Supe's 2018 MGM SR5 CM SPORT Build
Discussion in '2.5 Gen Builds (2014-2021)' started by r1-superstar, Jan 16, 2019.
  1. Mar 6, 2019 at 12:37 PM
    #61
    r1-superstar
    r1-superstar [OP] Kailua Boy
    DB
    UTAH
    Some close up pics...
  2. Mar 6, 2019 at 2:51 PM
    #62
    Markman
    Markman New Member
    Mark
    Utah
    2019 limited cement cm
    Tint airbags daystar cradles Elka suspension bushwacker flares
    Nice build truck looks good great job!!
    r1-superstar[OP] likes this.
  3. Mar 6, 2019 at 5:03 PM
    #63
    r1-superstar
    DB
    UTAH
    @Markman Thank you!
  4. Mar 7, 2019 at 8:44 AM
    #64
    r1-superstar
    DB
    UTAH
    Comparison:
    Bone Stock
    Bilstein 5100 Leveling Shock middle setting
    Bilstein 5100 Leveling Shock top setting w/shims, @BOSS4x4s Shackles top setting
    Ray 10s 18x9 +25mm offset, Falken Wildpeak AT3s 305/65-18; suspension same as above
    Ray 10s 18x9 +25mm offset, Falken Wildpeak AT3s 305/65-18; 6112/5100 and Boss shackles on top setting.
  5. Mar 7, 2019 at 9:42 AM
    #65
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    Nice, those Sport wheels look good but have a street feel to them. These Ray 10's have a more aggressive look.
  6. Mar 7, 2019 at 5:23 PM
    #66
    r1-superstar
    DB
    UTAH
    Tire poke...
  7. Mar 7, 2019 at 5:34 PM
    #67
    MJ_19Tundra
    MJ_19Tundra Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2025 TRD MUDBATH
    Do you mind telling me the wires on the stock amp that you tapped into LC2I? Wanting to do the upgrade but nervous about tearing into it. Want a strait understanding before starting.
  8. Mar 7, 2019 at 5:48 PM
    #68
    eric1
    eric1 New Member
    2019 Tundra SR5
    Looks great!
  9. Mar 7, 2019 at 5:58 PM
    #69
    r1-superstar
    DB
    UTAH
    I have spent years fiddling with and installing car stereos (20 to be exact). To be quite honest, I had the dealer install this one. Since it was being tapped into the factory harness, I didn't want to mess with it. If I were replacing the entire system, I would have done it myself. I can look at what they did if that helps. Just let me know what pics you need.
  10. Mar 7, 2019 at 5:59 PM
    #70
    r1-superstar
    DB
    UTAH
    Thanks @eric1
  11. Mar 7, 2019 at 6:02 PM
    #71
    MJ_19Tundra
    Ben
    Nashville, TN
    2025 TRD MUDBATH
    I know there are a few threads showing what it is and what not but yours looked very simple. From the pics, it looks like they tapped into a few wires from one side of the factory amp and hooked them into the LC2I. Then ran RCA cables from LC2I to the new amp along with power wire from battery to new amp. Then speaker wire from new amp to subs.
  12. Mar 7, 2019 at 6:07 PM
    #72
    TRDSam
    TRDSam New Member
    Sam
    2019 Black Tundra TRD Sport
    2.4" level, Dealer installed Remote Start,
    killer setup
  13. Mar 7, 2019 at 6:20 PM
    #73
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Truck looks great! May I ask why you went with 5100’s vs 6112’s, stock UCA’s, height of rear shackles, and any rubbing of trimming necessary for those tires?
  14. Mar 7, 2019 at 6:22 PM
    #74
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    Love the ride, rims and tires are money!
  15. Mar 7, 2019 at 6:36 PM
    #75
    r1-superstar
    DB
    UTAH
    You are probably correct in that description.
