Suspension Help
Discussion in 'Suspension' started by jdavenport, Jan 31, 2018.
  1. Feb 10, 2018 at 1:48 AM
    #91
    zackbremer
    zackbremer New Member
    Da Z
    @papasmurf has some for sale i think
  2. Feb 11, 2018 at 2:58 PM
    #92
    jdavenport
    jdavenport [OP] New Member
    Justin
    2013 Tundra 4x4 w/Flippac
    So I went ahead and bought full King with reservoir and adjusters due to them being 5 minutes from my house and the customer service aspect. I also got the TC ucas and just need to order the deavers.
    I'm now looking to my tires and rims. Do you run beadlock? I know I want 35s but the question is regarding the width of tire and offset. I'm not sure whether to go 17" or 18" rims and what width of tire to look for and then what offset to look for. From what I understand the stock alloy rims are +60offset.
    KevinK[QUOTED] likes this.
  3. Feb 11, 2018 at 7:28 PM
    #93
    n2deep
    n2deep Pavement Princess
    Check out the Icon Speed 6 wheel in 17. One of the lighter wheels out there.
    KevinK, Watt maker and jdavenport[OP] like this.
  4. Feb 11, 2018 at 7:45 PM
    #94
    jdavenport
    Justin
    Those things are awesome, it's cool that it allows you to run 35s without having to do the body chop mount! Thanks for the heads up on it! Do you run them?
  5. Feb 11, 2018 at 7:48 PM
    #95
    n2deep
    No I don't think they have the correct backspacing to fit with my LCA's.
  6. Feb 12, 2018 at 8:54 PM
    #96
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    Thanks. I will try to hit him up. I need them real soon.
  7. Feb 12, 2018 at 10:21 PM
    #97
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I don’t know if he gets alerts from this forum. Let me know if he doesn’t answer and I’ll text him.
  8. Feb 12, 2018 at 10:26 PM
    #98
    JBSTOY
    Jack
    Unknown Origen
    Cool @KevinK. I’d appreciate that. I take it he is one of your friends?
  9. Feb 13, 2018 at 2:05 PM
    #99
    KevinK
    Tundras to Sedona
    He's just this asshole I know.
    :rofl::rofl:
    I'll ping him right now.
    JBSTOY[QUOTED] likes this.
  10. Feb 13, 2018 at 3:23 PM
    #100
    jdavenport
    Justin
    What size shackles are you guys running? Want it level at 2.5in in the front. I know the long bed double cabs sit a little differently right? @KevinK
  11. Feb 13, 2018 at 3:32 PM
    #101
    KevinK
    Tundras to Sedona
    We didn't lift with a shackle. We have a 1" block on stock leafs, I'm embarrassed to say, but it's been performing well under our loads. Maybe one of the shackle guys can speak up. I'm not sure what the difference is in the DC regular bed and the DC long bed.
  12. Feb 14, 2018 at 10:04 AM
    #102
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    :bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance:
    I mean you are not wrong...
  13. Feb 14, 2018 at 6:16 PM
    #103
    JBSTOY
    Jack
    Unknown Origen
    Thanks so much @KevinK . He replied to me. I really appreciate your help.
    KevinK[QUOTED] and papasmurf like this.
  14. Feb 14, 2018 at 6:46 PM
    #104
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Look
    @KevinK i did a decent thing.... :boink:
    KevinK and JBSTOY[QUOTED] like this.
  15. Feb 14, 2018 at 7:05 PM
    #105
    zackbremer
    Da Z
    if you leave the coils at 2.5in of lift you should sit about dead even with no load in the bed....stock rake the tundra sits about 3in high in the ass with the crew max..so lifting the front 2.5 should just about level it. if you want shackles, go with coachbuilder
    KevinK likes this.
  16. Feb 15, 2018 at 7:23 AM
    #106
    KevinK
    Tundras to Sedona
    I had faith in you. I also took a side bet just in case. :rofl:
    JBSTOY and papasmurf[QUOTED] like this.
  17. Mar 16, 2018 at 7:52 AM
    #107
    jdavenport
    Justin
    @KevinK Alright because I'm indecisive. How much cutting are we talking when it comes to 37s. Are you re geared? Keep going back and forth between 35s and 37s.
  18. Mar 16, 2018 at 8:30 AM
    #108
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Kevin when have you seen a Fox shock fail?
  19. Mar 16, 2018 at 10:05 AM
    #109
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Hes not and nor am I
  20. Mar 16, 2018 at 2:36 PM
    #110
    KevinK
    Tundras to Sedona
    It’s not a ton of cutting. Worth it in my opinion for sure. Biggest issue is Rim offset. With non adjustable uppers you want to be around 18 offset on a 9” Rim or 25 on a 8.5” rim. With adjustable uppers you can go up to 0 offset on an 8.5”.
    Cut and plate the body mount, flatten the pinch weld, throw the sway bar in the trash, trim the stock bumper if you have one and the stock skid if you have one.
    We’re still stock geared with no immediate reason to change. If you have the tow package you have 4.30 gears so it’s no biggie. If you have the non-tow package 4.10 gears, you’ll want to regear. The Tow/Haul button is the indicator - if you have that, you have 4.30.
    Bent shaft on one someplace. It was a picture I saw, so it could’ve been photoshopped by the cabal. :rofl:
    Word
  21. Mar 16, 2018 at 2:41 PM
    #111
    jdavenport
    Justin
    So I should be okay on a icon alloy speed 6 17x8.5, 5.75 backspacing, 25 offset then? I have TC ucas. Again thank you everyone for all the help, it's been more than helpful.
  22. Mar 16, 2018 at 2:44 PM
    #112
    n2deep
    You guys suck- LT > 37's anyway
    M C M and osidepunker like this.
  23. Mar 16, 2018 at 3:19 PM
    #113
    KevinK
    Tundras to Sedona
    Yeah those Speed Six will definitely work. Can’t wait to see you put it together!
    LT + 37s = The Golden Goose
  24. Mar 16, 2018 at 3:21 PM
    #114
    n2deep
    Wrong again sucker
    LT + 40's = The Golden Goose LOL
    KevinK[QUOTED] and osidepunker like this.
  25. Mar 16, 2018 at 3:21 PM
    #115
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm not convinced...
  26. Mar 16, 2018 at 3:46 PM
    #116
    jdavenport
    Justin
    Awesome thank you. Now it's just whether I want my DD on 37s. I plan on doing long raod trips and i dont want my truck to suffer bc of the bigger tires. I keep going back and forth.
  27. Mar 16, 2018 at 4:01 PM
    #117
    KevinK
    Tundras to Sedona
    You will when you have 37s under The Truck.
    Our truck is my wife’s daily driver. And we just did 4500 miles from AZ to OH and back. Aside from the bad alignment killing 2 tires (would have happened regardless of size. We somehow had 5/8” toe out) they were perfect. We’ve been on 37s for two years and 30k miles.
  28. Mar 16, 2018 at 4:03 PM
    #118
    jdavenport
    Justin
    Nothing besides a loss of power huh? I just don't want to be reducing the life of my drivetrain by over stressing it. But if it's minimal differences I'm for it.
  29. Mar 16, 2018 at 6:31 PM
    #119
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    wrong again
    LT+40's+bracket lift > everything
    Help likes this.
  30. Mar 16, 2018 at 6:32 PM
    #120
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I drive a lot i have 175K + miles and 75 k have been on 37's never a problem or doubt in mind mind, would do it again
    Watt maker likes this.
