Suspension advice
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Jan 24, 2018 at 7:16 PM
    Tundra1794E
    Tundra1794E [OP] New Member
    Victoria B.C Canada
    2014 tundra 1794
    New to the forum , looking at giving my 1794 edition 2014 a lift, was told not to go over 4"? I wanted to give her a 6" lift . Not sure what the issue is going over 4" lift? Anyone have any legit input ? Thanks in advance
  2. Jan 24, 2018 at 7:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can lift it 6". It involves cutting a cross member. Be sure to do your research on what the best 6" lift is. 4 " is about the limit w/o cutting the cross member.
  3. Jan 24, 2018 at 7:35 PM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona
  4. Jan 24, 2018 at 7:40 PM
    Tundra1794E
    Victoria B.C Canada
    2014 tundra 1794
    is that the only issue with lifting it 6"? Does it cause any wear on cv's? I read the boots can tear, but there is a upgrade boot from you can get but that's least of my worries, I think 6" lift with 35s is the perfect look but was told over 4" will cause issues ?
