Supernova V.4 LED’s
Discussion in 'Lighting' started by bdpeelgren, Dec 30, 2018.
  1. Jan 9, 2019 at 6:17 PM
    #91
    bdpeelgren
    bdpeelgren [OP] New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    No problem! If you do, just check all the connections.
  2. Jan 9, 2019 at 6:30 PM
    #92
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    Yes sir will do. Looks like a great improvement over our stock dim lights
  3. Jan 11, 2019 at 11:45 AM
    #93
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Which one did u buy. They show 3 types on their website. 5202/2504. 9004 or 9005/9145
    Thanks.
  4. Jan 11, 2019 at 4:03 PM
    #94
    bdpeelgren
    Round Rock, TX
  5. Jan 11, 2019 at 4:05 PM
    #95
    bdpeelgren
    Round Rock, TX
    9003/H4
  6. Jan 11, 2019 at 4:28 PM
    #96
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Yep H4/9003
    Just installed them today, will report back tonight with the results. Broke the right lower tab off the grill pulling it off, that sucked!:frusty: Everything else went straightforward. If you do this in the cold have a heat gun or hair dryer around, allows for the plastic tabs to be removed easier. Installed mine outside on the snowy driveway.
    You can hear the fans when lights are on, just barley. You can't hear a thing when the truck is running. On the positive note if I ever buy the 19 headlights the install will easy since it's the same procedure. Stay tuned:popcorn:
  7. Jan 11, 2019 at 5:00 PM
    #97
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Thanks guys. I tried to call the co several times but nobody would pick up the phone. Yes please report back w good news
  8. Jan 11, 2019 at 6:11 PM
    #98
    alpinepro4
    Pat
    Here are the results. There is scatter in these bulbs. I did a test drive in some thick fog. Scatter seemed to light up layers of fog, hard to describe what I saw. Will see how they do in a snow storm. We have one coming in a few days. Overall they put out much more light than OEM bulbs. Snow storm will be the test weather I keep them.
    12-15 feet away from the wall here
    Headlights Only
    Head lights with Baja Designs Sqadron Sports fogs
    Headlights in the fog
  9. Jan 11, 2019 at 6:25 PM
    #99
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
  10. Jan 11, 2019 at 6:44 PM
    #100
    alpinepro4
    Pat
  11. Jan 11, 2019 at 6:52 PM
    #101
    tundracap
    NC
    Same here.
  12. Jan 11, 2019 at 6:54 PM
    #102
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    That is way better than our stock yellow. Thanks for posting your results. I esp like the pic w the fogs on. I will go ahead and buy a set. I'm in Houston so theres rarely 0 fog
    bdpeelgren[OP] likes this.
  13. Jan 11, 2019 at 6:58 PM
    #103
    alpinepro4
    Pat
    Now that I think about it, it's a lot better than OEM output. Boots that better output then your 18 headlights?
  14. Jan 11, 2019 at 7:05 PM
    #104
    tundracap
    NC
    Same for me in 2017 CM Limited.
    I tried a Sylvania replacement for the OEM bulb first and was underwhelmed. Then this site started costing me $ when I found the Headlight Revolution video, Baja Design Squadron fogs.
    It's ON now....$$$$$
  15. Jan 11, 2019 at 7:08 PM
    #105
    alpinepro4
    Pat
    Yeah your in the black hole now brother. BD squadrons I have are only 2300 lumens per side. new ones are 3100 lumens. They are wide cornering lenses I use.
    tundracap[QUOTED] likes this.
  16. Jan 11, 2019 at 7:32 PM
    #106
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    I think the beam as good too. Reflectors will have some scatter I general. As far as the fog, we'll that isn't scatter coming back at you. It's just the brighter light reflecting back at you. The dinner halogens may not do it as pronounced with dimmer bulbs as the brighter leds. I have a 2019 Camry XSE and it has led headlights and in the fog the same thing happens.
  17. Jan 11, 2019 at 7:38 PM
    #107
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Yes it's way better than mine. I drive on pitch dark roads sometimes in louisanna and our stock lights suck. Now theres fog there because the sh IPO p yards are there so better lights will be useful
  18. Jan 11, 2019 at 7:40 PM
    #108
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Yes I'll order those as well after seeing these pics. Blame it on him lol
  19. Jan 11, 2019 at 7:44 PM
    #109
    alpinepro4
    Pat
    Went out for another drive in dense fog visibility was maybe 10-15ft. These lights do kick ass!
    Headlights only
    Baja Designs Sqadron Sport and lights.
  20. Jan 11, 2019 at 7:46 PM
    #110
    alpinepro4
    Pat
    Aren’t your 18 headlights LED with DRL’s?
  21. Jan 11, 2019 at 7:48 PM
    #111
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Damn bro where do u live. I dont want that cold weather
  22. Jan 11, 2019 at 7:50 PM
    #112
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    No mine aren't led. The yr 19 are led. Plus I turned my drl off
  23. Jan 11, 2019 at 7:52 PM
    #113
    alpinepro4
    Pat
    Ok that makes sense.
  24. Jan 11, 2019 at 7:53 PM
    #114
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
  25. Jan 11, 2019 at 7:54 PM
    #115
    alpinepro4
    Pat
    Damn good looking truck!
    Boots likes this.
  26. Jan 11, 2019 at 7:57 PM
    #116
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Going to place my order now for hl and fogs
  27. Jan 11, 2019 at 7:59 PM
    #117
    alpinepro4
    Pat
    Right on :spending:
    I should be a representative for Baja Designs and HR. Baja Designs is what started it all for me.
  28. Jan 11, 2019 at 7:59 PM
    #118
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Thanks pat. I also have the sq1 taco tunes in it. It hits hard
  29. Jan 11, 2019 at 8:01 PM
    #119
    alpinepro4
    Pat
    Jackson, WY. My truck read 1 degree when taking these photos.
  30. Jan 11, 2019 at 8:09 PM
    #120
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Damn that bro. Pebbles size small in that weather
