Suggestions for 2.5" front, 1.5" rear lift?
Discussion in 'Suspension' started by Kraykhoff, Dec 16, 2017.
  1. Dec 16, 2017 at 8:30 AM
    Kraykhoff
    Kraykhoff [OP] New Member
    Black 07 Tundra SR5 trd
    Looking to do Bilstein 5100 on the front to raise it 2.5. Should i buy new coils too? Would like the back raised 1.5 or so too ( want slight rake ) any ideas?
  2. Dec 16, 2017 at 10:10 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Not sure if you are doing the install yourself, but I would buy some takeoff front assy from a newer truck, do the coil swap to the new 5100's and have the new units ready to install. That way the day off install you are not messing with a spring compressor and rushing to get the job done. It will be an easy coil over assy swap out and alignment in the same day. Rear can be with coachbuilder shackles or the like. Good luck with all.
  3. Dec 16, 2017 at 10:24 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The truck should sit pretty level with 5100s at top setting. You don't need new coils unless you've got high mileage.
  4. Dec 16, 2017 at 10:36 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    If you Wnana go throught the trouble for new coils and stuff get 6112s but you should be fine with your stockers
    geno0506 and Casper3 like this.
  5. Dec 16, 2017 at 6:34 PM
    Kraykhoff
    Right on thanks, so with the front raised whats the best way to get the back up a bit? 5100 in the back too? toytec shackles? good or not?
  6. Dec 16, 2017 at 8:43 PM
    xtyfighterx
    Ty
    North Idaho
    They are good. Probabaly 1in is all you need.
  7. Dec 17, 2017 at 2:12 AM
    IslandHui
    IslandHui New Member
    Del
    Oahu, Hawaii
    2016 White DC TRD
    2.5 Kings, Deaver k37, TC A-arms, trd pro grille
    I have coach builder +3 shackles it lifts the rear about 1.75". The shackles are beefy
  8. Dec 17, 2017 at 2:56 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have Add-a-leaf primarily because when I bought my OME kit from Toytec, AAL was a $10 option. I noticed that this is no longer an option on their site. From what I've read, you can't go wrong with Coachbuilder products.
  9. Dec 17, 2017 at 4:20 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    2.5in the front looks mostly level, but I believe it's about .5 inches taller than the rear. I've measured a few local trucks and 2in front is the closest level setting.
    I'd say..
    Low Budget...
    5100 at the top in front, with 1in the rear via blocks or shackles with 5100
    Middle budget...
    6112 at the top in front, with 1in the rear via blocks or shackles with 5160
    Better...
    Toytec Boss 3/1
  10. Dec 17, 2017 at 6:51 AM
    xtyfighterx
    Ty
    North Idaho
    And the best
    Fox 2.5 :)
  11. Dec 17, 2017 at 6:52 AM
    xtyfighterx
    Ty
    North Idaho
    Check my build out OP I originally had a leveling kit at 2.5 then added a 1in block to it then later went to fox coilovers at 3in and a 1in shackle. Might give you an idea on stance.
  12. Dec 19, 2017 at 12:48 AM
    geno0506
    geno0506 New Member
    Michael
    Great point and better setup at that!
