Supercharger issue
Discussion in 'Performance and Tuning' started by mohd.darmaki, Aug 20, 2018.
  1. Aug 20, 2018 at 3:24 PM
    mohd.darmaki
    mohd.darmaki [OP] New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    Am facing an issue with my Tundra 2017 platinum i installed short headers , TRD Intake, TRD Daul Exhaust , Magnsoun Supercharger and programmed it into the dyno with Tundra computer
    I see my Truck is very heavy plus it keeps cutting example if i press the gas it cuts and then pulls its self ist from the stupid TRD Intake , or ist from header short couldnt know whats the problem had any body went through this issues pls share with me your comments .
    kcaustin66 likes this.
  2. Aug 20, 2018 at 4:08 PM
    It’s almost like it’s not enough fuel getting to it
    ColoradoTJ likes this.
  3. Aug 21, 2018 at 12:07 AM
    mohd.darmaki
    Mohammed
    I willafter i change the TRD Intake and install racing filter plus installing the gear valve i will put it back to the dyno hope
    GNTundra likes this.
  4. Aug 21, 2018 at 12:08 AM
    mohd.darmaki
    Mohammed
    Thank you for sharing me ur comments
    Do you thinks its the fuel pump although the car is almost brand new only 3 k miles
  5. Aug 21, 2018 at 12:08 AM
    mohd.darmaki
    Mohammed
    Yes sir
    ColoradoTJ and GNTundra like this.
  6. Aug 21, 2018 at 12:12 AM
    mohd.darmaki
    Mohammed
    D964DA58-1692-49E3-A978-0AAC4B18CD7A.jpg F35C48E1-3C37-4C15-A4C7-175F3DF3D8D7.jpg
    yes sir i think this is whats killing the power of the car
  7. Aug 21, 2018 at 12:55 AM
    mohd.darmaki
    Mohammed
    Thank you sir
  8. Aug 21, 2018 at 12:56 AM
    mohd.darmaki
    Mohammed
    I think its the petrol
  9. Aug 21, 2018 at 1:56 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Ditto for me, I run my Magneson, Bully Dog tune, 93 octane and with the traction control off and the tow haul button on at all times. I actually have a PAC TR12 trigger control module that shuts those off at ignition. If you just push the button once like the previous video describes as an option the TC will turn back on when you spin your tires so it's better to completely disengage it. If you don't with the light rear end of the truck the tires will spin really easy and even if it's just a little the system will apply the brake and power down the engine making it feel like what you describe. I would also ditch the TRD Cold Air intake and put the air box in that came with the Magneson SC. The cold air intake isn't doing you any favors on the low end and the SC is designed for the intake that came with it. One more thing to consider although it might not be as noticeable with the SC, to help get a little more low end back is add an x-pipe to your exhaust or better yet get a Dirty Deeds TRD replacement exhaust as he puts an x-pipe in his and it will bolt right to your TRD tailpipes. Keith @dirtydeeds will definitely be able to shed some light on the subject.
  10. Aug 21, 2018 at 3:27 AM
    mohd.darmaki
    Mohammed
    No its not flex
  11. Aug 21, 2018 at 3:33 AM
    mohd.darmaki
    Mohammed
    I fully agree in what y wrote i will change the setup from short headers to long tube i will get rid of the intake and put the open plus i might change the oem fuel pump and install racing fuel pump plus i will install the gear valve but the question is which is better in programming dyno or while driving the car
  12. Aug 21, 2018 at 3:48 AM
    mohd.darmaki
    Mohammed
    No standard tundra computer i was scared no one can program it here in my country plus thought all lights will comee up in the dashboard an the most reason i didnt want to go high bost , i have big wheels 20x 12 and i could onnly make 380 soon i will change the setup hopefully i go upto 460 hp with thse big wheels if its possible
  13. Aug 21, 2018 at 9:49 PM
    Nick T
    Nick T New Member
    Nick
    You need to flash the TRD tune (not available for your year) or bullydog tune(should have come with magnuson supercharger kit). Change your fuel injectors and fuel pump ( these should also have come with your magnuson supercharger kit, they are higher flow)
    Without the higher flow injectors, fuel pump to feed the injectors, and tune your stock ecu cannot feed the required fuel to keep your afr in the safe zone. You will have detonation and the ecu will pull timing.
  14. Aug 21, 2018 at 10:01 PM
    So much this^^^
    15whtrd likes this.
  15. Aug 21, 2018 at 10:05 PM
    Welcome Mohammad. Been to Dubai many times. UAE can be a fun place.
    I would also say, do not drive the truck until you can run the tuning for your truck. Finding this might become troublesome.
    mohd.darmaki[OP] likes this.
  16. Aug 21, 2018 at 10:45 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    DITTO!! Park that thing if your tuner/installer did not instal the proper fuel management system, you could severely damage that 5.7.
    Any time you boost a rig you should have a Air/Fuel Ratio gauge too.
    Find a new shop, I’m sure there is many in Dubai.
    There is a Supercharged Lexus IS350 pushing 500+rwhp somewhere over there and his tuner/shop knows what they are doing. I’d highly recommend finding that shop.
    I’ll try to dig up his info.
    Eta - here’s a video of the shop/car
    https://m.youtube.com/watch?v=UCY_fufakZ0
    Just for fun - same guy pulling pretty hard on a twin turbo cls500
    https://m.youtube.com/watch?v=0Jv7XZ-H6uw#
    The kit that guy in Dubai uses is from rr-racing.
    This is the shop in the US that’s figured out how to actually tune a Toyota/Lexus ECU. They’re slow on developing, as I’m guessing their cracking codes as the years goes by. They’ve figured out Lexus up to 2017 and have successfuly put out a reliable SC kit for the bulletproof 3.5L lexus 2GR-FSE.
    https://www.rr-racing.com/v/mobile/home.asp
    15whtrd and ColoradoTJ[QUOTED] like this.
  17. Aug 22, 2018 at 2:14 AM
    mohd.darmaki
    Mohammed
    Uae is fun in the winter you should visit us
    Next week i will take the car to a friend garage he will add a lexus fuel pump gear valve and install long pipe for the headers and change the cold air intake to the open one filter plus push button for tracation control instead of stopping which take minutes plus re program it while driving not in the dyno
  18. Aug 22, 2018 at 2:18 AM
    mohd.darmaki
    Mohammed
    Yes sir there quiet good garages here whos been working in the 5.7 engines actually know they been taking out the MG superchargers and going to harrops super am talking my my car next week
  19. Aug 25, 2018 at 4:19 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Why is this in the suspension forum?
    T-Rex266 likes this.
  20. Aug 25, 2018 at 4:57 PM
    That was my fault. It must have scrolled up when I moved it from General Discussion.
    Fixed. :thumbsup:
