Supercharger and stock exhaust?
Discussion in 'Performance and Tuning' started by mountainpete, Feb 22, 2020.
  1. Feb 22, 2020 at 7:53 PM
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I understand that with Magnuson an updated exhaust is recommended but not required. What are the potential consequences of not upgrading the exhaust?
  2. Feb 22, 2020 at 9:21 PM
    TXTundra2722
    2015 Black Tundra
    Less "Vroom, VROOM" sounds when you mash the gas:mudding:
    Honestly I believe it takes a little more custom tuning if you have more mods versus stock. @1UPPER had a custom exhaust from the headers and back and needed slightly more tweaking with the setup that he used to have.
    RitcheyRch and 1UPPER like this.
  3. Feb 23, 2020 at 4:38 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If your considering doing a Magnuson SC I would not install long tube headers. It makes tuning the truck a lot more difficult. Most of the tuning kits for the magnuson are based on stock headers. So if you change them you will have to go with a custom tuner like HP. It adds up quick. Is your truck a flex fuel?
    Saltyhero13 likes this.
  4. Feb 23, 2020 at 5:10 AM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    I wanted the extra power the SC provides while towing and still using the factory exhaust. I didn't want the additional noise and/or possible drone on longer trips. Like 1UPPER said if you do go with Long tubes and a free flowing exhaust you will run into some tuning issues. Matt with OVTune can help sort them out with logs and revisions too...
    snivilous and Rex Kramer like this.
  5. Feb 23, 2020 at 5:23 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    A BAMuffler cat-back is the only change that I would make to the exhaust if I ran a SC.
    CMB and dirtydeeds like this.
  6. Feb 23, 2020 at 7:37 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I’ve discovered that when supercharged, no matter what exhaust you have, you make the same power.
    trust me, this was devastating when I discovered this fact since I put braces in my kids face by selling tundra exhaust.
    thst said, while there is no power gains, the stock muffler is extremely restrictive by design, and it is so on purpose. That’s the cheapest way to make it quiet.
    by replacing the stock muffler with a Bamufflers standard system you remove the huge restriction and the heat that comes along with it. Our standard systems retain the stock tailpipe which keeps from losing low end torque.
    please feel free to give a call to discuss this topic in further detail.
    Keith 760-877-4234
  7. Feb 23, 2020 at 7:43 AM
    mountainpete
    So it doesn’t reduce valve heat
    Thanks Keith. Do you have a muffler that removes the restriction and stays quiet? I’m one of those guys that think the stock exhaust could be quieter but would love more power towing over the Rockies.
    dirtydeeds[QUOTED] likes this.
  8. Feb 23, 2020 at 8:21 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have some experience with a “quiet” aftermarket muffler.
    I have the magnaflow jumbo size. The case is 5x11 and it is 22 inches long. It is a 2 in 1 out similar to stock but a straight through design. On idle it has a small rumble, but is pretty quiet when you’re accelerating. I met one of the executives from magnaflow in person and he had told me before i put it on that it will get quieter as the rpms go up. He was right in my experience.
    The one thing I’ll say, it now drones. Keith makes the only resonator that kills any and all drone. It really works.
    My first tailpipe had a small oe resonator bulb after the muffler in it. I now have an oe tailpipe without that resonator. Whatever that piece is helps drone, as my magnaflow now drones pretty bad at certain rpms where as before it had none
    I can’t say it makes more power than stock, ive had it for 8-9 years now and it’s probably not much anyways.
    dirtydeeds likes this.
  9. Feb 23, 2020 at 9:21 AM
    Rex Kramer
    Georgia
    Your comment reminded me that I should probably re-install the resonator that came with my BAMuffler. Today is a good day to do that, thanks!
    OhEmmBee and dirtydeeds like this.
