Sway Bar End Links
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Apr 8, 2019.
  1. May 28, 2024 at 10:44 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I like my suspension Maxx links.
    Mine are designed for trucks with 2 inches of lift or more
    I don't think there's honestly a lot to them and several brands would suffice. Just be aware there is quite a variation between some thin little cheap ones with cheap bushings and some nice sturdy ones and those that are designed for trucks that are lifted
  2. May 28, 2024 at 10:46 AM
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    I looked on suspension maxx but they only has links for 2000-2006 I think. I have a 2014 Tundra.
    Weagle[QUOTED] likes this.
  3. May 28, 2024 at 10:48 AM
    Weagle
    Prattville, AL
    OK, I didn't notice your year model since this is a 1stgen forum.
  4. May 28, 2024 at 10:51 AM
    lukedias00
    Ooops, didn't see that. Apologies.
  5. May 28, 2024 at 11:59 AM
