Swap cigarette lighter for USB ports
Discussion in '2nd Gen Tundras (2007-2013)' started by TXTundraFan, Oct 30, 2020.
  1. Oct 30, 2020 at 5:17 PM
    TXTundraFan
    TXTundraFan [OP] New Member
    I'm swapping out the cigarette lighter for a dual USB port socket. I thought I had read that the grey wire is positive and the white/black wire is negative. However I am not getting any power and my multimeter is not getting voltage like I do on the power port to the right. I'm wondering if I blew a fuse but wouldn't both ports be on the same fuse?
    2010 CM SR5
    TundraBrew likes this.
  2. Oct 30, 2020 at 7:03 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Sequoia owner here. In my truck, Cigarette lighter has different fuse than Power Outlet.
    Check your user manual for confirmation.
    Greg
    TXTundraFan[OP] likes this.
  3. Oct 30, 2020 at 7:06 PM
    TXTundraFan
    Yep, that was it. The cig lighter had it's own 15A fuze and it was blown. I didn't have a spare so I took the 20A one for the seat heaters since I don't have heated seats. USB ports lit right up when I turned the key to accessory. Thank you!
  4. Nov 2, 2020 at 1:11 PM
    RH01
    RH01 Amateur Human
    Nick
    Oregon
    2019 Tundra Platinum CM
    Mind posting pics of the USB adapter you went with?
    Ducarius likes this.
  5. Nov 2, 2020 at 4:07 PM
    TXTundraFan
    Sure thing! https://www.amazon.com/gp/product/B07F84VVB4/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    You'd need to clip the factory connector off the back and add the female terminals to them. It comes with the blue ones but those are too big for the factory wiring, so you'll want to get the red ones. You will also need to use a Dremel and open up the hole for this one to fit. You don't have to be perfect with it since it includes a ring that will tighten it to the trim piece.
    Grey is positive and white with black stripe is ground. This connector shows a plus and minus on the pins to show you which is which.
    I also used this same USB outlet to replace the 12v in the rear of the center console. I like that it has a voltmeter built in.
  6. Nov 3, 2020 at 2:14 PM
    RH01
    RH01 Amateur Human
    Nick
    Oregon
    Awesome! I just grabbed one too. How much did you shave off with the Dremel? I’m one of those “hesitant to alter stock” guys. Haha
  7. Nov 3, 2020 at 4:43 PM
    TXTundraFan
    Not a whole lot. I basically took the Dremel and went around the existing hole to enlarge it. Maybe 10-15 seconds total. You don't have to get it the exact size of the dual USB port outlet as it includes a locking ring you spin and tighten it to the base. Just be sure to get the red female terminals as the blue are too large for the factory wiring. Found that out the hard way, lol.
  8. Nov 3, 2020 at 8:11 PM
    RH01
    RH01 Amateur Human
    Nick
    Oregon
    Awesome! Thanks for the info!
  9. Nov 5, 2020 at 5:49 PM
    TXTundraFan
    Anytime! That's what I like about this forum!
  10. Apr 7, 2021 at 8:33 AM
    James07
    James07 New Member
    James
    Maryland
    2017 CM Platinum in Super White
    Ready Lift 3/2 General Grabbers ATX 35x12.5x17 Icon Alloys Rebounds 17 Window Tint Line-X Bed 32" Rigid Light bar in Bumper Stubby Antenna VLED under dash lights A-Pillar Grab handle Blacked out exhaust tip Shovel/Axe bed mounts
    TXTundraFan Did you use the fuse that was inline or cut it out and hardware.
  11. Apr 7, 2021 at 8:55 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I used a unibit in my drill to enlarge the cig lighter mounting hole to accept the USB plug.
    https://www.amazon.com/Neiko-10193A...7&sr=1-2-64f3a41a-73ca-403a-923c-8152c45485fe
    NewImprovedRon likes this.
  12. Apr 7, 2021 at 8:58 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    One of these makes it slightly easier.
    07 Tundie and NewImprovedRon like this.
  13. Apr 9, 2021 at 3:31 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    This is what I used. From Harbor Freight
    Hightide[QUOTED] likes this.
