Supercharger install losing coolant
Discussion in 'Performance and Tuning' started by Kanekz, Jul 4, 2020.
  1. Jul 4, 2020 at 11:09 PM
    Kanekz
    Kanekz [OP] New Member
    Levi
    2019 1794 SC
    Finally got the magnuson up and running. Love the system. However, after my trips, after the cool down, my rad reservoir losing coolant, I don’t see it on the ground or in the engine bay. I checked oil just in case. While driving and it’s heated, it stays at the same level. I don’t know where it’s going.
  2. Jul 4, 2020 at 11:19 PM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    That's your overflow tank. The level will rise when the engine is hot, and drop when it's cool. Add coolant to the proper level when it is cold, and then see if it continues to drop before you worry.
    I'm not 100% sure, but does the addition of the SC change the required amount of coolant? Something similar to how adding a trans cooler changes your required amount of ATF?
    snivilous and HulkSmurf14 like this.
  3. Jul 4, 2020 at 11:54 PM
    Kanekz
    Levi
    2019 1794 SC
    3 separate trips it stays high when hot to where I filled it, then when cool it goes backdown. But I don’t see where it’s going. No evidence anywhere. I filled all 3 trips tho.
  4. Jul 4, 2020 at 11:56 PM
    Kanekz
    Levi
    2019 1794 SC
    First pic is where I filled up to first time, and 2nd pic is after the 2nd trip.
  5. Jul 5, 2020 at 12:06 AM
    Wyoming
    That would have me a little worried, but there could still be something like a pin hole in the radiator that could only be leaking when under pressure. Have you tried getting it up to temp in the driveway, maybe with a fresh sheet of cardboard under it, and then letting it cool while you watch to see if there are any minor leaks?
    Also, quick search shows you're not the first to have this puzzle. https://www.tundras.com/threads/losing-coolant-slowly.58471/
    MS22 likes this.
  6. Jul 5, 2020 at 5:58 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Does the system have a built in I/c where it bolts to the upper intake runners? Expanding Aluminum inter coolers bolted to an aluminum motor is always problematic in these type of systems due to all the expansion and contraction. Just one bolt torqued out of sequence or not exactly to spec can cause warping. I’ve also seen issues where a bolt hole in the head or intake wasn’t completely clean and gave false torque readings on the bolt.
  7. Jul 5, 2020 at 7:21 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Are you saying it stays high when hot and goes back down when cool? Without adding any coolant? If so thats how coolant works, thats why it has an overflow tank. If you were to fill the overflow to the top when cold, you would end up pissing out coolant when it gets hot because the coolant level rises from high temps.
    HulkSmurf14 likes this.
  8. Jul 5, 2020 at 7:03 PM
    Kanekz
    Levi
    2019 1794 SC
    Found this today
    GODZILLA likes this.
  9. Jul 5, 2020 at 7:04 PM
    Danman34
    Danman34 New Member
    Danny
    Damn. Safe to say, you have a considerable leak.
    You never smelled burning coolant? Seems like you would have easily smelled this.
  10. Jul 5, 2020 at 7:25 PM
    Wyoming
    I do believe that's your issue. :thumbsup: Good job finding it. Is it a hole in the hose, or loose clamps, or something more sinister like a crack in one of the hard fittings? I think I see a hole in the hose in the first pic, but it's so hard to tell over the interwebs.
  11. Jul 7, 2020 at 8:47 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Were you able to find the culprit? The photos show where you might find the leak, but were you able to define a solution?!
  12. Jul 7, 2020 at 9:35 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    X2, any ideas?
    FWIW: I had a pin-hole in the s/c coolant reservoir return hose...didn’t really leak until hot and it was slow. The dealer wasn’t checking the coolant reservoir and one day I noticed some stains and popped the cap off and it was low. Ultimately, I replaced the hose myself and no more leaks.
    RitcheyRch and HulkSmurf14 like this.
  13. Jul 7, 2020 at 9:37 AM
    HulkSmurf14
    2014 Tundra Limited
    Great to hear! I'm glad you found the issue and have been able to resolve the coolant leak!
    I hope the OP was able to find a similar success!
  14. Jul 7, 2020 at 5:55 PM
    I bet it was a hose given the spray pattern
  15. Jul 17, 2020 at 1:28 AM
    Kanekz
    Levi
    2019 1794 SC
    UPDATE
    I found the leak turns out the water pump bolt wasn’t secured all the way. Problem solved.
    now.....
