Supe's 2018 MGM SR5 CM SPORT Build
Discussion in '2.5 Gen Builds (2014-2021)' started by r1-superstar, Jan 16, 2019.
  1. Apr 17, 2019 at 7:17 AM
    #121
    r1-superstar
    r1-superstar [OP] Kailua Boy
    DB
    UTAH
    Thanks for the kind words! As for loading and unloading; loading a sportbike lifted will be a challenge and it will bottom out. If you are a seasoned vet to riding, dirt bikes will be easy. I use my stand in the garage and anywhere else that's flat. When I ride dirt, I always look for a dip to put the rear tires in to lower the back of the truck.
    G2G[QUOTED] likes this.
  2. Apr 17, 2019 at 7:18 AM
    #122
    r1-superstar
    DB
    UTAH
    They are as thick as the clamps. 3/8" of I believe. Just enough to make them sit level.
  3. May 7, 2019 at 5:12 AM
    #123
    BC.TRD
    BC.TRD New Member
    2019 TRD OFF ROAD CEMENT
    I have the 5100s with 2 shims on driver and 1 on passenger going on and stock rear. Do you think I'd be able to run a 18x9 +25 with the 305/65/18 like yours? did you have to CMC?
  4. May 17, 2019 at 6:28 PM
    #124
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Confused truck...is it a large SUV with a small bed, or a large SUV with a small bed truck stuck up its butt? I can't tell if it wants to be an SUV or a pickup. What is that, a 3 ft. bed? Hold a lot of groceries? Nice paint. :crapstorm: There's got to be a cut-off point to what constitutes a truck and what constitutes a pregnant station wagon with 4x4 capability. :poking:
    Love me the first gen, love me long time. :redxfall: :boom:
  5. May 17, 2019 at 7:22 PM
    #125
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    great looking truck... definitely following this build!
    MGM SPORT TEAM!!!!
  6. May 23, 2019 at 3:12 PM
    #126
    r1-superstar
    DB
    UTAH
    Sure you will be able to. I only had to remove the front flaps on the bumper and heat the back of the inside of the bumper and the front flaps on the fender. But only slightly. Pics when you are DONE!
    BC.TRD[QUOTED] likes this.
  7. May 23, 2019 at 3:13 PM
    #127
    r1-superstar
    DB
    UTAH
    Thanks! Your truck looks GREAT as well! MGM Rules!
    TheFreshMouse[QUOTED] likes this.
  8. May 23, 2019 at 3:15 PM
    #128
    r1-superstar
    DB
    UTAH
    You enjoy your truck and I will mine. :thumbsup: THIS CM SPORT TUNDRA does everything I need it to and does it well. Yes, it's a TRUCK! A TRUCK that everyone admires for having a lot of room in it when they climb in. I haul what I need in the back. If it doesn't fit; I use my trailer.
    Cheers!
    db
    GELCW and GODZILLA like this.
  9. May 23, 2019 at 5:31 PM
    #129
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    i'm confused too... confused as to why he thinks that previous post on someones build page was appropriate... especially when its posted in the 3rd gen section...
    :der::facepalm::lalala:
    GODZILLA and CO_Native like this.
  10. Jun 9, 2019 at 6:52 AM
    #130
    r1-superstar
    DB
    UTAH
    "pregnant station wagon" is at it again. Pleasing me with the abilities of 4x4, carrying what I need where I need it. :D
    GODZILLA, Beni36ti, CO_Native and 3 others like this.
  11. Jul 4, 2019 at 9:17 PM
    #131
    2chains
    2chains New Member
    Southern Ablerta
    Looks great really want to do the Q charger install..thanks for the idea for that location. How are you liking the tonneau cover? Looking to get one that would work with the Victory bed rack.
  12. Sep 21, 2019 at 8:20 AM
    #132
    r1-superstar
    DB
    UTAH
    Your welcome on the ideas. I really like my tonneau cover. It works well, is holding up great, and is exactly what I needed for my applications and uses.
  13. Nov 19, 2019 at 9:05 PM
    #133
    r1-superstar
    DB
    UTAH
    No mods as of late, just enjoying this Tundra on and OFF road!
  14. Nov 27, 2019 at 6:43 PM
    #134
    gabewhite
    gabewhite New Member
    2020 Tundra TRD Sport
    Stock...for now.
    I just posted in another thread replying to one of your posts but then ran across your build thread. Truck looks AMAZING!! I have just brought home a 2020 Tundra TRD Sport in this color. I want to level it but don’t want to alter the suspension too much. This may be the same question as above but do you feel your wheel and tire setup would have worked fine with the 5100s on the middle setting up front? It looked pretty level like that and I am thinking that’s the route I want to go...5100s on middle setting and leave the rear stock.
