Super Bowl Eats
Discussion in 'Food Talk' started by JMB, Feb 6, 2021.
  1. Feb 6, 2021 at 8:23 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    JMB[QUOTED][OP] likes this.
  2. Feb 6, 2021 at 8:28 PM
    TaquitoBandito
    Joel (AKA Bif)
    I love Cubanos! It's one of those sandwiches that tears the roof of your mouth, but worth it. I've got a pretty good Cubano recipe from Cooks Country that I'm sharing below. When I made it last, I didn't have a smoker. If/when I do it again, the pork is going in the smoker.
    For the bread:
    Sponge
    ¼ cup water
    ¼ cup (1¼ ounces) all-purpose flour
    ½ teaspoon instant or rapid-rise yeast
    Dough
    3 cups (15 ounces) all-purpose flour
    2 teaspoons instant or rapid-rise yeast
    1 ½ teaspoons table salt
    1 cup warm water (110 degrees)
    ¼ cup lard
    1 (16 by 12-inch) rectangular disposable aluminum roasting pan
    FOR THE SPONGE: Whisk all ingredients with fork in liquid measuring cup until consistency of thin pancake batter. Cover with plastic wrap and refrigerate overnight (sponge will rise and collapse).
    FOR THE DOUGH: Whisk flour, yeast, and salt together in bowl of stand mixer. Add warm water, lard, and sponge. Fit mixer with dough hook and mix on low speed until no dry flour remains, about 2 minutes, scraping down bowl as needed. Increase speed to medium and knead for 8 minutes. (Dough will be sticky and clear sides of bowl but still stick to bottom.)
    Turn out dough onto lightly floured counter, sprinkle top with flour, and knead briefly to form smooth ball, about 30 seconds. Transfer dough to greased large bowl and turn to coat. Cover with plastic and let dough rise at room temperature until doubled in size, about 45 minutes.
    Line rimless baking sheet with parchment paper. Turn out dough onto floured counter and cut into 2 equal pieces, about 14 ounces each.
    Working with 1 piece of dough at a time, flatten into 10 by 6-inch rectangle with long side parallel to counter's edge. Fold top edge of rectangle down to midline, pressing to seal. Fold bottom edge of rectangle up to midline, pressing to seal. Fold dough in half so top and bottom edges meet; pinch seam and ends to seal. Flip dough seam side down and gently roll into 15-inch loaf with tapered ends.
    Transfer loaf, seam side down, to 1 side of prepared sheet. Repeat shaping with second piece of dough and place about 3 inches from first loaf on other side of sheet. Cover loosely with plastic and let rise at room temperature until puffy, about 30 minutes. Adjust oven rack to middle position and heat oven to 450 degrees.
    Using sharp paring knife in swift, fluid motion, make ⅛-inch-deep lengthwise slash along top of each loaf, starting and stopping about 1½ inches from ends. Cover loaves with inverted disposable pan. Bake for 20 minutes. Using tongs, remove disposable pan and continue to bake until loaves are light golden brown and centers register 210 degrees, 10 to 12 minutes longer.
    Transfer loaves to wire rack and let cool for 30 minutes. Serve warm.
    TO MAKE AHEAD: Fully cooled loaves can be wrapped in aluminum foil and stored at room temperature for up to 2 days. Cooled bread can also be wrapped in plastic wrap, then in foil, and frozen for up to 1 month. Unwrap and warm before serving.
    For the meat:
    ⅓ cup kosher salt
    ⅓ cup packed light brown sugar
    1 tablespoon lime zest (2 limes)
    1 tablespoon orange zest
    3 garlic cloves, minced
    2 teaspoons ground cumin
    2 teaspoons dried oregano
    ½ teaspoon red pepper flakes
    1 (5-pound) boneless pork butt with fat cap
    Mojo
    ⅓ cup extra-virgin olive oil
    6 garlic cloves, minced
    ⅓ cup pineapple juice
    ⅓ cup orange juice
    ⅓ cup lime juice (3 limes)
    1 tablespoon yellow mustard
    1 ¼ teaspoons ground cumin
    1 teaspoon kosher salt
    ¾ teaspoon pepper
    ¾ teaspoon dried oregano
    ¼ teaspoon red pepper flakes
    Thinly sliced onion rounds
    FOR THE PORK: Combine salt, sugar, lime zest, orange zest, garlic, cumin, oregano, and pepper flakes in bowl. Using sharp knife, trim fat cap on pork to ¼ inch. Cut 1-inch crosshatch pattern in fat cap.