  10. Feb 23, 2020 at 9:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Im about to order one too. The BA resonator is amazing
  11. Feb 23, 2020 at 9:29 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Your engine is basically an air pump. When you change something in the suck, bang, blow process, you're changing how the vehicle was designed to manage and utilize that airflow. Honestly, if you want to slap some sort of forced induction on any vehicle, you should be thinking about the entire process, including a new tune to work with it. It's not as simple as slapping a SC on it and calling it good.
    EDIT: Should also mention that when you do add more power you should also look at whether your engine and driveline components can handle it, as those may need upgrading too.
    dirtydeeds and Wynnded like this.
  12. Feb 23, 2020 at 9:33 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    On my S/C'd 3.4L Tacoma I was able to add several degrees of timing to my tune with just a change from stock manifolds to headers. I was able to tune out almost all the Low RPM High Gear ping (it was a 5spd). I don't know if headers would have the same effect on the 5.7L, but would guess that it might and would certainly examine that.
    dirtydeeds and Sas like this.
  13. Feb 23, 2020 at 10:03 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    While Keith gets back to you,I can assure you that he's able to build your system as quiet as you need. I've had his 10" single on my 2010 for several years. The sound is exactly what I was after. You won't mistake it for stock, but it's light years away from some of the juvenile sounding "off the shelf" systems that just happen to fit our Tundras.' You may be a candidate for one of his 12" systems and even then,it'll still make you grin like a monkey when you get into it!:D P.S, with NO DRONE.
    dirtydeeds, Sas and Wynnded like this.
  14. Feb 23, 2020 at 10:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I run the same thing on my Tundra. :thumbsup:
  15. Feb 23, 2020 at 11:03 AM
    Rex Kramer
    Georgia
    I re-installed resonator today, and just returned from a test drive - What a difference!
    I go into more detail in my build thread.
  16. Feb 23, 2020 at 11:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The drone of my truck was awful without the resonator. One short test drive and on it went.
  17. Feb 24, 2020 at 7:02 AM
    dirtydeeds
    Keith
    USA
    When you run the Magnusson blower, the engine is no longer an air pump, the blower is. Not only is the blower and air pump, it’s a positive displacement air pump. When those rotors are turning the air is forced From one side to the other. If there is something in the way, it gets blown up.
    I’ve seen guys custom tune our trucks with long tube headers and supercharger, and their times are the same as my truck. There’s very little power in the exhaust when supercharged. It’s all about the cam phasing and pulley on the charger. Exhaust is simply there to reduce the pressure from the stock muffler.
    Wynnded, Sas[QUOTED] and Rex Kramer like this.
  18. Feb 24, 2020 at 7:03 AM
    dirtydeeds
    Keith
    USA
    I can do this. Call me and remind me of this post. 760-877-4234
  19. Feb 24, 2020 at 7:07 AM
    Sas
    OKC, OK
    Yep, excellent point.
  20. Feb 24, 2020 at 3:02 PM
    Punisher22
    Punisher22 New Member
    Dave
    NM
    2015 Platinum 4x4
    TRD Supercharger, FOX 2.5 coilovers, 35" Toyo R/T's on 17" wheels, Nitro Gear 4.88's w/ Auburn Pro, Expedition One bumpers w/ Baja Designs lights & Superwinch Talon 12.5SR, custom skid plates
    Are you running the same day on the same track? A lot of factors involved with running different times...
  21. Feb 24, 2020 at 7:57 PM
    MrMax
    Rob
    Eastern Iowa, USA
    One thing I noticed 20 years ago with my 4V SVT Cobra and it still holds true today...Is you cannot make these newer 4V engines sound like an old school push rod big block. And if they are 4V VVT you can also forget about cam lope as well...
    Rex Kramer and Wynnded like this.
  22. Mar 5, 2020 at 5:59 AM
    dirtydeeds
    Keith
    USA
    My truck runs 8.2 in the 1/8 mile day or night in San Diego.
  23. Mar 5, 2020 at 6:06 AM
    Rex Kramer
    Georgia
    Yeah, these motors sound more like big sewing machines.
    Sas likes this.