  16. Mar 7, 2019 at 6:43 PM
    #76
    r1-superstar
    DB
    UTAH
    I went with the 5100 leveling shocks back in June since I wanted to level it. I had no intention to go higher. I also chose the 5100s in the rear. I didn't want to spend too much money on the suspension since I'm not off-roading hardcore, not even mediocre. The 5100s are perfect for my application and uses. I'm mainly hitting fire roads, small trails and hills, going to and from dirt bike riding areas, etc... Now If I was going somewhere like Moab, I would have chosen a different setup.
    I ordered SPC UCAs from @BOSS4x4s yesterday since my alignment adjustments are maxed out and the driver's side caster is off. I was hoping that I wouldn't have to with the 3" lift up front; not so lucky. The rear shackles are also from @BOSS4x4s and are adjustable and set at the highest setting. It gave me a 2" lift in the rear. I removed the small forward mudflaps up front and I did have rubbing on the inner fender well. I hit it with a heat gun but still have a bit more to go. Nothing major, no body or cab mount chops required.
  17. Mar 7, 2019 at 6:44 PM
    #77
    r1-superstar
    DB
    UTAH
    Thank you! The wife, kids, and I are happy with how it turned out.
  18. Mar 7, 2019 at 6:45 PM
    #78
    dlowry81
    dlowry81 New Member
    Doug
    Thank you. Sounds like I need to hold off on the Led headlights and opt for the UCA’s.
  19. Mar 7, 2019 at 7:03 PM
    #79
    r1-superstar
    DB
    UTAH
    I would.:thumbsup:
  20. Mar 9, 2019 at 12:42 PM
    #80
    dlowry81
    dlowry81 New Member
    Doug
    From the 5100's in the middle and stock tires compared to your current setup what are your overall thoughts on how it drives? Significantly harsher, worse turning radius, or any other negatives that accompany getting your truck looking that sweet?
  21. Mar 9, 2019 at 3:27 PM
    #81
    r1-superstar
    DB
    UTAH
    Thanks, much appreciated! The turning radius is the same. The ride is about the same; figuring the front is at the top setting and shims added w/18s compared to middle setting, no shims and 20's. It just rubs slightly on the inner fender well behind the bumper. I got it all heated up and taken care of.
  22. Mar 12, 2019 at 1:32 PM
    #82
    kevin9763
    kevin9763 New Member
    Kevin
    North Carolina
    2018 tundra platinum
    Borla exhaust, k&n cai,
    Any problems with the winjet tails? Do you like them?
  23. Mar 12, 2019 at 1:40 PM
    #83
    r1-superstar
    DB
    UTAH
    I had an issue with one of the lights (driver's side) upon arrival. One of the LED side markers were not working and the other was pointing in the wrong direction. The seller sent me a replacement and it too had problems. One LED side marker was out. I got a full refund and still got to keep the driver's side. Other than that, they are still going *knock on wood.
    kevin9763[QUOTED] likes this.
  24. Mar 12, 2019 at 4:04 PM
    #84
    kevin9763
    Kevin
    North Carolina
    Thanks for the reply!
  25. Mar 12, 2019 at 4:28 PM
    #85
    r1-superstar
    DB
    UTAH
    Of course!!
  26. Mar 12, 2019 at 5:56 PM
    #86
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    Congrats!! Your truck came out looking awesome man!
  27. Mar 12, 2019 at 9:50 PM
    #87
    r1-superstar
    DB
    UTAH
    Thanks! @CCTundra
  28. Mar 13, 2019 at 5:42 AM
    #88
    STITCHv
    STITCHv New Member
    This thing is sweet, I thought I finally made my mind up that I was going to get a TRD Off Road but the Sport looks bad a$$ after mods!
  29. Mar 13, 2019 at 5:58 AM
    #89
    r1-superstar
    DB
    UTAH
    Thanks! For us it was the right Tundra and package. Post pics when you get yours.
  30. Mar 13, 2019 at 8:13 AM
    #90
    r1-superstar
    DB
    UTAH
    So many "clean" pics of mods done. Here is a pic of my truck in the snow of suburbia. These Falken Wildpeaks work well in the snow, slush, and ice. Stopping performance is Fantastic!!
