Sunroof issues
Discussion in 'General Tundra Discussion' started by Toytunman, May 30, 2016.
  1. May 30, 2016 at 10:27 AM
    Toytunman
    Toytunman [OP] New Member
    There's a grinding noise when I open the sunroof. It is coming from the auto wind deflector because it grinds when I drop below certain speeds. Any advice??
  2. May 30, 2016 at 10:29 AM
  3. May 30, 2016 at 10:39 AM
    Toytunman
    2012 platinum
  4. May 30, 2016 at 11:16 AM
    Any video of the sound to better diagnose?
  5. May 30, 2016 at 11:27 AM
    Toytunman
    I can a little bit later. My friend is using my truck right now. I know it's the auto wind deflector. It makes that grinding noise at certain speeds when the deflector is supposed to go up or down depending on how fast you're going. It doesn't move anymore, just making a grinding noise.
  6. May 30, 2016 at 11:41 AM
    Sounds like a gear or linkage is broken which is what is making the noise. I'm not sure exactly how it operates, so it is just speculation on my part.
  7. May 30, 2016 at 11:45 AM
    Toytunman
    Yes, that's what I think it is too. I'm just wondering how to fix it. Or, just disable it someway. I don't know anything about sunroofs.
  8. Sep 7, 2022 at 8:26 AM
    RoGun
    RoGun New Member
    I know it's an old thread, but I have an old truck (2011) and the same exact problem. Did you ever figure out how to fix this?
  9. Apr 11, 2025 at 4:25 PM
    Jason p
    Jason p New Member
    I am having the same issue. Did you find a fix?
  10. Apr 16, 2025 at 2:11 PM
    Jason p
    Jason p New Member
    I have a 2011 tundra crewmax limited
