Supercharger long term reliability?
Discussion in 'Performance and Tuning' started by BenAZ, Mar 23, 2017.
  1. Apr 26, 2021 at 6:09 AM
    #211
    Saltyhero13
    Saltyhero13 Throbbing Member
    So far Magnuson is only supporting 2019s and below: https://www.magnusonsuperchargers.com/product-p/01-19-57-109-bl.htm
    2018s and older are using HP Tuner, 2019 is using OV Tuner and will probably be used for 2020 and 2021.
    As of now, the only option for 2020 and 2021 is the Harrop Stage 1. According to Harrop it doesn't require a tune even though they recommend one. A couple of us are getting Harrops installed within the next couple of weeks. Keep an eye out to see if this is an option for you.
    Wynnded and Platinum714 like this.
  2. Apr 26, 2021 at 7:24 AM
    #212
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    Thanks... I will do that. Please keep me posted on the results.
    Saltyhero13[QUOTED] likes this.
  3. Apr 28, 2021 at 6:55 AM
    #213
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Couldn't find an answer to this in a search ... so here's a general question: in the event you're on the road and need fuel, but the station doesn't have high octane gas, what's the solution? My first thought would be to carry a case of fuel additive/octane boost with me for these situations if I had to run std or mid-grade - has anybody done this and noted any issues or changes?
    HulkSmurf14 and Saltyhero13 like this.
  4. Apr 28, 2021 at 7:21 AM
    #214
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    That would work.
    Shuffler[QUOTED] likes this.
  5. Apr 28, 2021 at 7:24 AM
    #215
    Coupe
    Coupe New Member
    James
    Houston, Texas
    This is a little out of context, but I have a TRD supercharger on an Xrunner w/a smaller pulley(so more boost). I currently have over 100K on the engine and 80K on the supercharger. I have changed the oil in the supercharger once in that time period.
    So far I have had no engine related problems.
    Dr Doobie, Warreng, Wynnded and 2 others like this.
  6. May 1, 2021 at 12:54 PM
    #216
    Normak
    Normak New Member
    I just hit 30k, no issues. 2017 DC 4x4 5.7 installed right after the break-in period. Only thing I've noticed is noisy injectors.
    Oil every 5k, even though it calls for 10k interval.
    I'll floor it whenever I want to because that's the point of having it. But my usual driving style reflects that I want it to last. Like no full throttle until it's warm, etc.
    Miles are primarily highway, but the hours on the motor are start/stop/short trips. The truck sits all week, does errands on the weekend (maybe 10 miles total). Then road trips; 600-1000 mi round trip. River, Desert, up the coast, etc. and some occasional project type stuff, full size trailer to the dump, materials runs, etc.
  7. May 1, 2021 at 8:09 PM
    #217
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Some have mentioned if you dont go wot, you should be ok.
    snivilous likes this.
  8. Jun 16, 2021 at 9:57 PM
    #218
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    What octane/fuel type is everyone running with the Magnuson Superchargers?
  9. Jun 16, 2021 at 10:04 PM
    #219
    AZTundra
    Paul
    Phoenix, AZ
    91 premium. Best we have out here in AZ.
    HulkSmurf14, BenAZ[OP] and snivilous like this.
  10. Jun 16, 2021 at 10:06 PM
    #220
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Same^ use whatever is highest, usually that's 91 E10 here in Utah
    HulkSmurf14 and AZTundra like this.
  11. Jun 17, 2021 at 7:01 AM
    #221
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I use non-ethanol 91 in the mountains of MT; it costs right now about $3.69/gal...but I've been getting the best MPG and power delivery this truck has ever seen so I'm okay with the cost...just bought a thing of Boostane for a trip thru rural country...just in case...
    AZTundra and Saltyhero13 like this.
  12. Jun 17, 2021 at 9:23 AM
    #222
    ZPMAN
    Minnesota
    I use Pure Gas app on phone (https://www.pure-gas.org/) when going on trips and also carry a can of boostane, sometimes you can get a bad 91.
    Saltyhero13, AZTundra and HulkSmurf14 like this.
  13. Jun 17, 2021 at 9:39 AM
    #223
    HulkSmurf14
    2014 Tundra Limited
    I'll try the app out...it will be helpful in areas I'm not "certain" of the fuel...I am however surprised at how many non-Eth stations I live near! Bonus!
    Saltyhero13 likes this.
  14. Jun 17, 2021 at 9:53 AM
    #224
    AZTundra
    Paul
    Phoenix, AZ
    Ever use Torco? If so, which brand do you prefer between that and Boostane? Are there any negative side effects with moderate use? I still have very slight pinging when in high gear and low rpm and applying moderate throttle to accelerate. Planning for a custom tune, but still haven't gotten around to it.
    Platinum714 and Saltyhero13 like this.
