Sway bar installed!
Discussion in '2.5 Gen Tundras (2014-2021)' started by BTBAKER, Dec 7, 2017.
  1. Dec 7, 2017 at 10:27 AM
    TheBeast The Beach
    no issues here either. cornering is much better.
    T500 likes this.
  2. Dec 7, 2017 at 10:55 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    It is basically your regional distribution center...mine is Gulf States for Texas as an example. Some of the bed LED lights, side steps, spray in bed liner, etc. are installed at the distribution center which is technically called a "Port".
  3. Dec 7, 2017 at 10:59 AM
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    You must travel 130 toll a lot...
    geno0506 and ChucklesToy[QUOTED] like this.
  4. Dec 7, 2017 at 11:02 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Yup and SH45...rough road
    JRPro[QUOTED] likes this.
  5. Dec 7, 2017 at 11:12 AM
    15whtrd
    15whtrd Mr. Blonde
    I find it weird that it would create more bed bounce being that it doesn’t limit up and down travel so much as it limits articulation.
    Not saying it isn’t so, just my thoughts.
    I swore it helped my truck when I did a before and after on a section of freeway. I do think it’s speed sensitive and now reacts differently at certain speeds. Having a load makes the most difference though.
    Good luck with whatever you do.
    BTBAKER[OP] likes this.
  6. Dec 7, 2017 at 11:15 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    The road is still rough and now I have more sway on exit ramps and fly over ramps, but I feel the bumps less for sure. I agree it is probably speed sensitive and definitely dependent on the section of road and how bumpy or how close together the bumps are.
    15whtrd likes this.
  7. Dec 7, 2017 at 11:25 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Thanks. It sucks. On the stretch that is bad speed doesn’t seem to make much of a difference. I will try somehow to post a video. I fly solo to work so I will do the best I can.
    If I knew if was just this stretch I would probably just try my best to avoid it.
    15whtrd[QUOTED] likes this.
  8. Dec 7, 2017 at 4:18 PM
    geno0506
    geno0506 New Member
    Michael
    I love that Toll road, Balls to the Wall and have yet to see a local or Trooper!
    ChucklesToy likes this.
  9. Dec 7, 2017 at 4:25 PM
    JRPro
    Rich
    Austin, TX
    Absolutely! I hover around 90, but I’ve seen triple digits a few times. Only stretch of road you can really air one out on around Austin. Found out my S5 had a governer on it and had no idea before.
    ChucklesToy and geno0506[QUOTED] like this.
  10. Dec 7, 2017 at 4:28 PM
    geno0506
    geno0506 New Member
    Michael
    Yep, hit 90's a lot and don't even notice it, love driving at night but defiantly careful of the hogs or deer!
  11. Dec 7, 2017 at 6:06 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    I love my TRD sway bar. Literally made a huge difference when towing. I never experienced what your saying about bed bounce but I love the control with weight in the back.
    15whtrd, NewImprovedRon and geno0506 like this.
  12. Dec 7, 2017 at 6:30 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Glad everyone likes it. I ripped mine off ten minutes ago. The stretches of concrete I live around make it an absolute no go!
    geno0506 likes this.
  13. Dec 7, 2017 at 6:42 PM
    geno0506
    geno0506 New Member
    Michael
    You must surely be the only one here that has that problem on concrete, I'm sure with a better suspension it may ride a bit better! Good luck!
    BlueBottle likes this.
  14. Dec 7, 2017 at 9:04 PM
    Stuffs
    Stuffs New Member
    Bummer you got that issue. No issue here on concrete highways. Its such a good mod because of the improvements in handling.
    The only thing I have different are 5100 in the rear instead of the OEM OR Bilsteins. The rebound was stout on the stock and the 5100 changed that...not sure if its enough to eliminate bed bounce tho..
    BTBAKER[OP] and geno0506 like this.
  15. Dec 7, 2017 at 9:24 PM
    geno0506
    geno0506 New Member
    Michael
    Right on! :thumbsup:
