Sway Bar drop kit needed?
Discussion in 'Suspension' started by gan, Aug 14, 2017.
  1. Aug 14, 2017 at 11:29 AM
    gan
    gan [OP] New Member
    Rgv Texas
    2021 Black Tundra Pro
    Is a sway bar drop kit needed a basic 3/1 spacer lift? I noticed most kits don't come with it and I was trying to find the source of a poping noise I had, found 2 loose bolts and tightened them and it appears to be the wheel spacers also causing noise. But now I am wondering if by adding the sway bar drop kit I caused the issue. Thoughts?
  2. Aug 14, 2017 at 11:44 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Won't be an issue. Most kits won't include a sway bar drop kit just to keep cost down.
  3. Aug 17, 2017 at 4:32 PM
    gan
    gan [OP] New Member
    Rgv Texas
    I removed my drop kit amd my pooping noise went away put wheel spacers backnon and so far no noise.
    NewImprovedRon likes this.