    Place pork on large double layer of plastic wrap. Sprinkle pork all over with salt mixture. Wrap pork tightly in plastic, place on plate, and refrigerate for at least 12 hours or up to 24 hours.
    Adjust oven rack to middle position and heat oven to 325 degrees. Unwrap pork; transfer to Dutch oven, fat side up; and pour 2 cups water around pork. Cover, transfer to oven, and cook until meat registers 175 degrees in center, 2½ to 3 hours.
    Uncover pork and continue to cook until meat registers 195 degrees in center and fork slips easily in and out of meat, 45 minutes to 1¾ hours longer. Transfer pork to carving board, tent with aluminum foil, and let rest for 45 minutes.
    FOR THE MOJO: While pork is resting, heat oil and garlic in small saucepan over low heat, stirring often, until tiny bubbles appear and garlic is fragrant and straw-colored, 3 to 5 minutes. Let cool for at least 5 minutes. Whisk pineapple juice, orange juice, lime juice, mustard, cumin, salt, pepper, oregano, and pepper flakes into cooled garlic oil.
    Slice pork as thin as possible (some meat may shred; this is OK) and transfer to serving platter. Serve with onion and mojo.
    Now put it all together:
    1 recipe Cuban Bread
    ¼ cup mojo from Cuban Roast Pork with Mojo (optional)
    ¼ cup mayonnaise (optional)
    12 ounces thinly sliced deli ham
    10 ounces thinly sliced Cuban roast pork from Cuban Roast Pork with Mojo (2 cups)
    3 ounces thinly sliced deli Genoa salami with peppercorns
    6 ounces thinly sliced deli Swiss cheese
    16 dill pickle chips
    ¼ cup yellow mustard
    4 tablespoons unsalted butter, cut into 4 pieces, divided
    Adjust oven rack to middle position and heat oven to 200 degrees. Set wire rack in rimmed baking sheet. Cut bread in half crosswise, then cut each piece in half horizontally.
    Brush bread bottoms with mojo, if using, and spread with mayonnaise, if using. Layer on ham, followed by pork, salami, cheese, and pickles, overlapping and/or folding meats as needed to keep them from overhanging sides of bread. Spread mustard on bread tops. Cap sandwiches with bread tops.
    Melt 1 tablespoon butter in 12-inch nonstick skillet over medium-low heat. Place 2 sandwiches in skillet, right side up, in alternating directions, and spread far apart. Place heavy Dutch oven on top and cook until bottoms of sandwiches are uniformly golden brown and feel firm when tapped, 5 to 7 minutes, rotating sandwiches in skillet as needed. (You will need to flip sandwiches to tap them.)
    Transfer sandwiches to cutting board. Melt 1 tablespoon butter in now-empty skillet. Return sandwiches to skillet toasted side up. Place Dutch oven on top and continue to cook until second side is uniformly golden brown and feels firm when tapped, 3 to 5 minutes longer.
    Transfer toasted sandwiches to prepared wire rack and place in oven to keep warm. Wipe skillet clean with paper towels. Repeat with remaining 2 tablespoons butter and remaining 2 sandwiches. Cut sandwiches in half on steep diagonal and serve.
  3. Feb 6, 2021 at 8:31 PM
    TaquitoBandito
    Joel (AKA Bif)
    Sorry, I got sidetracked. I don't usually pay to much attention to the game - I'm all in for the commercials. I am a big Eric Church fan so I'm interested to see his National Anthem duet. I've got some ribs to smoke but no other big menu plans. I hope those of you who watch it, enjoy it. I hope those of you who aren't going to watch it, enjoy yourselves too.
    gosolo, Black Wolf, Toyokuhl and 4 others like this.
  4. Feb 6, 2021 at 9:16 PM
    Wings
    Beer
    Booze
  5. Feb 6, 2021 at 9:20 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Making chili in the crockpot and being lazy. It should be a damn good game.
  6. Feb 6, 2021 at 9:20 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Bloody marrys, shrimp cocktail, garlic chicken wings, ribeye steaks
  7. Feb 6, 2021 at 9:30 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Made a test batch of hot, and sweet and Smokey wings. Damn good. :thumbsup:
  8. Feb 6, 2021 at 9:37 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I normally do chicken wings...but they were either ridiculously priced or so small it wasn't going to be worth it this year. My aunt is making us a seven layer dip to make up for it.
