Sway bar and lift kits
Discussion in 'General Tundra Discussion' started by birdslayer, Sep 25, 2017.
  1. Sep 25, 2017 at 2:52 PM
    birdslayer
    birdslayer [OP] New Member
    MARYLAND
    2018 DC SILVER SKY LIMITED TRD
    Not yet but scratches and dents are sure to come 3/1 TOYTEC LIFT, SPC UCA'S, EIBACH SHOCKS, EXTANG TRI FOLD TONNEAU COVER
    I am taking delivery on a 2018 TUNDRA DC limited w/ TRD offroad package. Can the TRD rear sway bar be retained with a lift kit?
  2. Sep 25, 2017 at 2:56 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    20170408_163635.jpg 7" lift
    Double Badass and Inquiringone like this.
  3. Sep 25, 2017 at 4:06 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you want to retain more of the functionality of your sway bar. You can have the end links extended. Here is a my swaybar after being extended for a 7" lift. I decided to have my TRD sway bar powder coated to match my wheels. It used to be red. IMG_4524.jpgIMG_4527.jpg
    Inquiringone, CJ21 and trayday like this.
  4. Sep 25, 2017 at 4:22 PM
    Why is the bar so high? All others I've seen are lower?
  5. Sep 25, 2017 at 4:24 PM
    1UPPER
    TEXAS
    Flux capacitor!
    He flipped the mounts. The sway bar is supposed to be mounted below the rear diff.
  6. Sep 25, 2017 at 4:26 PM
    I thought it was mounted wrong... I might not make Tundra meet in S.A. thought our group would be close to S.A. but were coming back to Big Spring Tx be too far
  7. Sep 25, 2017 at 4:38 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I've never seen anyone mount it reversed. Don't know if it's wrong or not effective. Typically the bar is mounted below.
    Hopefully you can make it to Random for a beer at least. Haha
  8. Sep 25, 2017 at 4:43 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Inquiringone likes this.
  9. Sep 25, 2017 at 4:44 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Stock length sway bar with the lift. Truck handles better than it did stock w/out the lift and sway bar. Rear end of the truck hasn't slid out unintentionally yet with the current setup.
  10. Sep 25, 2017 at 4:50 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Yeah I'm not sure if it's wrong but typically it's mounted below is all I'm saying. I'm sure it helps having it though.
  11. Sep 25, 2017 at 5:46 PM
    It's mounted wrong
    CJ21 likes this.
  12. Sep 25, 2017 at 7:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    It's not mounted the way the instructions say to, but that doesn't mean it's wrong. The way it's mounted doesn't make a difference in handling or effectiveness. @jberry813 explained it perfectly in another thread.
    IIRC, all the links act as is a lever, the bar itself, however attached, is fastened to the Axel. Since the axel doesn't move, but the attach points on the links (levers) do, it makes sense that unless you modify the links, the effectiveness of the bar doesn't change either way.
    YardBird, Inquiringone and trayday like this.
  13. Sep 25, 2017 at 8:38 PM
    Gotcha
    Law323[QUOTED] likes this.
  14. Oct 6, 2017 at 8:30 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    D7A1A8CD-2E66-4010-AB06-1CAF79695B75.jpg 7” BDS lift Kit. With 2” Leaf springs
  15. Oct 6, 2017 at 8:31 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
  16. Oct 6, 2017 at 8:46 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    Factory TRD sway bar stock length arms.
    newguy209 likes this.
  17. Apr 15, 2019 at 4:56 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Who did this for you?
  18. Apr 15, 2019 at 5:42 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Call David Ekstrom with Ekstrom Designs. Great guy to work with.
    (801) 635-4872
  19. Apr 15, 2019 at 5:57 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Ekstrom just did mine too for my 8” lift 97AB122E-67BC-43AA-B58A-ACAFEFD85A1A.jpg
    YardBird, Prostar 190 and Tundyfundy like this.
  20. Apr 17, 2019 at 3:29 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    My sport trd sway bar is under the diff. I'm thinking Toyota did it this way for a engineering purpose !
    Tundyfundy and Prostar 190 like this.
  21. Apr 17, 2019 at 3:58 AM
    Tundyfundy
    Bay Area, CA
    I spoke with him. He said they are developing a new adjustable drop bracket for the rear. He said it will be adjustable from 1 to 5” and you can preload the bar or set it at 0 preload. Saying time frame is a month or so. I think I’ll wait and buy it when I can. I’ll report back...
    YardBird and 1UPPER[QUOTED] like this.
  22. Apr 17, 2019 at 5:12 AM
    You can buy adjustable drop links from Hellwig.
    YardBird likes this.
  23. May 13, 2020 at 3:48 PM
    Duckbutter
    Duckbutter New Member
    2018 Charcoal Tundra Limited
    So I was looking at adding a sway bar to my truck and will be adding 2" of lift at same time. From what I am seeing here: the stock TRD sway bar will work with my 2" of lift without need for additional parts? Please let me know if I am thinking correctly.
    Tundyfundy likes this.
  24. May 13, 2020 at 4:12 PM
    Yes the red TRD sway bar will work on the rear with a 2 inch lift.
  25. May 13, 2020 at 4:31 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    He can also have a way of mounting a diff skid plate with this conf of mounting.
    The anti sway bar still works the same. it might be close to spare tire mounted area, and If a Bam exhaust with HolmHertz resonator wouldn’t work with it either. Unless mounted closer to mufflers
    It’ll never get caught on any rocks.
    Lol.
  26. May 22, 2020 at 3:41 PM
    quinterora8
    quinterora8 New Member
    Ruben
    2020 CM TRD
    6112/5100 & UCA
    About to put my 1.5 Toytec shackles do I need to do anything to rear sway bar?
  27. May 22, 2020 at 3:44 PM
    Just disconnect it at the end links.
  28. May 22, 2020 at 3:45 PM
    I used a balljoint press and impact to push the bushings out of the leaf springs....if you are replacing them.
  29. May 22, 2020 at 3:48 PM
    quinterora8
    Ruben
    2020 CM TRD
    6112/5100 & UCA
    Thanks for reply
  30. May 22, 2020 at 3:49 PM
    No problem. That's why we are all here. :thumbsup:
