Suspension/Tire Size help
Discussion in '1st Gen Tundras (2000-2006)' started by destrodrew, Dec 20, 2020.
  1. Dec 20, 2020 at 2:39 PM
    destrodrew
    destrodrew [OP] New Member
    Drew
    Utah
    2002 Toyota Tundra SR5 4x4
    Hello everyone. I acquired a stock 2002 Tundra AC with a TRD package this year and I'm at the point where I need to replace tires. I've read through the other threads but would appreciate some advice and suggestions for my situation. My goal would be to fit 285/70/r17 (or biggest possible without much trimming and adjustments). My wheel choice would be some American Racing AR172 Baja (Pro Comp 7069 could be a possibility). I'm still up in the air about tire brands but I was leaning towards BFGoodrich T/A KO2.
    I know that if I want to do this I'd have to mess with suspension. My preferred option for the time being would be to get a level kit from ReadyLift or Pro Comp. If I do choose to get a level kit would I also need to get a block kit for the rear? My second option would be to buy a lift kit from toytec but I'd prefer to do this when it comes time to replace the Bilstein that are already on the truck.
    https://www.tirerack.com/suspension...del=Tundra+SR5+4wd&autoYear=2002&autoModClar=
    I'm still new to this and trying to learn so any advice/suggestions would be appreciated.
  2. Dec 20, 2020 at 3:00 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    285/70/17 will clear with a 2”/2.5” level no problem. Where you might run into some issue is offset on wheels. Too little will cause the tires to possibly rub the frame, too much and you will run on the pinch welds. Finding the perfect combination is the tough part.
    Myself, I will be running a 2.5” Toytec front lift and a 2” rear block. I plan on running 285/70/17’s with a 17x9 wheel with a -12 offset. Ideally a 285/75/17 would be best but tire choices are limited in that size (34”).
    imDementeD likes this.
  3. Dec 20, 2020 at 3:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I used an 16x8 wheel with 4.5 inches of backspacing on my gen 1. Cleared 285’s perfect.
    many wheels have only 4 inches of BS, and that can sometimes hit the fender
  4. Dec 20, 2020 at 3:53 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    I have 2.5” OME front suspension lift and 1.5” rear spacer (for now, planning on replacing with adjustable struts) and I am running 285/70r17. Nitto trail grapplers and Fuel Hostage wheels. I’ve been really happy with my setup all around.
  5. Dec 22, 2020 at 4:52 PM
    destrodrew
    Drew
    Utah
    I'm assuming you're running 285/75/r16? Did you notice a change in ride quality or a decrease to mpg when upgrading to 285s? At the moment I use my Tundra more on road than off-road so depending how much it affects these things I might look at some 275/265 instead. From my understanding it doesn't look like I'll need regearing if I put 285s. I'm still open to using 16" instead of 17".
    Looking at the AR172 the 16" have 4.52 backspace and -25 offset and the 17" have 4.53 backspace with a -12 offset.
    https://www.americanracing.com/product/wheels/ar172-baja/?attribute_pa_finish=satin-black
    Pro Comp 69 for 16" have 4 backspace and -12 offset and 17" have 4.75 backspace and -6 offset.
    https://www.procompusa.com/wheels-p...lc=PXA&pqq=2336-1558-1551&pqa=13671-8275-8059
    Safe to say that the American Racing would be better for my situation?
  6. Dec 22, 2020 at 4:55 PM
    destrodrew
    Drew
    Utah
    Looks great! Did you have to do any trimming? How's the OME front lift on the road and off-road?
  7. Dec 22, 2020 at 6:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It was my last truck @destrodrew
    yes the 285s did hit quickness and mpg a little.
    the 4.75 bs wheels may hit the frame with 285s if I remember
  8. Dec 23, 2020 at 4:16 AM
    04DCTundraMan
    Ryan
    Thanks! No trimming, I only ride trails around here, It’s great for that!
  9. Dec 23, 2020 at 2:17 PM
    Bray_Maynard44
    Bray_Maynard44 New Member
    Bray
    2004 DC 4WD
    Is the OME a good lift, I’ve been considering it
  10. Dec 27, 2020 at 8:40 AM
    SouthPaw
    2000 Limited 4x4 AC
    They are considered good. First Gen Offroad sells a lot of them.
  11. Dec 27, 2020 at 5:51 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
  12. Dec 27, 2020 at 6:05 PM
    ADKYoter720
    ADKYoter720 New Member
    Raymond
    Adirondacks of NY
    2006 DCLB TRD Mica Blue
    Stock... for now
  13. Dec 27, 2020 at 6:07 PM
    ADKYoter720
    Raymond
    Adirondacks of NY
    Stock... for now
    Sorry for just the quote post. 04DCTundraMan, did you do UCA’s along with the OME lift? I’ve got the OME 2.5” kit with AAL’s for the rear on the way from Toytec, and it seems you can go either with the stock ones or get some aftermarket ones
  14. Dec 27, 2020 at 7:43 PM
    04DCTundraMan
    Ryan
    I have SPC UCAs, but they were done a year or so before the lift. Been doing things in stages as they wear out.
    ADKYoter720[QUOTED] likes this.
  15. Jan 22, 2021 at 12:00 PM
    destrodrew
    Drew
    Utah
    I wanted to update this thread on what I went with. For the time being to make it easy on my wallet and schedule I decided on 265/70/r17. I went with BF Goodrich KO2s which are amazing. I've put around 1,200 miles so far on them and the difference between my old a/t tires is night and day. Off roading in the snow/mud is a walk in the park. I've taken it on two long distance trips since install and I can't tell a difference between the old tires and the KO2s in terms of ride quality and noise (honestly might be slightly better but they are new tires). My mpg seems to be about the same as before but I'll know for certain as time goes on. Looking forward to see how these tires continue to perform. For the wheels I went with AR Baja 172 with the -12 offset, no clearance issues at all. I plan on doing a suspension rebuild later this year and at this point I'll go with 285s or 315s.
    des2mtn and Mustanley like this.
  16. Jan 22, 2021 at 12:14 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Looks nice and glad you're liking the tires! When they have some good wear in them, you'll start to notice some noise but nothing unbearable. But then again that is the nature of A/Ts.