  14. Apr 9, 2021 at 3:36 PM
    Rocko9999
    Rocko9999 New Member
    What about when you want to use a 12v air pump or other 12v accessory?
  15. Apr 9, 2021 at 3:40 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    use either the one inside the center console or that one at the back of the center console.
    edit: I had two 12v outlets up front. I only converted one to a USB outlet.
    Hightide likes this.
  16. Apr 9, 2021 at 3:41 PM
    Hightide
    Abalama
    Magic School Bus
  17. Apr 9, 2021 at 3:44 PM
    Rocko9999
    Ah. Any reason you don't want to use a usb adapter other than aesthetics? If it fails it's easily replaced.
    texasrho83 likes this.
  18. Apr 9, 2021 at 3:46 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    aesthetics, I suppose.
    this is much cleaner than a plug-in and plug-ins fail as well. If my usb socket ever fails it’ll take about 15 minutes to replace.
    edit: here’s a photo. I think it looks a lot better.
  19. Apr 9, 2021 at 3:49 PM
    Rocko9999
    it does look nice.
    07 Tundie[QUOTED] likes this.
  20. Apr 9, 2021 at 3:50 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Thanks, man!
    It’s super quick and easy.
    Rocko9999[QUOTED] likes this.
  21. Apr 9, 2021 at 3:51 PM
    Hightide
    Abalama
    Magic School Bus
    Um, Because more things use usb rather than 12v plug these days.
    Plus, it cleans it up.
  22. Apr 9, 2021 at 7:47 PM
    TXTundraFan
    I didn't cut anything out except the factory connectors as the dual USB ports use different ones. I spliced those together. I get that the 20A fuse isn't better than the 15A that the cig lighter normally uses, but I also won't be running anything power hungry with those ports either; maybe charging a phone or tablet.
  23. Apr 9, 2021 at 8:57 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’ve got a couple USB ports waiting to be installed as soon as I get the truck back from being regeared, and I had the same mentality. It’s been a while since I’ve found myself needing a 12V plug over a USB. I think it’ll be an updated look over all, and as noted above, there are still some 12V receptacles in other areas if I really need one. I guess it all depends on what your most common day-to-day needs are.
  24. Apr 9, 2021 at 9:00 PM
    Hightide
    Abalama
    Magic School Bus
    I purchased a replacement portable air pump to one I broke, that I previously bought off Amazon years ago.
    It originally had a 12v plug.
    The new one came with a usb and zero 12v.
  25. Apr 10, 2021 at 4:28 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Cig lighter / USB adaptors just plug in, no wiring
  26. Dec 30, 2022 at 8:14 PM
    Killahill
    Killahill New Member
    2015 Toyota Tundra
    Swapped out my lighter ports in the rear of the console and 2 up front. All 3 appear to work just fine, however immediately after I now notice that my airbag light is on. Can anyone think of how this might be connected?
  27. Dec 30, 2022 at 9:01 PM
    Killahill
    2015 Toyota Tundra
    Scratch that. Pulled the that dash/console insert off and saw that I failed to reconnect the passenger airbag. All good!
  28. Dec 30, 2022 at 9:13 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    As rapidly as USB charging formats change these days, I stick to adapters that can be swapped in 30 seconds for $25. Hell in the last 3 years I've had devices swing from USB-A to USB-3.1 to C to PD to whatever the hell we're at now. Thunderbolt 4? Bleh. Integrated just invites a slow-charge headache with a new phone, my two cents!
    Dank likes this.
  29. Dec 30, 2022 at 9:55 PM
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    Bought a few of these a few years ago and still working. Threw out the cheaper ones I bought since they stopped charging correctly, especially off-roading!
    Agree with MedCityMoto above.
  30. Dec 31, 2022 at 9:07 AM
    MedCityMoto
    I love the Scosche magnetic mounts, I don't use Qi charging (too slow) so I use the XL plates stuck inside cheap Amazon cases, you'd have to throw the truck off Everest to get the thing to come off. It holds with almost as much force as my gun magnet, very impressive.