    Thanks!
    r1-superstar[OP] likes this.
  15. Nov 30, 2019 at 8:50 PM
    #135
    r1-superstar
    DB
    UTAH
    @gabewhite Congrats on your purchase!!! And thank you for the kind words. As for the suspension, I think I would have had more rubbing on the middle setting with the tire size I'm running. On the top setting, I barely rub but I did still have to heat the inside (front and back) of both wheel wells/bumpers and removed the front mud flap that's attached to the bumper. I'm running Ray 10s Gunmetal 18x9 +25mm with Falken Wildpeak AT3s 305/65-18.
  16. Dec 7, 2019 at 7:02 AM
    #136
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Stumbled across your build when searching for some reviews on Wilkpeak tires and sizes. Great looking truck man; especially that wheel and tire combination... :thumbsup:
  17. Dec 7, 2019 at 7:28 PM
    #137
    favStaR
    favStaR New Member
    2020 Tundra TRD Sport Premium
    Awesome truck dude! I have a 2020 TRD Sport and would like to go with 18” wheels instead of 20” as well, so many more options and I just can’t find 20’s that I like. How much clearance do you have between the calipers and the the inside of the wheel?
    Looking at my 20” stock rims it looks like going with 18’s would be extremely tight on the front calipers, about 1 3/16” clearance with the 20’s if I lose an inch and add balancing magnets it would be really really close. Did you run into any issues?
  18. Dec 15, 2019 at 12:33 PM
    #138
    JOrnelas
    JOrnelas New Member
    2020 Black Tundra TRD Sport
    Where did you get your tint done? and what %, I am looking for a place that will go darker.
  19. Jan 10, 2020 at 7:56 AM
    #139
    r1-superstar
    DB
    UTAH
    Thank you!
  20. Jan 10, 2020 at 7:57 AM
    #140
    r1-superstar
    DB
    UTAH
    Thank you!
    No issues at all. A lot of clearance.
  21. Jan 10, 2020 at 8:06 AM
    #141
    r1-superstar
    DB
    UTAH
    I would go darker too but it's hard to see at night. I went with ceramic on all the windows. 50% on the windshield, 35% on the front windows, and 25% on the rest (over the factory tint). The ceramic really cuts down on the UV and heat.
    JOrnelas[QUOTED] likes this.
  22. Jan 25, 2020 at 6:18 PM
    #142
    r1-superstar
    DB
    UTAH
    Out with the 5100s, in with the 6112s!!! Thanks @BOSS4x4s for the awesome price and fast shipping. It was a ninety minute install. 6112s are so much beefier than the 5100s and they ride SOOOO MUCH BETTER!!!! I had them assembled at the top setting (2.5") and are the same length as the 5100s on the top setting.
    Flyinryank and drobb like this.
  23. Jan 27, 2020 at 10:07 AM
    #143
    r1-superstar
    DB
    UTAH
    How my Tundra sits right now. :cool:
    tundra_uso, TRDblvd, JOrnelas and 2 others like this.
  24. Jan 28, 2020 at 5:21 PM
    #144
    vhstejskal
    Vic
    Build looks great man. The before and after pics looks phenomenal. :bowdown:
    Mind if I ask what shop did you take to get your alignment done? I’ve been looking at SPCs and trying to find someone that will know how to align things.
  25. Jan 28, 2020 at 5:26 PM
    #145
    r1-superstar
    DB
    UTAH
    Thank you for the kind words. Here in SLC it's Les Schwab. Get your SPCs from Darren @BOSS4x4s
    vhstejskal[QUOTED] likes this.
  26. Jan 28, 2020 at 5:28 PM
    #146
    vhstejskal
    Vic
    Thank you sir.
  27. Mar 30, 2020 at 10:21 AM
    #147
    BC.TRD
    BC.TRD New Member
    Why the switch to 6112? I plan on bumping my 5100 to top with a shim on driver to fit 295/70/18 properly.
  28. Apr 15, 2020 at 7:34 PM
    #148
    r1-superstar
    DB
    UTAH
    Ride quality. 5100s at top setting w/OEM springs were kinda harsh. The 6112s came with Eibach springs, more coils, longer spring, different wind = nicer ride.
  29. Apr 24, 2020 at 9:33 AM
    #149
    r1-superstar
    DB
    UTAH
    6112s off road are NICE!
    a_double, tdawson05 and Yzed608 like this.
  30. May 19, 2020 at 11:00 AM
    #150
    a_double
    a_double New Member
    Your truck looks great. I'm convinced on this wheel spec and tire size after looking at your build :thumbsup:
    What would you say your lift is in terms of inches? TIA.
    Edit: Nevermind, I found a post with the answer. 3/2
