Swap V6 for V8 question
Discussion in '1st Gen Tundras (2000-2006)' started by Nezpique, Apr 16, 2019.
  1. Apr 16, 2019 at 5:11 PM
    Nezpique
    Nezpique [OP] New Member
    Wendell
    Hello Guys!
    I have a 2000 Tundra, V6 2 wheel drive with a bad tranny and radiator. I also have a 2001 Tundra V8 2 wheel drive with a good tranny and radiator. Both engines run great, the V8 especially good! My son wrecked the V8 truck and not worth fixing with all the body work needed. I'd like to take the V8 engine, tranny and radiator and put it in the V6 truck. I know I'll have to take the V8 computer and swap out as well, but my question is, do you think with wiring harness is the same?? I would think so, but just not 100% Any negatives with attempting this?
    Thanks!
    Wendell
    DaWhiteTundra and speedtre like this.
  2. Apr 16, 2019 at 5:34 PM
    Professional Hand Model
    Hand Protectors
    A saying I live by: You don’t know until you go.
    Eugene406 and Darkness like this.
  3. Apr 16, 2019 at 6:39 PM
    Nezpique
    Wendell
    A saying I live by: Don't go until you know :rofl:
    landphil, GODZILLA, Aerindel and 3 others like this.
  4. Apr 17, 2019 at 4:16 AM
    Hand Protectors
    A good saying as well, but when you are carving new territory and you need to get things done.... you tend to find out what you are made of.
    My opinion is tackle this job if you have plenty of free time on your hands.
    You’ve done engine swaps before?
  5. Apr 17, 2019 at 5:30 AM
    Nezpique
    Wendell
    Never, but my brother has done plenty. I'm going to be his helper, lol.
  6. Apr 17, 2019 at 5:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Barring someone that has actual experience making this swap, you're probably best equipped to answer your own question, since you have both trucks in your possession for comparison.
    Since both engines were available in those years, it's logical that at some point, enough parts can be exchanged to get back to a common vehicle configuration for both engines. The only issue might be if the V8 trucks have significantly different basic elements that are not easily changed. For example, transmissions are likely different given the horsepower and torque of the V8, and this may require different mounting points, i.e. a different frame with different cross-member configuration. It was easy to build a truck on a frame, no so easy to change a frame to another part number.
    If there is a question about any component, like the engine wiring harness or the frame being the same, you can always avail yourself of Toyota of Cool Springs hospitality and use their site to verify common part numbers between the two trucks. A plus is you'll have the actual VINs to enter into the search...that may reduce the data input.
    You would be able to work behind a Toyota parts counter after this swap. :D
    GODZILLA, speedtre and Darkness like this.
  7. Apr 17, 2019 at 6:32 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Even if it's good, if that radiator in the 2001 is not a recent replacement, I would go ahead and splurge on a new Denso for $110 bucks...it will be no extra work and money well spent. It would SUCK to do all that work and have an old radiator cause a "pink milkshake" shortly after the swap....oh, and throw a new Aisin Timing belt water pump kit on there too ($170) if it's remotely close to needing it. It will be much easier to do while you have the engine out while your swapping it...:thumbsup:
    https://www.rockauto.com/en/moreinfo.php?pk=4723065&cc=1375365&jsn=392
    https://www.rockauto.com/en/moreinfo.php?pk=3290529&cc=1375365&jsn=1102
    Pretty sure both trucks had the same A340E transmission , so that is one less thing to worry about. :)
    https://en.wikipedia.org/wiki/Toyota_A_transmission#A340E_(30-40LE)
    revtune and JohnLakeman[QUOTED] like this.
  8. Apr 17, 2019 at 6:36 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Given you have both trucks you can do it. Easily? Not sure but you have all the pieces.
    As a good friend of mine says, anything is possible with a welder and cash.
    JohnLakeman likes this.
  9. Apr 17, 2019 at 6:45 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Yes v8 should fit. Need motor mounts and everything from v8 to fit. Should not have too many issues
  10. Apr 17, 2019 at 7:23 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    And remember, your stuffing 8lbs into a 5lbs bag. It's all a matter of speed! It can be done. Just take your time, enjoy the time with your brother and enjoy the fruits of your labors;)
    Darkness, noahrexion and bmf4069 like this.
  11. Apr 17, 2019 at 9:06 AM
    JohnLakeman
    Another important area of difference to check between the two trucks...front suspension. I can almost guarantee the coils will be heavier for the V8, and maybe the anti-roll bar as well. On other vehicles, I have seen as many as four different coil spring part numbers depending on the engine and what options are on the car.
  12. Apr 17, 2019 at 6:15 PM
    Nezpique
    Wendell
    Great point! The problem with the 2000 V6 tranny is the strawberry milkshake issue. From what I've read, the milkshake issue is mostly connected to the gen 1 V6 tundras, maybe i'm wrong, but for $110 it's a no brainer
  13. Apr 17, 2019 at 6:17 PM
    Nezpique
    Wendell
    I love your taste in welders, as I'm employed by Miller, welding is not an issue.
  14. Apr 17, 2019 at 6:19 PM
    Nezpique
    Wendell
    Thanks John! I just visited the Toyota of cool springs, great site. Thanks for all the input.
  15. Jul 7, 2020 at 10:16 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    Hey did you get it in? Did You need any different parts?
    I’m looking for a v8 to put into mine. Originally I wanted to supercharge my v6. But it’s cheaper to do the swap with similar results (Plus I can always by the s.c. for the v8).
    My guy said that if you get the same generation v8, it’s a direct drop in. And you should be fine for smog. Except for 05 V8 because it’s has a bit more hp and extra parts.
  16. Jul 7, 2020 at 10:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the v6 frames i believe have different engine mount locations and transmission cross member location. its doable. but there will be fab work.
    and if your going through the trouble, do a 05 or 06 v8 and trans.. more power, more gears.. and your going to need a donor anyway for harnesses and the cluster
    DaWhiteTundra[QUOTED] likes this.
  17. Jul 7, 2020 at 10:38 PM
    DaWhiteTundra
    Anthonee
    Sacramento, Ca
    Thanks for the advice. I hope there’s not too much fab work... Idk how to do fab work yet. It might be worth it to just get another v8 tundra for cheap if there’s too much fab work. I’ll read up on it and see what the difference is On the 05/06 vs older ones. I was hoping to find something at the yard and just pull the motor, harness, and cluster. If I do the 05 06 Swap I’ll likely grab a trans too for the extra gear.
  18. Jul 7, 2020 at 11:39 PM
    empty_lord
    05 rollover special
    honestly price wise you'd likely make out cheaper just finding a whole donor truck. or just sell yours for a v8 truck.
