Suspension upgrade...tow 5000lbs and mostly street driving
Discussion in '1st Gen Tundras (2000-2006)' started by Dave8699, Oct 3, 2021.
  1. Oct 25, 2021 at 6:30 PM
    #61
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The mount is sitting between 2 rubber bushings to allow slight movement. If it didn’t your bottom bushing would be fucked within short order due to caster.
  2. Oct 25, 2021 at 6:31 PM
    #62
    Dave8699
    Dave8699 [OP] Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Do you know where the 3 bolts on the strut mount need to he compared to the shock bushing?
  3. Oct 25, 2021 at 7:15 PM
    #63
    empty_lord
    05 rollover special
    Off the top of my head no. It’s in the FSM. But I’m no where near my computer currently and TIS won’t load PDF files on my phone
  4. Oct 25, 2021 at 7:59 PM
    #64
    Dave8699
    David
    NJ
    Thank you I found this for 05-06 I'm assuming it has to be the same. It's crazy how no videos on YouTube or anywhere mention this.
  5. Nov 2, 2021 at 3:45 PM
    #65
    Dave8699
    David
    NJ
    Ok so I finally finished the front end rebuild. And I have to move on the the back now, but I have a question there is a difference of 1" from driver to passenger.
    Should I wait for suspension to settle before ordering a ½" spacer to fix the 1" difference?
    Also I'm assuming I have to wait until suspension settles to get an alignment.
    2006 Tundra AC likes this.
  6. Nov 2, 2021 at 5:08 PM
    #66
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I would wait at least a week before making a decision on a spacer. I would wait about a week before an alignment IMHO. Post up pics when you're done. We like pics.
  7. Nov 2, 2021 at 5:12 PM
    #67
    Dave8699
    David
    NJ
    Will do the issue is the alignment is way off so don't want to drive that much. Will the suspect settle without driving tbe truck or just drive it as is.
  8. Nov 2, 2021 at 7:45 PM
    #68
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Align now, touch up if they settle in a month or two.
  9. Nov 3, 2021 at 9:32 AM
    #69
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I agree, otherwise you could chew up your tires.
  10. Nov 3, 2021 at 3:44 PM
    #70
    Dave8699
    David
    NJ
    Are these good alignment specs?
  11. Nov 3, 2021 at 3:46 PM
    #71
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Ok specs.
    Better ones.
    - 0.3 camber
    + 2.6 caster
    + 0.15 toe in
  12. Nov 3, 2021 at 6:09 PM
    #72
    Dave8699
    David
    NJ
    If I give these specs to technician is there anything I have to let him know so he does a good job?
    I got this with the JBA UCA they say tell tech to set caster as high as possible. Is that around +2.6?
  13. Nov 3, 2021 at 6:53 PM
    #73
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    If he knows what he is doing, you shouldn't have to.
    Yes, 2.7 or 2.8 is also good.
    This spec moves the lower ball joint towards the front of the truck and therefore the tire also moves towards the bumper. This gives more clearance to the foot well area/pinch weld at the rear of the fender, where the majority of the rubbing is.
  14. Nov 3, 2021 at 7:03 PM
    #74
    Dave8699
    David
    NJ
    Got it 2.8 caster and toe and camber to oem spec
  15. Nov 3, 2021 at 7:43 PM
    #75
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Make sure you check into the place you're having it done at. Was a pain in my area to find a place to set custom alignment.
  16. Nov 3, 2021 at 7:55 PM
    #76
    Dave8699
    David
    NJ
    Going to take it to the place I take my track car so I'm sure they will set it to my specs. Just need to give them the specs and they will get it there.
    NickB_01TRD[QUOTED] likes this.
  17. Nov 3, 2021 at 8:15 PM
    #77
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Not stock spec for camber and toe.
    -0.3 camber and +0.15 toe in.
    Dave8699[QUOTED][OP] likes this.