  9. Feb 7, 2021 at 3:20 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Wow, there's a few on here that must be A BLAST at parties...
    We're throwing an all out tailgate party at my place for my Bucs loving FL folk that have relocated to Denver. Brats, sausages, burgers, all the dips and apps. Have the house all decked out with streamers and our bucs gear. Gonna be blasting it in the basement theater.
    LET'S GO BUCS! FIRE THE CANNONS!!!!
  10. Feb 7, 2021 at 3:42 AM
    Paul B
    Paul B New Member
    Paul
    2019 Cavalry Blue Tundra TRD Offroad
    chicken wing dip!!
  11. Feb 7, 2021 at 6:13 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    aww, poor little feller....
    I’ll be sure to eat a few extra wings and dip for you. I don’t even give a shit about football, but I won’t miss an excuse to make some party food.
  12. Feb 7, 2021 at 6:15 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    yum
  13. Feb 7, 2021 at 6:18 AM
    T500
    Alfie
    Neptune, NJ
    2020 Black
    ‘We have wings, filet, chips, dip, pasta salad, beer, wine, liquor. We need sides, dessert and ice.’
    I’m bringing baked beans...
    And Vegemite for the heathens
  14. Feb 7, 2021 at 6:20 AM
    T500
    Alfie
    Neptune, NJ
    2020 Black
    Oh and watching Puppy Bowl
  15. Feb 7, 2021 at 6:22 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    What T-Rex said....
    T-Rex266[QUOTED] likes this.
  16. Feb 7, 2021 at 6:22 AM
    Leo's first
    Groton ma
    Got any fur in the game?
  17. Feb 7, 2021 at 6:23 AM
    T500
    Alfie
    Neptune, NJ
    2020 Black
    :eek:
    Leo's first[QUOTED] likes this.
  18. Feb 7, 2021 at 6:24 AM
    Kanobi13
    Kanobi13 New Member
    After i smoke a super bowl i usually eat the entire kitchen!!
  19. Feb 7, 2021 at 6:25 AM
    #49
    T500
    Alfie
    Neptune, NJ
    2020 Black
    jewsNbrews likes this.
  20. Feb 7, 2021 at 6:37 AM
    #50
    Grilling, wings and few racks of baby back ribs, and few dips being made
  21. Feb 7, 2021 at 6:40 AM
    #51
    speckmon
    Thornton, CO
    I like this guy.
  22. Feb 7, 2021 at 7:52 AM
    #52
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I heard they won’t let them fire the cannons. Might have been more fun to let both teams do it.
    :fenforcer:
  23. Feb 7, 2021 at 8:19 AM
    #53
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Brisket, leftover pulled pork and hoagie dip! Couple local crowlers of Irish Red. I like the idea of Tampa beer and Kc beer.
  24. Feb 7, 2021 at 9:09 AM
    #54
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Totally unrelated- but looking at your name just made me think....is there anything funnier than that skit? “ You done messed up A-A-Ron!! You want to go to war B-la-ke!! Sooo classic!!
    A-A-Ron[QUOTED] likes this.
  25. Feb 7, 2021 at 10:29 AM
    #55
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    So sorry for hurting your tender little sensibilities. We’re going to be eating racks of ribs (we butchered 3 pigs this winter) and grilled potato slices with some other sides. It’s just got nothing to do with watching a bunch of overpaid, drug enhanced, self righteous, narcissistic, primadonnas.
    T500 likes this.
  26. Feb 7, 2021 at 11:08 AM
    #56
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I am smoking some baby back ribs, spicy wings, lemon pepper dry-rub wings, spicy garlic quail and butt rub quail.
  27. Feb 7, 2021 at 11:10 AM
    #57
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Wings, whisky, beers, stuffed mushrooms and anything else on the Traeger...If Tom Brady wins another super bowl I will promptly puke it all up.
    Cpl_Punishment and JMB[OP] like this.
  28. Feb 7, 2021 at 11:23 AM
    #58
    I_Am_Thee_Walrus
    Brother, your posts on a “Super Bowl Eats” thread tell me all I need to know about you. Have a good day, sir. :hattip:
  29. Feb 7, 2021 at 11:24 AM
    #59
    T500
    Alfie
    Neptune, NJ
    2020 Black
  30. Feb 7, 2021 at 11:28 AM
    #60
