Suspension upgrade...tow 5000lbs and mostly street driving
Discussion in '1st Gen Tundras (2000-2006)' started by Dave8699, Oct 3, 2021.
  1. Oct 5, 2021 at 8:49 AM
    Dave8699
    Dave8699 [OP] Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Is it safe to say ¼" spacer is safe to level every truck or does it vary?
  2. Oct 5, 2021 at 12:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It typically will vary. Some trucks lean more than others
  3. Oct 5, 2021 at 1:00 PM
    Dave8699
    David
    NJ
    So I pretty much ordered everything i believe let me know if I'm missing something.
    Wheelersoffroad.com
    Wheelers 3 leaf aal
    Wheelers diff drop
    Wheelers strut mount
    Wheelers SS brake lines
    Ome 2885
    Wheelers ¼" aluminum spacer ( if I need it for the driver side)
    SPC alignment cam
    Rockauto.com
    AC Delco tie rod ends
    MevoTech terrain tuff LBJ with grease fitting
    Ac Delco LCA
    Bilsteinlift.com
    Bilstein 5100 Front and rear
    CVJ.com
    CV Red inner boot
    Amazon
    Energy suspension power steering bushing
    Energy suspension isolators
    Suspensionmax.com
    Ext swey end links
  4. Oct 7, 2021 at 10:39 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
  5. Oct 7, 2021 at 12:44 PM
    Dave8699
    David
    NJ
    Shit only if I knew yesterday I ordered a ¼" shim for the driver side. Hopefully it's enough if not I will have to take everything apart again and install the correct side which I'll order from you. Also I'm assuming I have to wait some time for suspension to settle before alignment and measuring the difference?
  6. Oct 21, 2021 at 1:52 PM
    Dave8699
    David
    NJ
    So before I tackle this front end rebuild, I have a question is everyone using the 5100 and 2885 coils on the 1st or 2nd clip?
    I want the most lift possible as I have 2.5" left now and not sure how the 5100 will compare with the Rancho quick lift.
    Also is there a particular position the coil has to be ? Some people say yes other no. I'm referring to the end of the coil . I read it has to be centered with the wheel.
  7. Oct 22, 2021 at 10:14 AM
    Dave8699
    David
    NJ
    Anyone have some input on circlip locations on the 5100? Using 2885 coil 1,2 or 3rd postion?
    Also I realized that the poly isolators don't have a cutout for the 3 bolts on the strut mount so the isolator doesn't set flush. My ocd wants to cut some of the poly so it can set flush. Not sure if anyone noticed or had the same issue.
  8. Oct 22, 2021 at 11:41 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I feel like those isolators will be flush when compressed.
  9. Oct 22, 2021 at 1:12 PM
    empty_lord
    05 rollover special
    1st notch. 2nd may end up too tall. And the isolator will compress enough to not care
    alb1k likes this.
  10. Oct 22, 2021 at 1:14 PM
    Dave8699
    David
    NJ
    Excellent so 1st notch will give me 2" or 2.5?
  11. Oct 22, 2021 at 1:22 PM
    empty_lord
    05 rollover special
    Ehhh my
    Measurements before and after we’re 2.25”, but mine was original suspension with 200k miles and a rollover under their belt
  12. Oct 22, 2021 at 1:42 PM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I have 2885 with Bilstein 5100s on the bottom notch. I got ~2.75" but I am 2WD and have the 4.0L. I would keep them on the bottom notch because it rides better.
  13. Oct 22, 2021 at 2:07 PM
    Dave8699
    David
    NJ
    Just saw your post on the other thread with measurements from center to fender. Was trying to go back and see if anyone has used the 2nd notch.
    Shit know I'm not sure if I should go 1st or 2nd notch. Is the ride that bad with using the 2nd notch or is it something else that can go bad?
  14. Oct 22, 2021 at 2:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    What's the distance between notches? 1/4"?
    The rate of lift is approximately 2:1, so each 1/4" = 1/2" lift.
    Thats why those 1/4" leveling spacers give about 1/2" of lean correction.
  15. Oct 22, 2021 at 3:27 PM
    empty_lord
    05 rollover special
    The higher you go, the more preload. More preload = rougher ride. I’m on first notch and the rides fantastic. I’m sure 2nd isn’t a lot worse. But it won’t be as nice
  16. Oct 23, 2021 at 4:45 PM
    Dave8699
    David
    NJ
    @empty_lord did you install a diff drop kit? Is it needed for 5100 on the 2nd notch?
  17. Oct 23, 2021 at 5:12 PM
    empty_lord
    05 rollover special
    I don’t have one. On 2nd notch it’s probably not a bad idea
  18. Oct 23, 2021 at 5:16 PM
    Dave8699
    David
    NJ
    Ok I have one so I'll install it I also noticed that my carrier bearing is loose so I'm changing that out also. By any chance do you know what the best time determine the angle of the driveshaft for are trucks? Not sure if I need to install small spacer on the carrier bearing bracket.
  19. Oct 23, 2021 at 6:34 PM
    #49
    empty_lord
    05 rollover special
    I mean if it’s not vibrating I wouldn’t worry about angles
  20. Oct 23, 2021 at 6:56 PM
    #50
    alb1k
    Left Coast
    It's good
    I agree, but in my case after a pretty good lift in the rear and more travel coming, I just looked at the driveline and ordered a drop kit for the support bearing. 2WD and completely different set up for me. My front u joint can spare a bit for my mid and rear.
  21. Oct 23, 2021 at 7:29 PM
    #51
    Dave8699
    David
    NJ
    The issue I have is I feel a little vibration around 70 MPH but not sure what it can be. Once I finish up next week with UCA, LCA, outer tie rod, CVJ boots, aal, power steering bushing, 5100, clamshell bearing, diff drop and carrier bearing. I'll get an alignment and go from there.
  22. Oct 25, 2021 at 2:35 PM
    #52
    Dave8699
    David
    NJ
    @empty_lord I'm I doing something wrong or did I get the wrong parts. This spring gave my Branick compressor a work out. The issue I'm having is that it looks like the strut mount is not straight with the shock and spring. Hard to tell from the pictures but hopefully you can see of something is off.
  23. Oct 25, 2021 at 2:58 PM
    #53
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Can you take a closer picture of the bottom perch?
  24. Oct 25, 2021 at 3:02 PM
    #54
    Dave8699
    David
    NJ
    Is this better?
  25. Oct 25, 2021 at 3:03 PM
    #55
    rock climber
    Yeah, is it sitting just a little off? I have no idea if that's the cause though.
  26. Oct 25, 2021 at 3:06 PM
    #56
    Dave8699
    David
    NJ
    What do you mean by off a little ?
  27. Oct 25, 2021 at 3:39 PM
    #57
    rock climber
    Where I circled doesn't look flush
  28. Oct 25, 2021 at 3:46 PM
    #58
    Dave8699
    David
    NJ
    Ok im going to try to see if it improves it.
  29. Oct 25, 2021 at 4:12 PM
    #59
    Dave8699
    David
    NJ
    Ok so I fix it but still the top is not squared with the shock or coil. Also is it normal for the top rubber bushing to mushroom like this.
  30. Oct 25, 2021 at 6:28 PM
    #60
    empty_lord
    05 rollover special
    The slight bow in the spring is normal.
