Suspension Popping/Grinding After Lift Kit
Discussion in 'General Tundra Discussion' started by AtlasTheTundra, Jun 10, 2019.
  1. Jun 10, 2019 at 1:04 PM
    AtlasTheTundra
    AtlasTheTundra [OP] New Member
    Cassie
    2010 Tundra
    Hey all,
    Just got my tundra lifted 2.5 inches with and Old Man Emu lift kit and ever since the front right is making a slight popping and grinding sound when the wheel is turned all the way to the left.
    It's not a constant sound, only when all the way cranked and only intermittent at low speeds. I am putting it up on an alignment rack tonight to take a look before I take it back to the shop that did the lift. Do any of you have any experience with this or have any suggestions as to what it might be?
  2. Jun 10, 2019 at 1:22 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Might be your front mud guard rubbing and carching in the tire. Look and see if you can see rub marks on the plastics.
    Black Wolf likes this.
  3. Jun 10, 2019 at 1:24 PM
    AtlasTheTundra
    Cassie
    2010 Tundra
    No mud flaps up front so probably not those. The right fender liner isn't completely flush so it's possible that is the cause. It just sounds too metallic to be the fender liner catching and the wheels I have on it are still small, only running stock tire size from before the lift kit. I will definitely look into that being the cause though
  4. Jun 10, 2019 at 1:28 PM
    Tundyfundy
    Bay Area, CA
    Could be the skid plate rubbing? If you only hear it at full lock I'd say some clearances are messed up. Got any pics?
  5. Jun 10, 2019 at 1:29 PM
    AtlasTheTundra
    Cassie
    2010 Tundra
    Ya, I'm definitely thinking something isn't right with the clearance. No pics yet but I'll take some when it's up in the air in a few hours
    Tundyfundy[QUOTED] likes this.
  6. Jun 16, 2019 at 3:24 PM
    AtlasTheTundra
    Cassie
    2010 Tundra
    So the truck went back to Toytec where the lift kit was installed. After an hour and a half of digging, the tech that lifted it and the master tech couldn't find the problem. I was told to install new lower control arms and see if that would correct the noise it was making (my cam bolts were frozen so they couldn't get it properly alligned).
    A few days after that, I took it to a greasemonkey to get the rear diff drained and filled and the tech there found my problem. The drive train hanger where the carrier bearing goes was barely even attached. tightened the two bolts and hasn't made a peep since.
    Just though I would share the info incase anyone comes across a similar issue
    mtntop, Tundra$ and DM 2018 Tundra like this.
  7. Nov 11, 2023 at 9:00 AM
    Hamet hunts
    Hamet hunts New Member
    Geoff
    2001 tundra
    It’s always that dang carrier bracket. I spent 2 days looking for the damn grinding after I lifted the tundra 2 inches and a simple adjusting of that bracket forward solved it all