  15. Jun 17, 2021 at 9:58 AM
    #225
    HulkSmurf14
    2014 Tundra Limited
    Boostane is my preference...I've used Torco one other time; I didn't have any negative effects, but I like Boostane's products more as I've used them on all my boosted vehicles...I feel I get the most "umph" with it...might be placebo but my mind is made up :burnrubber:
    **If you have pinging, you're needing better fuel...or a safe tune...no issue using it but if you're FFV, I'm not certain how it effects your gaskets/O-rings/blah blah blah...I do know that if I put in non-ethanol fuel or a fuel octane booster on my bikes, quads, lawn mowers, and anything with a motor really, they all run better, go further on a tank, make less noise (engine rattles, etc) and I don't need to stabilize the fuel from gelling up and gumming up the carburetors and fuel filters...
    Saltyhero13 and AZTundra like this.
  16. Jun 17, 2021 at 10:21 AM
    #226
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I'm running 94 octane when I can find it, I also use BG 44K. My first Tundra had 45k on the TRD Supercharger with no issues at all using a bully dog tuner. This truck has 17k on it, so far so good. Change the oil every 3-4k miles but I only put about 5k miles a year on it.
  17. Jun 17, 2021 at 10:24 AM
    #227
    HulkSmurf14
    2014 Tundra Limited
    BG44k is amazing fuel treatment/cleaner/power adder! I use it on the German cars. I think Boostane gives a little more of everything - - at least in my experience...they are priced roughly the same though...
  18. Jun 17, 2021 at 10:37 AM
    #228
    AZTundra
    Paul
    Phoenix, AZ
    I'll try out the Boostane and see if that helps any. It seems that QT gas has less pinging or at least that's what my ears tell me. Yes, I am flex fuel. I really need to get it in for a custom tune. That will help me know everything is as it should be.
  19. Nov 27, 2021 at 9:15 PM
    #229
    wyso
    wyso New Member
    chris
    2010 Tunda
    TRD supercharger, big brake kit, 22 TRD wheels
    I am at 151k. Blower installed at 10k. Sending blower for a 150k rebuild over the winter.
  20. Jan 26, 2022 at 8:19 AM
    #230
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Update on this one? Still have it or sold it?
  21. Jan 31, 2022 at 5:30 PM
    #231
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    7 years, no issues. Still runs like a raped ape.
    nasher75, Joro43, HulkSmurf14 and 3 others like this.
  22. Jan 31, 2022 at 5:41 PM
    #232
    AZTundra
    Paul
    Phoenix, AZ
    How often are you swapping new plugs in? I'm at 21K miles on mine and just bought a set of Denso IKH22's from URD for only $7.99 each - they are 28% off right now. I was planning to replace mine before 25K.
  23. Jan 31, 2022 at 5:53 PM
    #233
    Vector W8
    Have not replaced my plugs yet.
    Joro43, HulkSmurf14 and AZTundra like this.
  24. Jan 31, 2022 at 5:58 PM
    #234
    AZTundra
    Paul
    Phoenix, AZ
    Maybe I'm wrong, but thought it was around a 30K mile interval on plugs after the supercharger install. :monocle:
  25. Jan 31, 2022 at 6:06 PM
    #235
    Vector W8
    Not that I'm aware of.
    AZTundra likes this.
  26. Jan 31, 2022 at 6:24 PM
    #236
    HulkSmurf14
    2014 Tundra Limited
    I'm at 60k miles on my SCr and haven't done anything to it but drive it...once I edge closer to the maintenance interval (in another year or so) I will have everything freshened up...should be no different than a "regular" tundra...
    AZTundra and Vector W8 like this.
  27. Jun 23, 2024 at 5:37 PM
    #237
    JohnWhicker
    JohnWhicker New Member
    Resurrecting this thread. Any Magnuson 2650 in the house? How are they doing in terms of reliability? I know they're a bit newer but still wondering.
  28. Jun 23, 2024 at 5:54 PM
    #238
    Saltyhero13
    Fair question. IMO the quality of the tune (and tuner) and having appropriate supporting mods for your power level will have more impact on reliability than the actual blower selected.
    ARES35 likes this.
  29. Jun 23, 2024 at 6:35 PM
    #239
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No issues with mine, it's quieter than my 1900 was in terms of whine.
    Saltyhero13 and ARES35 like this.
  30. Jun 23, 2024 at 7:05 PM
    #240
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    I have a 2012 sr5 s/c. Been s/c since 2013 at 26k. I now have 248k. I have not serviced the s/c. I spoke with Magnusen and was told when it goes bad service it. The engine has not been a problem nor the transmission. I tow a pressure washing rig (approx 3200lbs.) 90 % of the times. It has been great. I use premium fuel (93 octane), I also have a 2019 trd off-road limited. Keep it stock. Did not want to fill 30+gallons of premium.
    the truck still looks amazing runs great. I did normal service intervals per owners manual. I had a leak in radiator after 200k but that’s it
