Supercharged tundra shutting off when accelerated
Discussion in 'Performance and Tuning' started by Buckshot95, Mar 31, 2021.
  1. Mar 31, 2021 at 5:39 PM
    Buckshot95
    Buckshot95 [OP] New Member
    2017 supercharged tundra
    Magnusson supercharger
    2017 supercharged tundra shuts off when easing on the accelerator. But starts right back up. Any advice?
  2. Mar 31, 2021 at 5:59 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    WHEELS MotoMetal 962’s 20x12 -44 offset SUSPENSION Energy Suspension Bump Stops Pro Comp 6” Lift Kit Body mount chop - BMC King Front Shocks with Remote Resi King Rear Shocks with Remote Resi Toyota TRD Rear Sway Bar Pro Comp ProRunner UCA's Toytec Adjustable Lift Shackles DRIVETRAIN Energy Suspension Rack Bushings (progress) TIRES Fuel Mudder M/T 37x13.5x20 EXTERIOR BulletLiner Truck Bed Liner PerformanceAccessories 3" Body Lift Performance Accessories Gap Guards Go Rhino Dominator D2 Nerf Bars Undercover SE Tonneau Cover AUDIO JL Audio HD900/5 JL Audio HD750/1 Dynamat Extreme Closed Cell Foam Install (progress) JL Audio Stealthbox Pioneer SPH-DA120 (AppRadio 4) INTERIOR Black Suede Headliner Carbon Fiber Vinyl Wrap Suede Door Panel Insets Steering Wheel Cover AJT Design Shift Knob AJT Design Key Fob LIGHTING Door panel accent lighting Swapped all interior lights to LED Morimoto Custom Retrofit Headlights Morimoto XB LED Fog Lights COSMETIC Debadged All Emblems Powdercoated ProComp Lift Parts Envy Grille (progress) G2 Brake Caliper Paint - Gold Toyota Fender Flares PERFORMANCE Unichip programmer StopTech Drilled and Slotted Rotors Borla Turbo XL Muffler K&N Air Filter STORAGE Rotopax 4 gallon fuel pack Diesel Power Hang A Hitch TOWING Elevated Suspension Tow Brackets Razor Auto Aluminum Shackles ELECTRICAL Optima Yellow Top Battery
    I would start with checking the vacuum hoses.
  3. Mar 31, 2021 at 6:03 PM
    AZTundra
    Paul
    Phoenix, AZ
    :popcorn:
    2017 supercharged here, but never ran into or heard of that problem before. When was the supercharger installed? Why do you think that is the culprit?
  4. Mar 31, 2021 at 6:18 PM
    Buckshot95
    Installed about 2 months ago.
    I forgot to mention that it stalled 3 times in a row and then it ran fine.
  5. Mar 31, 2021 at 6:21 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Could be trash in the fuel line/pickup...no fuel filter on these trucks if you can believe that one...
  6. Mar 31, 2021 at 6:27 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, sounds like a possible fuel issue to me. Any check engine light or codes? Flex Fuel?
  7. Mar 31, 2021 at 6:42 PM
    Buckshot95
    No codes and yes flex fuel
  8. Apr 1, 2021 at 3:47 AM
    blanchard7684
    blanchard7684 New Member
    no codes at all? very strange. Something is hitting a power circuit.
    I've seen this in other vehicles that had worn out ignition switches. (I've also seen it in a 1000 rwhp mustang that had ignition turn off from inertia).
    what are driving conditions when it shuts off? low vehicle speed, high vehicle speed?
    I would think outside of the box on this one:
    Ground wires
    Battery connections
    Battery health
    Alternator wiring
    PCM fuse, relay
    Fuel pump fuse, relay
    Ignition switch
    Ignition fuse, relay (not sure if Tundra has a circuit like this)
    Basically check for things that are in circuits that can shutdown the truck like the key was cycled.
  9. Apr 1, 2021 at 4:53 AM
    Buckshot95
    Shuts off around 1800rpms only when driving.
  10. Apr 1, 2021 at 5:54 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Is your truck flex fuel? Did you upgrade the pump? My fuel pump would give me fits at 1800-2200rpm. It would stutter and not want to pick up speed. I'm sure if I was supercharged it would have stalled from lack of fuel. I replaced my pump with an aeromotive pump and kit from URD.
  11. Apr 1, 2021 at 6:06 AM
    Buckshot95
    No magnusson said i didn't need to replace pump.
    It ran great for a around 2k miles. But if it is pump i will definitely upgrade.
  12. Apr 1, 2021 at 9:40 AM
    blanchard7684
    Check wiring and connection to crank sensor ... but this would trip a code.
  13. Apr 1, 2021 at 1:38 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Do you have a video of this happening? I agree that this would absolutely cause a code, whether historical or not, if it's an engine stall event.
    When you say it shuts off, are you saying the engine dies, or that the truck loses power completely as if the ignition was turned to "off"?
  14. Apr 9, 2023 at 6:08 AM
    turtletree
    turtletree New Member
    I’m gonna jump on this too. I’m having the exact same problem. Just installed supercharger 2016 flex fuel tundra. It drove for about 2k as well with no issues. At 1500 rpm it will shut off the engine. Dash will stay on. But if I turn the key off and back on it will stay running but once I hit 1500 rpm it will do the same thing. If I do that process about 6-8 times by the 8th time it will stay running and get passed the 1500 rpm. I’m thinking it’s something to do with the fuel pressure switch valve. I can get a constant code of p-109c. Next move is changing the fuel system with Prospeed fuel system. At least I know I’m not the only one dealing with this.
