviously this isn't great. I thought about removing the sway bar, but I run a lot of highway miles and would rather keep it. Anybody had this issue and fixed it? should I get another alignment? Attached are my alignment specs.
    Rica25 likes this.
  2. Nov 19, 2020 at 8:26 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Welcome to the forum! Are yoiu sure they are not hitting the tie rod? Looks like its touching in the photo
    Rica25 and centxyota[OP] like this.
  3. Nov 19, 2020 at 8:30 PM
    centxyota
    yea it does look like that from that angle.. they are close to the tie rod but if they are hitting.. its not often. I took these after miles of bumpy dirt roads so they may have hit a few times. The sway bar is leaving grease on the shock though.. I wiped it off to see if it was a one time thing and it came back
  4. Nov 19, 2020 at 8:37 PM
    Tundyfundy
    Bay Area, CA
    It looks like your end links are leaking grease. You can see it all over the end of the sway bar. Id say its not necessarily hitting but may be. Ive got he 6112's and Mine don't hit. Hopefully somebody can chime in about your alignment numbers
    centxyota[OP] likes this.
  5. Nov 19, 2020 at 8:44 PM
    centxyota
    that's a good thought.. I assumed they were hitting because the grease keeps coming back but its possible its just blowing on there or something. Like I said I don't hear any noice when I drive over bumps and stuff.
    Mine are at the 1.9 setting because I wanted to keep it as close to stock as possible to avoid issues while gaining some clearance. I'm kinda hoping its an alignment issue at this point.
    Tundyfundy likes this.
  6. Nov 19, 2020 at 9:19 PM
    Tortuga83
    Tortuga83 New Member
    Tortuga
    Here is my 6112s setup. I compared the pictures to notice any differences. Other than the obvious I don’t see anything, don’t know if you do. 7357A37C-0A96-4C99-9FCE-69A17D3B2BF4.jpg1C2F0801-FDB1-49B2-907F-30F6EDDDE19C.jpg
    centxyota[QUOTED][OP] likes this.
  7. Nov 19, 2020 at 9:25 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum @centxyota
    Does it only look that close at full lock?
    Here is mine on my 2WD 2014..
    27C5334C-E17F-4296-8080-38F28356153D_zps_e4bc8eec8808248cd1648a6ac214ac93927bffd4.jpg
    Rica25 and centxyota[QUOTED][OP] like this.
  8. Nov 20, 2020 at 12:09 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Don't see how they'd mount them incorrectly. Really only one way they could be mounted.
    Do you see scratches or scrapes on the cylinder of the strut or just grease? Unless you see obvious contact marks I'd say its just the grease from your sway bar end links blowing onto the strut. The Bilsteins are a few mm bigger in diameter than the stock struts, but not enough to cause clearance issues I wouldn't think. Lot's of folks running them with no issues.
    Your tie rods do look closer than ones in the other pics, but could just be the angle.
    Maybe take a pressure washer to that whole front end and replace those end link bushings and then check it after putting some more miles on it and see if the condition still exists.
    1lowlife and centxyota[OP] like this.
  9. Nov 20, 2020 at 9:21 AM
    centxyota
    Guys,
    Good insight from all. Already glad I joined the forum.
    Upon closer examination this morning it does look like grease is just blowing onto the struts (or shocks? I forget). Until I see metal on metal I'll probably quit worrying about it. I am going to retorque the bolts on the sway bar to spec for my own peace of mind and quit worrying about it.
    I feel a lot better knowing others 6112s sit this close.
    Side note: I love this suspension. I had 5100s on my last truck and these are definitely a step up. I am able to take dirt roads much faster and the truck holds the ground much better.
    Rica25 likes this.
