Suspension slip?
Discussion in 'Suspension' started by Danimal86, Mar 15, 2020.
  1. Mar 15, 2020 at 4:37 PM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I need some advice from the suspension guru's. About a month ago, I installed 6112 myself (assembled by boss4x4).
    Today I was turning left into a parking spot and it felt like I drove over something like a rock (kinda felt like one tire slipped).
    Now I noticed that my steering wheel is at the 11 o'clock when driving straight.
    I took a look at the suspension and everything looks normal. I'm no guru, this was the first time working with suspension. Anything in particular I should look at? I'm thinking I'll bring it back to the shop I had the alignment done at this week and see if they will fix the steering.
  2. Mar 15, 2020 at 4:38 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Check cam bolts
    15whtrd and Tundyfundy like this.
  3. Mar 15, 2020 at 4:51 PM
    Danimal86
    Daniel
    Sacramento, CA
    If they loosened, then I would need the shop the re-do the alignment?
    15whtrd likes this.
  4. Mar 15, 2020 at 4:52 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes, unless you marked then when you got home. Some people mark the cams, so after hard wheeling or etc they can pop under, take a look and adjust if they moved.
    15whtrd likes this.
  5. Mar 15, 2020 at 5:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    Dang, I'll have to do that next time.
  6. Mar 15, 2020 at 5:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    Think I should go crank them down now before I bring them in?
  7. Mar 15, 2020 at 8:19 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Are they loose?
  8. Mar 15, 2020 at 8:30 PM
    Danimal86
    Daniel
    Sacramento, CA
    Its pouring ran today, ill check it tomorrow
  9. Mar 15, 2020 at 9:04 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Based of your comment I assumed you checked. Regardless, you'll need to take it back for a realignment as something happened. But, obviously, you need to figure out what happened and fix it prior to the realignment.
    15whtrd likes this.
  10. Mar 16, 2020 at 6:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    I'm going to call the shop today. I'll see if they can give all the bolts a once-over to make sure everything is tightened down.
    I used thread locker on all the bolts I removed, but not the cam bolts.
    14burrito[QUOTED] likes this.
  11. Mar 16, 2020 at 6:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    I called the shop today, they said to bring it in and they will re align it.
    I'm going to try to put a wrench on the cam bolts, do you know how tight they should be?
  12. Mar 16, 2020 at 7:05 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Like 300ftlbs lol
    Not really, but they should be freaking tight
    Quick search shows like 207 lb. Ft?
  13. Mar 16, 2020 at 7:10 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    207 is correct. At least in the ball park.
    15whtrd likes this.
  14. Mar 16, 2020 at 7:17 PM
    Danimal86
    Daniel
    Sacramento, CA
    So get it right and give it a good couple whacks with an impact wrench? I think my torque wrench only goes to around 125
  15. Mar 17, 2020 at 10:30 AM
    Danimal86
    Daniel
    Sacramento, CA
    At the shop now, you were right on the money @14burrito .
    I'm not sure how it happened but left ear that holds the cam bolt had been flattened and looks like it was letting the control arm move.
    They are going to try to bend it back. I have no idea if it will hold. I wonder if a fab shop could weld on a little reinforcement.
  16. Mar 17, 2020 at 10:34 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    When you explained your situation, I felt this was the issue. Glad it was an "easy" find.
    Some people put a fat weld there, cheapest option.
    @TOTAL CHAOS makes cam gusset tabs, they are a little more labor intensive.
    I did just come across something interesting that I'm toying the idea of doing...
    https://www.marlincrawler.com/axles/front-axle-armor/hd-lca-frame-brace-2007-tundra
  17. Mar 17, 2020 at 10:40 AM
    Danimal86
    Daniel
    Sacramento, CA
    You da man!
    That's a good idea about slapping a bead on there. I'll see if I can get a pic before they pull it off the lift.
  18. Mar 17, 2020 at 10:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    Dang, the tech just came by and said the ear broke off.
    Gotta try to call a shop to see if I can find someone to weld it on.
  19. Mar 17, 2020 at 11:01 AM
    15whtrd
    15whtrd Mr. Blonde
    I want to say it’s possible they didn’t have them tight enough. That caused your cam bolt to move and fatigue that ear. I’m not saying it’s impossible for it to move after being torqued properly. But I would be questioning if it was right from the start.
  20. Mar 17, 2020 at 12:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    No real way to tell if it was me or them......probably was me, as when I was putting on the 6112s this side was a real pain in the ass.
    15whtrd[QUOTED] likes this.
  21. Mar 17, 2020 at 12:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    I'm at a shop that my family has gone to a bunch. They are going to weld on a piece of box stock in the place of the tab
    If they just put it in the same place as the little ear, it should be fine right? Not really sure how those cam bolts are adjusted for an alignment.
  22. Mar 17, 2020 at 1:40 PM
    Danimal86
    Daniel
    Sacramento, CA
    Long day.....
    The tab is welded on, it twisted a little bit. Now I'm back at the alignment shop to have it aligned for the third time.
    15whtrd likes this.
  23. Mar 17, 2020 at 5:33 PM
    Danimal86
    Daniel
    Sacramento, CA
    Just picked it up from the shop, they said the weld looked good and held up nicely.
    She's aligned and driving great.
    Thanks @14burrito for your help!
    14burrito and FrenchToasty like this.
  24. Mar 17, 2020 at 5:52 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Glad your truck is up and running good. I recommend getting a torque wrench and double checking cam bolt torque to tundra factory spec. This will ensure the truck holds the alignment.
    My Tacoma has the same alignment design and I had the same cam tab folding issue. I have found over the years that every alignment shop has under torqued my cam bolts.
    Best practice is to mark them and torque verify after alignment. Maybe I'm cheap, but i would rather spend $100 on mods rather than spending it on an alignment.
  25. Mar 17, 2020 at 6:42 PM
    Rubberdown
    Those bolts are tiiiiiiiiight. Make sure you get a torque wrench that goes high enough.
  26. Mar 18, 2020 at 7:19 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Anytime buddy! Glad it all worked out well!
  27. Mar 18, 2020 at 5:14 PM
    rustytoys
    rustytoys New Member
    Believe I read around 190-pounds on another thread; I'm going to check mine but not sure how I could get enough leverage on the wrench underneath the truck to hit that?! Seems like you almost need a lift so you can have the room to use a really long breaker bar/torque wrench - though I hope not.
  28. Mar 18, 2020 at 5:16 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    They are supposed to be torqued down at ride height, as is the UCA. So an alignment rack would be a proper rack, traditional hoist not so much.
    I have an electric Ryobi impact, it works great.
