Sway Bar Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Nov 23, 2020.
  1. Nov 23, 2020 at 1:00 PM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    Does Toyota have a TRD front sway bar for the 2017 Tundra?
  2. Nov 23, 2020 at 1:04 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Nov 23, 2020 at 1:07 PM
    rodl12
    Rod
    South Jersey
    Where? And would it be recommended with oversize tires?
  4. Nov 23, 2020 at 1:07 PM
    rodl12
    Rod
    South Jersey
    I've been able to find the rear but not the front.
  5. Nov 23, 2020 at 1:15 PM
    Saltyhero13
    I think this is the correct part #:
    PTR62-0C180
    I don't see why there would be any conflict, the dimensions of the stock sway is close if not identical to the TRD bar but someone else will need to definitely answer the tire issue as I'm still running stock tires.
    I know there is an issue with running the rear sway bar with a certain lift heights but that's not what you are asking.
  6. Nov 23, 2020 at 1:19 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I can confirm that they do. I have one on my 2017 Tundra. I think I got it from Sparks in South Carolina.\
    EDIT: this shows that a front TRD swayer is available. They will take your money. https://www.sparksparts.com/p-trd-sport-front-sway-bar-frsway
  7. Nov 23, 2020 at 1:19 PM
    rodl12
    Rod
    South Jersey
    I will be upgrading with Bilstein 6112's in the front and 5100's in the rear. So yes, I will be raising the truck.
  8. Nov 23, 2020 at 1:22 PM
    rodl12
    Rod
    South Jersey
    When I do a search on Sparks Toyota's webpage it says "This part does not fit your 2017 Toyota Tundra". I think that number is for 2018-2020.
  9. Nov 23, 2020 at 1:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
  10. Nov 23, 2020 at 1:47 PM
    tictac20
    tictac20 New Member
    I don’t mean to hijack the thread but thought I could ask another question here given the title. I am looking for bolts and spacers to attach the rear sway bar to the frame. I’ve only been able to find them as part of a hardware kit for 70 bucks. If you know where I can find just the bolts and spacers, or the size of the bolts and spacers so I could look for them online, I would greatly appreciate it. Thank you in advance.
  11. Nov 23, 2020 at 1:54 PM
    Saltyhero13
    tictac20 likes this.
  12. Nov 23, 2020 at 2:04 PM
    Saltyhero13
    Fitment: 2007-2019 Tundra - All models
  13. Nov 23, 2020 at 4:28 PM
    rodl12
    Rod
    South Jersey
    Okay, thanks for the help!
  14. Nov 24, 2020 at 10:13 AM
    tictac20
    tictac20 New Member
    Saltyhero13[QUOTED] likes this.
