Suggestions for best wireless charger
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Jan 6, 2022.
  1. Jan 6, 2022 at 2:14 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    My sales rep last week told me Toyota makes one to replace the center console top pocket. Parts told me today that’s true but only on some years and 2018 isn’t one of them.
    So looking after-market. I see lots of options. Anyone have a preference or recommendation? My two priorities are fastest possible charging and looking as OEM as possible.
  2. Jan 6, 2022 at 2:23 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    That's not true. Mine is an 18 and I have it in my truck. Works perfect. Look at sparksparts.com. They sell them. Look on the back of your console. If there is 12volt port there. Then it will work. Takes about 30 mins. to install.
    Shadowfax1[OP] likes this.
  3. Jan 6, 2022 at 2:26 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    What phone?
  4. Jan 6, 2022 at 2:27 PM
    Shadowfax1
    iOS devices
  5. Jan 6, 2022 at 2:44 PM
    19TurdPro
    2019 Tundra TRD Pro
    The OEM Toyota console one will work, but it's 10 watts. Your phone is most likely capable of 15 watts. If it were me I'd just use the Apple Mag Safe and call it good. Belkin makes some nice ones as well.
    The OEM Toyota one will work on your truck. Your dealer is incorrect. It just won't charge as fast as your phone is capable of.
  6. Jan 6, 2022 at 2:54 PM
    Shadowfax1
    Interesting. sparksparts has the wireless charging tray, but says it is not compatible with my 2018 (which is a 1794 Edition, specifically). I have a 12volt back there. Why the heck would it not be compatible with mine?
    It also says at the bottom that iPhone 12 may not work with it...that would be problematic.
  7. Jan 6, 2022 at 2:57 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I have a 2018 1794 and it works perfect on mine. I will never turn to the Dark Side of IOS. But normally when my golfing buddies are in the truck. They use it with their IPhones and have no issues.
  8. Jan 6, 2022 at 2:57 PM
    Shadowfax1
    This is helpful, thank you. I admit to being super picky; I despite cords and cables dangling around my car, so I'm not inclined to use a MagSafe or another standard charger.
    Yes, iPhone 12 and 12 Pro (mine is a 12 Pro) finally added 15w support.
    Maybe I can find an after-market one that supports 15w. Or is the limitation in the vehicle wiring?
  9. Jan 6, 2022 at 3:09 PM
    19TurdPro
    2019 Tundra TRD Pro
    The cool thing with the OEM MagSafe charger is it's small and discreet, and your phone sticks to it REALLY well. You could probably easily glue or tape it somewhere, hide the cord, then slap the phone right on it, and it will never move.
    The vehicle wiring can support the 15 watt charger. I have a 45 watt charger for my Galaxy S21 Ultra.
    Mike59 likes this.
  10. Jan 6, 2022 at 3:13 PM
    Shadowfax1
    Ok...stupid question alert...but I do freaking foreign policy and strategic analysis. I don't do mechanics and electricity :help:
    Not knowing the difference between amps, watts, and volts.... How many watts can I run off of a standard 12 volt DC socket? I presume the wireless charger (whether Toyota's or an after market's) taps into the 12 volt socket on the back of the center console rather than running direct to the battery.
  11. Jan 6, 2022 at 3:17 PM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    I received mine today from Sparks and it will be going into my '21. Brochure says 7.5w for iPhone.
    IIRC, the iPhone small wall chargers are 5w and take hours for a full charge. The iPhone will handle a max of 18w which cuts charging to about 2hrs. If this delivers 7.5w, I should have no issues keeping my iPhone 11 charged. As always, YMMV.
    bulldog93 and Shadowfax1[OP] like this.
  12. Jan 6, 2022 at 3:32 PM
    19TurdPro
    2019 Tundra TRD Pro
    Depends on how many amps the fuse is it's connected to.
    10 amps is about 120 watts
    20 is about 240 watts
    Those are estimates because the electrical system is seldom exactly 12v.
    That's also the max load of the circuit and doesn't account for what else might be drawing power.
    Luke_Skywalker likes this.