    Fuel pump install to the provided one magnuson gave, my truck keeps stalling out. Gonna do a pressure test tomorrow on the pump to see if it’s faulty. Keep u guys updated.
    GODZILLA, HulkSmurf14 and Leo's first like this.
  16. Jul 17, 2020 at 12:01 PM
    Kanekz
    Levi
    2019 1794 SC
    Does anyone know if there is a difference between 2018 and 2019 models? Magnuson guy told me they don’t have sc for 2019. I mean same
    Motor right
  17. Jul 17, 2020 at 2:01 PM
    Kanekz
    Levi
    2019 1794 SC
    Sparksparts telling me the unichip will work. Everything is connected perfectly and truck is shutting off. Magnuson telling me only up to 2018 models
  18. Jul 17, 2020 at 2:05 PM
    Wyoming
    The only difference between a 2018 and a 2019 that I know of is the removal of the external transmission cooler. None of the 2019+ trucks have it. Now, that doesn't mean there aren't other differences, but that is the only one I know of.
  19. Jul 17, 2020 at 2:30 PM
    Kanekz
    Levi
    2019 1794 SC
    Yeah magnuson said ecu is the reason. Sparksparts guy insisted it will work on a 2019 and that my connections are wrong. Shop reapplied multiple times and confirmed it’s connected. I told sparks that there is a reason why it’s to 2018. He said nope it SHOULD work. Obviously it’s not working. Magnuson said said ecu changed between the years, so in theory could I buy a 2018 ecu
    And swap?
  20. Jul 17, 2020 at 2:33 PM
    Wyoming
    No clue. If the ECU changed, there would likely be a reason (possible to manage the increased tranny temps?) so I would be reluctant to do that swap. I'm not adventurous with my only vehicle though. :laughing:
  21. Jul 17, 2020 at 6:31 PM
    Kanekz
    Levi
    2019 1794 SC
    Also the harrop brand sc, on the YouTube site said they have a 2019. Looks like they using a hp tuner. Wonder if I could just go that route. Sparks pushed me toward a unichip.
    GODZILLA[QUOTED] likes this.
  22. Jul 17, 2020 at 6:40 PM
    Wyoming
    With the customer service woes I've heard about Sparks I would touch base with Roman at Cool Springs. Just my personal feelings.
    Black Wolf likes this.
  23. Jul 17, 2020 at 6:48 PM
    Kanekz
    Levi
    2019 1794 SC
    ONLY reason I went sparks cuz I saved 500$. I’ll hit Roman up.
  24. Jul 17, 2020 at 6:56 PM
    AZTundra
    Paul
    Phoenix, AZ
    I've got a small leak on mine that I noticed as well. My coolant leak is on one of the small hoses where it connects to the coolant crossover. It has one of the facory style spring clamps on it and probably needs to be replaced with a standard hose clamp to get a tighter fit. Not sure if I need to drain the coolant to replace the clamp or not.20200717_190033.jpg 20200717_190056.jpg
  25. Aug 8, 2020 at 11:31 PM
    Kanekz
    Levi
    2019 1794 SC
    About a month later, my 2019 is now sc and working good! So much tears but I’m good now! Now I can continue with the rest of my mods that was just sitting.
  26. Aug 8, 2020 at 11:50 PM
    davidbii
    davidbii New Member
    David
    What did you do for the chip/tuner? Curious as I have a ‘20.
  27. Aug 8, 2020 at 11:56 PM
    Kanekz
    Levi
    2019 1794 SC
    they send it with a unichip,
    not really a tune, but it tricks ecu that its running properly.
  28. Aug 9, 2020 at 5:07 AM
    Kanekz
    Levi
    2019 1794 SC
    Not my best try, but I put 2 decals on my new tow mirror caps. Then I gonna vinyl wrap it so it has a emboss look to it. I think it’s nice.
    JC303, Tundra2 and Leo's first like this.
  29. Aug 9, 2020 at 5:43 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I haven’t heard of folks having issues at Sparks before. What kind of issues are you talking about?
  30. Aug 9, 2020 at 6:19 AM
    Kanekz
    Levi
    2019 1794 SC
    Communication kind. They was hard to communicate with.
    GODZILLA and Uhhhh....[QUOTED] like this.