  13. Jan 6, 2022 at 3:34 PM
    Shadowfax1
    So if we assume the fuse for that 12v on the back of the center console is only 10 amps... If I'm inferring correctly, I can run my own 15 watt iPhone charger PLUS 2 more 15 watt chargers in the back seat (tapping into the same 12v socket) simultaneously and all will still charge at full speed? (15*3=45 watts = no where close to 120)
  14. Jan 6, 2022 at 3:39 PM
    19TurdPro
    2019 Tundra TRD Pro
    I'm running this one in my front socket. It's 78 watts, and I max it out.
    https://www.amazon.com/dp/B091G28KH5
    Mike59 and bulldog93 like this.
  15. Jan 6, 2022 at 3:50 PM
    Shadowfax1
  16. Jan 6, 2022 at 5:22 PM
    Brown747
    Brown747 New Member
    2021 Cement Crew Max LTD
  17. Jan 6, 2022 at 5:50 PM
    Shadowfax1
    That’s actually the same one as I linked to but branded differently. Look at the photos; identical.
    So how well does it charge? Especially curious if you’re on an iPhone 12 or 13 and actually getting the super fast 15w charging.
  18. Jan 6, 2022 at 6:29 PM
    Brown747
    Brown747 New Member
    I still have a stone age Iphone 8.
    Seems to charge at about same rate as when plugged into A/C. The blue light bar that indicates charging is a little too bright but I can live with it and I really like not having a cord flopping about…
    I rate it an 8.5
  19. Jan 6, 2022 at 6:31 PM
    Brown747
    Brown747 New Member
    … the wife’s 12 charges without issues. I would not say superfast for either phone.
  20. Jan 7, 2022 at 4:23 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    1.21 Gigawatts. When you're truck reaches 88 MPH, you're gonna some serious :poking::rofl:
    runningbombtech, bulldog93 and ATV25 like this.
  21. Jan 7, 2022 at 6:15 AM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    One of these is on my short list for sure. For those who don’t like cables sticking out there is also a wireless CarPlay dongle that can be installed pretty easily using one of the USB ports in the front. Then you’d have 0 wires.
  22. Jan 21, 2022 at 4:28 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I have an iPhone 13 pro and am experiencing issues with the OEM wireless charger from SE Toyota. It seems to work for ~5-10 minutes and then I get the red error message indicating metal/magnetic object, overheating, or incompatible phone. This was while using a MagBak case. I have also tried without any case and a Rockform case. Seems to be due to metal ring of MagSafe on phone or large camera bump if these newer models. I am wondering if anyone else is experiencing this or has a possible solution. Definitely 1st world problems lol…
  23. Jan 21, 2022 at 5:17 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Wondering if there is a workaround for this as well. I’ve noticed that it’s not just my trucks wireless charging that has an issue now. Had a wireless charger in my house that no longer works with my iPhone 12. Both were working flawlessly before upgrading
  24. Jan 21, 2022 at 5:52 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  25. Jan 21, 2022 at 5:59 AM
    zasdds
    zasdds New Member
  26. Jan 21, 2022 at 6:07 AM
    BlueCrushSC16
    Charleston, SC
    My Galaxy S10+ phone case won't allow wireless charging. I just saw this charger and thought it was a good option for those that don't want to get the one for the arm rest.
  27. Jan 24, 2022 at 5:37 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    This charger worked great with my iPhone 8 Plus, I upgraded to a 13 Pro Max and it now laughs at me and is useless. It will work for a minute then foul out. I just have to plug in the charger cord now.
    zasdds likes this.
  28. Jan 24, 2022 at 5:45 PM
    November Sun
    Huntsville, Alabama
    Didn't see your post before I quoted someone else, yeah, my 13 Pro Max doesn't work on the OEM Charger, acts like how you described, I've tried
    several different cases and no case. I've just resorted to plugging mine back in. OEM is only good for 7.5 watts.
    zasdds[QUOTED] likes this.
  29. Jan 24, 2022 at 5:52 PM
    Clemsonman14
    Has anyone tried this? Seems like the phone sliding around in the tray may be causing issue. Might try holding it like this guy suggests to see if it helps. If it does, something rubber to hold it still may do the trick.
  30. Jan 24, 2022 at 7:19 PM
    November Sun
    Huntsville, Alabama
    first time I've seen that video, makes sense, sometimes mine works but mine will still foul out sitting still. One member suggested an insert, i ordered it and it still didn't work.
